1st Lexus 05 ES330
So I just bought a 2005 Lexus ES 330 with 51,500 miles. Super clean on the inside and engine, but it has a salvaged title due to hail damage, which doesn't bother me too much. 1st owner put on 22k miles in 7 years and had all service at the dealer. 2nd owner put on 23k miles from 2012-2015 and then it got totaled due to hail. This forum already helped me fix the rear window. Haven't got the homelink to work yet, pretty sure I need to reprogram the opener, remotes and homelink altogether.
Only bummer other than hail is only 1 key and no manual. What should I know about upcoming service? Anything in the 50-60k mile range that is important? When is the timing belt/water pump usually done? I only drive like 300 miles per month so it may take awhile.
It replaced a 01 Pontiac Grand Prix that had 171k miles and was falling apart and hadn't been fun to drive in 5+ years.
Bought an 05 last year and love it
Join Drive Lexus it's free. You can see all your service records and maintain schedule.
https://secure.drivers.lexus.com/lexusdrivers/home.do
Timing belt is generally done after 7 years or 90K miles. Since rubber deteriorates with time, your belt is overdue. The water-pump is another story...since yours has such low miles, I'd give it a good inspection before replacing it.
Get those headlights buffed and clear coated! I had mine wrapped in vinyl, it will definitely stop the haze from coming back in a few months.
Did you get a master key or a valet key?
If you got a master key, you can buy spare keys off ebay and program them yourself if you get a Techstream cable.
jdog0411
13
02-03-11 10:00 PM
gaplee
09-26-10 12:08 PM
