4ES Radiator Replacement
Hey everyone, my 2002 ES with 254k miles has sprung a leak in the radiator where the plastic tank meets the core. I'm looking at radiators but it appears there are two types, one with tow package and without. I used my VIN number on LexusPartsNow.com but it didn't help narrow it down. I imagine my car does not have the tow package, cause it clearly does not have a tow hitch. Is there any other way to identify if my car is so equipped?
I'm thinking about ordering the non-tow package Denso 221-0503, cause I'm assuming that's a safer bet. Anyone else been in this situation?
If the mark has not worn off look by the upper rad hose you should see:
0A24 - tow package
2027 - standard
On Rockauto the Denso rad with tow package is actually cheaper.
0A24 - tow package
2027 - standard
Ok, thanks for that! I will go take a look in a little bit to see if the marking is still there.
My non-tow package radiator has already shipped from Amazon, so here's my question...is the only difference between the two radiators their cooling capacity? If so, I imagine it shouldn't be a huge deal if my current radiator is tow package and I replace with the standard? Or are there extra connections on the tow package radiator?
Yeah, I saw RockAuto was cheaper; unfortunately, I need it ASAP and since I have Prime it'll be here tomorrow.
Fingers crossed I have the standard one!
Measured
07-14-13 10:45 PM
