Potentially dumb Q-- anyone regret new struts?
1997 ES300
I have most of the pieces to update my front end (the affordable ones anyways), excluding control arms, struts and springs. I already put new ball joints in the existing arms.
I have $400 worth of KYB struts and KYB mounts in my Amazon shopping cart and I'm *this* close to pulling the trigger.
Does anyone regret doing struts on their 15+ year old car? Also, how are KYB struts? I hear 'they are great!' 'Use OEM!' back and forth.
If they haven't been replaced of late, then yes replacing suspension components that have been in use for that duration of time would be a vast improvement ![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
KYB is a preferred brand as a NON GEN option
I myself when the time comes will be replacing the front and rear struts with GENUINE ones on my early model ES300 (much more pricey
) Main reason for doing so is I want to keep the vehicle as stock as possible with as many genuine replacement parts as I can. Otherwise I would be using KYB
![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
![Woohoo](https://www.clublexus.com/forums/images/smilies/woohoo.gif)
Ive heard the KYB are super stiff, almost like track car, performance types... So I dont know which I want. Quick-Strut, OESpectrum, or the Excel-G.. Reviews here are wildly inconsistent. Some are junk, some are great...
And unfortunately, the whole right side is show. I hear clunks at low speed turns and there is a rattle.. Im hoping the rattle can be resolved with new lower or upper insulators.
Sure. If you like replacing more often, Quick-Strut is what you want. Excel-G is stiff for some time but after they ease up, they are fine. Usually discussions are lengthy on Monroe vs KYB. Lots of people like Monroe for less stiffness but do not last long. Where available, additional assemblies of name brand are KYB Strut Plus, Moog, and Detroit Axle.
To date, I have tried KYB Strut Plus ONCE, never again (bad mounts). Always used individual KYB struts with OEM components in every other vehicle we owned/own.
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
Howcome new mounts? Are you not able to reuse the current oem mounts? Of course I live in SoCal so I do not have rust or salt problem. Just wondering. If your mounts are not rusted or have some other issue, normally reuse. Our corolla mount had bearing in it. Our avalon and camry have separate mount and bearing. Etc. I usually check out the broken parts (bearing, boot, bumper) and order in advance. Thats about it.
Yeah I guess that works. Usually when you order online, you can return unused part with restocking fee. The clunk might be outer tie rod end, ball joint, cv joint, mount, or another loose part. Normally if CV goes bad, on turning it is a click-click.
1997 ES300
I know the main topic is KYB's, but has anyone tried Gabriel's? debating to lower the car with lowering springs but if i go that route I've noticed that they have roughly a longer 2in travel and also roughly about 1.5in shorter than KYB, Monroe & Excel-G. anyone have input or info about Gabriel's?
Another Q, what are the strut bumper? Is that OEM only or should they be picked up? Item #13
http://www.partswebsite.com/oemlexus...magecallout=13
This is what I priced out, price includes boots, insulator if necessary.
OEM struts & mounts: 500
KYB Struts & mounts: 320 (390 with OEM mounts)
Monroe Quick-Strut: 250
Monroe OE Spectrum and KYB mounts: 270 (340 with OEM mounts)
I dont think its worth getting the KYB mounts even though they are about $70 cheaper total for pair.
Im gonna sleep on it and make a choice. I plan to use the car for 2 years so quick-strut MAY work. Monroe OESpectrum could be a good compromise. but KYB seems most ideal.
