please helpe me
hi..please help me
I have a problem in the car and gives an alert warning is often the warning ( Alarm is Flasher Lamps with Horn )
So How to Disable a Car Alarm
my car .. lexus es 300 -2002
Forum Administrator
![](https://www.clublexus.com/forums/images/ranks/rank-admin2.gif)
You should use your key to unlock the car to disable the car alarm. Do you have a key with a transponder in it?
Is this your car or one you're trying to steal (only partially in jest, your post sounds suspicious)? Is there a Lexus dealer in Saudi Arabia you frequent?
Yes, I use the key with the remote This problem occurs in the new cars from Lexus and why sensitive safety who fumbles anything inside the car
Forum Administrator
Not sure I understand what you're saying/asking? Are you talking about a 2002 ES compared to new Lexus models with keyless fobs?
yes i have 200 es but..
I want to cancel the existing alarm in the car because he is annoying and appears in embarrassing times when the car is parked at work.. like this
I'm totally confused. You first state you have an '02 ES300 - the video is obviously a much later model. What is causing the alarm to go off? You have to really bump it for the motion detector to go off.
Just a note. This did not work in my 99. My alarm kept going off and my friend thought he could disable it by removing the horn fuse. All it did was make a different more scary sound lol. Then my horn didn't work at all afterwards and I had to buy a new one. So be careful removing the larger fuses.
Disconnect the horns when not driving it, until you sort it out. There are most always plugs at the horn itself that is where to disconnect them. Fuses usually power more than just a horn or what ever.
The usual reason for alarms to go off is a bad switch for a door, or motion sensor if the car has that, you need to check switches for resistance if any show resistance that is likely the problem.
TUGrad09
06-25-12 01:08 AM
