es300 2001 ignition coil connectors
Hi guys,
I'm wanting to replace my spark plugs, but what happens if one of the connectors to the ignition coil breaks while trying to get it off? I've tried to find replacement housing for those connectors online but not much luck so far. Do you think there is enough length to take out the front and rear ignition coils without removing the connectors?
If you break the connectors the housings can be replaced although it can be a bit of a challenge to find the part number.
http://wilbo666.pbworks.com/w/file/f...RM1022E%29.pdf
is this it?
http://www.ebay.com/itm/Connector-Pl...NWoZut&vxp=mtr
looks like part number is 90980-11885
Not sure, found a bunch from this page but don't know if one of them is it and which
http://www.lexuspartsnow.com/parts-l...ing-clamp.html
There should be a number on the connector prefix it with 90980- and there's your part number.
