any one know how to clean the front lights
i was just wondering if there was something to use to get the front head lights to get shiny and clean. because even when i wash the car the lights still look dirty.
thanks
thanks
Well it all depends on where the grime is. If its inside the lense, then you will have to take apart the headlights. And clean inside. First find out if the dirt is inside or outside. I recommend using this stuff called GOOF OFF. They sell it at Walmart and it takes just about anything off. Try it out. If that doesnt work, try using a buffer at low speed......
there's been a few different people that say things on how to remove some of the grime on the outside. some people have found that applying wax on the outside of the headlights and basically just waxing the housing cleans off some grime and makes it shine more.
i personally got new housings after an accident, but getting new headlights without other people paying for it means that you'd have to throw out a bit of money.
kevin
kevin
