Differential Fluid Change in my 98 ES300
I would like to change the differential fluid in my 98 ES300 with 80k miles. I changed the tranny fluid recently with Toyota Type VI. Where is the differential drain/fill plug(s) ? How many quarts of gear oil do I need ?
Thanks,
Ching-Ho Cheng
Thanks,
Ching-Ho Cheng
What I understand from a Toyota tech is that both the transmission and differential are shared cavities, but each has its own drain plug. The differential drain plug is the same type as the transmission pan, but perpendicular to ground, facing rear of the car. You still fill it through the transmission oil tube, and needs about an extra 0.8qt (I think), or look in the owner's manual. There is actually a very good link for a complete flush that you can do yourself under the Maintenance sub-forum, which takes to a link of a GS400 owner detailing the steps.
One more question, I am going to help my friend to replace his 2000 ES300's tranny/diferential fluid. Is 2000 the same setup as 98 ?
Thanks,
Ching-Ho Cheng
Thanks,
Ching-Ho Cheng
Me too. Also, if you change the differential fluid, if I jack up the end and support with jack stands, the car will no longer be level for the differential fill. Since the car is at an angle, would this cause the differential fill to be too much/little before it starts flowing out of the fill hole?
Concerning the tranny fluid. Yes, very conflicting, seems that some just state us the Toyo Type IV even with out asking year, or say to use the type 4 anyways. So which is it for '98 and below? If Dextron2-3, I was thinking of using a synthetic ATF, but read in another thread that that person had some issue (but then again, he mixed just about 4-5 products in by the end of it)
there was a Lexus TSB where it states that if your your model year stated dextron II or III, ( our lexus states dextron), then we should stick with that. So just wondering, did you ever drain out the differential? and also how is the transmission shifting in the '98 with toyotatype IV?
I have never drained the differential oil. I only did the tranny fluid with Toyota type IV. Shifting is slight improved with the new fluid, but not a big different.
I would jack up the car to access the drain plug of the differential. Then, I would put back the plug and lower the car back on ground for adding new differential oil to ensure the oil level is correct.
Ching-Ho Cheng
Ching-Ho Cheng
Ok, found the drain, but how do you fill it back up in the 98? I read that you posted that the 2000 that the differential was drained and filled via the transmission. I did not attempt to drain the differential yet.
Yes, it is filled via the tranny. Just remember how much of the differential fluid coming out on top of the tranny fluid. You add back the total amount of tranny + differential fluid.
Ching-Ho Cheng
Ching-Ho Cheng
