HELP!!! How Do I Add A Distributor Kill Switch To My '05 ES330?
My car was recently stolen (recovered after 3 week but EVERYTHING inside is gone). To deter that from happening again, I want to add a distributor kill switch (once had one on my old 72 Mustang), but don't know how to do it, as it is a lot different than adding a switch to the ignition coil of the Mustang.
Eventually I also plan to hardwire a hidden tracking device, so that IF it gets stolen, I can track it down, and with the help of my friend Arturo Rodriguez - Quince, "convince" the ne'er do wells to return my belongings, but that is for another thread.
Did they strip out the interior pieces or just took your belongings?
You'd have to add a kill switch to your fuel pump, which is located under the rear seat. These cars don't have distributers, and you don't want to be tampering with your ignition coil wiring.
Ironically though, the engine immobilizer does just that - disable the fuel pump and ignition. Did they start it and drive it away with a pre-programmed key?
They just stole/discarded all of our belongings.
Any idea how to add one to the fuel pump? The car was stolen from my garage overnight/early morning. The valet key was inside the unlocked car (sunglasses holder). Walked out into the garage, the door was up and the car was gone.
I'm no engineer but I think it could be as easy as throwing a switch that (dis)connects the 12V going to the fuel pump. There should be a harness under your backseats that plug into a gray circle, you just splice the switch into the wire that pushes 12V when the car starts, and tuck the switch somewhere sneaky.
DON'T TAKE MY WORD FOR IT. I AM BUT A MEAGER COLLEGE STUDENT.
Also, keeping keys outside of the car and then locking the car is an easier method.
Do you also lock your bedroom doors in your house before you leave? Do you lock up/away your laptops/electronic equipment/jewlrey/valuables before you leave, or before you go to bed @ night? I have yet to meet someone that locks their car when it is parked inside of their own garage. Do you???
Instead of being critical how about offering a real solution to my question.
According to both my daughter and my neighbor directly across the street, the door was closed. The insurance investigator told me that all the thieves needed to do to get into the garage was pop the manual lift switch with a coat hanger and then lift the door. How would locking my garage door help me when I drive to work, or just out and about anywhere?
If someone use a coat hanger to unlock the locked door, the car alarm will sound. And when it does, it will wake up people inside the house.
Your story isn't adding up.
![](https://cimg3.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/20160911_181705_6ab510ccdcf7bdafa58b008f5bbf8d5d8e510e1b.jpg)
Per the insurance investigator, the garage door was probably opened by using a coat hanger to pull the switch to manually lift it (see included picture). And as the car was in the garage, it was unlocked.
Instead of being so defensive I would just read what everyone is trying to tell you, sleep on it for a couple days, and actually think about what went wrong here.
You left your keys inside your car and that is where you messed up, learn from your mistakes and move on.
I understand you are mad that your car was stolen and possessions were stolen but everyone here is just trying to help, some being sarcastic / *******s, but its the truth.
But all of the other stuff isn't answering my questions. What is the point of all the other talk??? Am I being defensive, I don't think so. I asked questions, and with the exception of 3 people, everyone wanted to state what they feel is the obvious solution, while ignoring the fact that it may be useful to others to prevent similar from happening to them.
If thieves are smart enough to get around the engine immobilizer (built into the ECU) then a simple kill switch is unlikely to stop them. Maybe you're not aware but without the correct programmed key sending a transponder signal to the computer the car will not start.
