1997 Lexus ES300 power steering leak?
Old 07-18-16, 11:39 AM
hanime
hanime's Avatar
Default 1997 Lexus ES300 power steering leak?
My '97 ES300 is leaking power steering. I checked the leak and it appears to come from the "lower return tube" at the U bend (part# 4441606050).
But this part costs $100-$200 brand new and $50 used. I don't know whether it is worth it to spend on this part, or go with alternatives since my car is well over 275K. Can this tube be replaced with a one-piece rubber hose of some sort? Can I drive without power steering? I am okay with that as long as it is safe to disable it somehow.
Old 07-18-16, 01:55 PM
808mcv20l
808mcv20l's Avatar
Likely the leak is coming from the rubber portion of that line, the metal should not be leaking unless you are in a high rust area.
The rubber portion can be replaced with a cheapo hose by the foot from your local oreillys or Autozone. I used fuel line hose, forget the diameter, but if you bring a sample they can match it up.
Be sure to measure the inner diameter of the hose not the Outer diameter. The protective rubber sleeve can be removed off the old hose and put over the new one, I believe all that holds it together is a bit of glue.
I also had to replace the high pressure hose which was leaking, if yours hasn't already started leaking it will eventually. That one was 300+ from the dealer and 75 bucks aftermarket. I went with an aftermarket one and has been leak free for more than 1.5 years now.
Old 07-18-16, 05:37 PM
fortitude
fortitude's Avatar
I change the high pressure line on my '02 with Edelmann from Rock Auto.
So far so good.
Old 07-19-16, 06:56 AM
mmatheny
mmatheny's Avatar
No, you can't drive a power steering car without power steering - unless you're a weight lifter!
Old 07-19-16, 09:07 AM
hanime
hanime's Avatar
That is a good point regarding the leak coming from the rubber portion. The metal U-tube was a bit rusty on the bottom where I saw the dripping, so I had assumed it was at the metal tube area. I've wiped the hoses/tube down and filled the reservoir, so I'll see where the real leak is coming from.
You got me scared now about the high pressure hose.
Dortiz105
02-16-19 06:26 PM
Thrive1987
09-08-18 01:42 PM
isaiah2011
08-12-11 08:34 AM
funyunz
RX - 1st Gen (1999-2003)
10-22-09 08:16 AM
lex71
09-08-07 12:11 AM
Quick Reply: 1997 Lexus ES300 power steering leak?
