1995 ES300: general advice on buying
I found a ES300 that has a hundred and eighty-two thousand miles on it it is in great shape body wise interior is clean and the only concerns I guess I have are the engine and the transmission. My question to you guys are what do I need to look for as far as repairs go generally?
You need to know if the water pump and timing belt were replaced at 180k, if not you need to do it asap. They are duie at 180k and it's a major interference motor so you can't put it off. You also need to know if the oil changes have been kept up on a regular basis as this is a known sludge motor, extended periods between oil changes can be a redlight. A quick visual check with a flashlight can tell you much as well since this engine is a notorious valve cover leaker. When properly maintained this engine is reliable, smooth and powerful. A lack of maintenance makes it a ticking time bomb.
The engine in a '95 is NON interference and is not susceptible to sludge.
osfan8228
02-14-16 07:10 AM
