99 ES300 charging issues
Replaced the alternator due to low voltage. Now it will not charge at Idle. Under driving conditions it will run at 13.8-14.3 volts but at idle and under heavy load (seat heater, rear def, bright lights) the voltage drops till the car dies. Battery tested ok and even swapped the battery with a brand new one and same problem. Back to back ALT replaced and same.issues? Looking for answers!
