1999 ES300 with P1133 even with new A/F sensor
10th Gear
Hi everyone,
I'm at my wits' end about troubleshooting my 99 ES300. A few weeks ago it threw these codes:
P1354 VVT System Malfunction (Bank 2)
P1133 Air/Fuel Ratio Sensor Circuit Response Malfunction (Bank 1 Sensor 1)
I replaced the Oil Control Valve and the first error disappeared. Later, I've also replaced the Oxygen sensor (by the firewall), but the P1133 keeps coming back every 20-30 miles after I clear it.
I've checked for vacuum leaks and cleaned/bent contacts in the oxygen sensor receptacle, but the error still comes back.
Anything else I can try?
The engine seems to run ok, although acceleration might be a little slow at times.
Also, I've found that it could be "Fuel Pump, injector or pressure regulator fault" - how do I check for that?
Thanks!
Thanks!
ayroman
12
12-04-23 03:00 PM
