2000 es300 trac light on, check engine light on, transmission gear indicator malfu
Lexus 2000 es300 trac light on, check engine light on, transmission gear indicator on dash malfuctioning. Those are the symptoms I am experiencing. The transmission indicator light just goes randomly into reverse but the car is in drive. Traction control light and check engine light are on; on the dash board. Car was taken to a mechanic and they said the problem was a "switch" that seem to be located under a black cover/box, under/near the front bumper. This is my moms car are the dealer said the part costs $500. She can't afford a $500 part so I am here to verify everything, to see if this is really a $500 part, and can it be fixed cheaper. Thanks for all your help....
mervin
10-20-08 11:23 AM
