2000 ES300 Knock Sensors Replaced, Running Rough, Multiple Codes, Troubleshooting
I usually have the lights set to auto, but I did turn it to the ON position to check the rear lights, and they all seem to be working? The wiring harness in the trunk looks in good shape. Is the high tail light constant with the lights in the ON position, or does the brake need to be applied for it to light up? Thx, T
These are a couple Pics with lights in the ON position. The sun was starting to come up when I took these, so I hope they are visable enough to make it out. T
Thx again guys for all the help with this. T
My '02 had the light out indicator and it was the high brake light. Seems once you hit the brake and it doesn't light up, it sets it as bad from that point on whether you are hitting the brake or not.
JazzyQuinn
17
10-31-14 08:00 PM
