Need help finding O2 Sensor Part no.
I have a 'P0135: Heated Oxygen Sensor Heater Circuit Malfunction' error code
What is the part number for Bank 1 Sensor 1?
Lexus Parts isnt too helpful and doesnt reference the sensors as 'bank 1 sensor 1'
Is this the part?
http://www.lexuspartsnow.com/parts/lexus-sensor-air-fuel-ratio~89467-41020.html?Make=Lexus&Model=ES300&Year=1997&Submodel=&Filter=(d=USA;0=MCV20L-BTPGKA)&Location=switch-relay-computer,,89467B
Is this the part?
Your link did not work for me.
Do you have a California spec 1997 ES300? If so you will need Air/Fuel ratio sensor, It's listed as rear.
However if you need an oxygen sensor I would recommend Denso for the Oxygen sensor Part #: 234-4622 . Because it will be just as good quality and less expensive, $49 at Amazon. Desno is the OEM for these sensors. Denso did not have A/F sensors listed on its site for 1997.
Go here http://densoautoparts.com/find-my-pa...icle-selection to double check.
Lexus Part No.: 89467-41020
SENSOR, AIR FUEL RATIO
If you have a non-California spec 1997 ES300 you will need an Oxygen sensor.
Lexus Part No.: 89465-33180
SENSOR, OXYGEN
SENSOR, OXYGEN
ayroman
12
12-04-23 03:00 PM
LexusOwn15
04-10-21 02:27 AM
Dan040286
ES - 5th Gen (2007-2012)
08-17-19 03:32 PM
techiedude
05-02-12 06:57 PM
