97 es300 oil warning sensor...
Old 09-02-16, 10:48 AM
1997es300
1997es300's Avatar
Default 97 es300 oil warning sensor...
when the oil sensor light is on it does not allow the car to start. The battery is obviously fine because everything else works but the sensor will not allow the starter to even attempt to turn over. Eventually after anywhere between 45mins and 8 hours later, the starter will finally turn over and start the car. This has happened 4 times now leaving me stranded. Is there any way i can disconnect this sensor? Every time it happens I make sure the oil level is correct
DLfpv
06-25-19 11:21 PM
Beermunder
12-18-17 10:34 PM
xenonrider
01-01-10 03:29 PM
O. L. T.
Performance & Maintenance
10-31-09 07:17 PM
Quick Reply: 97 es300 oil warning sensor...
