1999 Lexus es300 front and rear creaking
Hey guys! so as stated, when I go into driveways or go over speed bumps, you can hear the front end creaking and the backend creaking.
So far I've replaced All 4 struts and replaced the strut Tower mounts in the front to get rid of the Coke can rattle.
I've done some research but only other model Lexus's come up with the front and rear creaking noise.
Thanks in advance.
Thanks in advance.
Just look at the other thread just started "Suspension refresh" and it talks about similar issue. As mentioned in that thread, check the following atleast for the rear sound
1. sway bar end links
2. rear control arm bushings
Dorian7
16
03-17-15 03:30 PM
LEX ES300
44
10-18-12 02:51 PM
