spacer for my wheel...
![Smile](https://www.clublexus.com/forums/images/icons/icon7.gif)
Hi./.. I had SSR 225/40 ZR18... on my 98' ES300.. and I had 1.0 drop with H&R...now I just brought some spacer to make my wheel look wilder... I got 7.5mm and waiting to put it on.... does anyone have ever use spacer on their car??? how does it feel... or does it really make a difference.??? or will it fit on my car????
Lexus Connoisseur
I'm not a fan of wheel spacers. They are more danger than good. Beware because when you add wheel spacers, you ultimately shorten the length of your wheel studs. The less area there is to hold for your wheel nuts will only cause extra stress on the studs...and possibly cause your wheel to fall off in some cases.
Lexus Connoisseur
Originally posted by George Hsieh
but I did order longer wheel studs... for my spacer.... but just that I don't like the way my wheel didn't line up with the body itself.....
Lexus Connoisseur
can you please explain more about " I can no longer rotate your tires." ?? thankz
