Stalls when turning steering wheel to lock?
Old 01-18-17, 07:39 PM
stevesturm
stevesturm's Avatar
Default Stalls when turning steering wheel to lock?
Sometimes, the car stalls when the wheel is turned to full lock, like when I'm turning into a parking space.
Ideas as as to why?
Old 01-18-17, 08:12 PM
Received 2,907 Likes on 2,452 Posts
First thought is a dirty idle air control valve. How is the power steering fluid level? Try and avoid turning the wheel completely to lock it puts a much greater load on the power steering pump.
Old 01-18-17, 11:42 PM
ES300NZ
ES300NZ's Avatar
I'm thinking low idle. or low power at idle.
some common causes
- bad / worn spark plugs
- low fuel pressure
- air filter clogged
- vaccum leak
- timing out / incorrectly installed timing belt (off say off one tooth in either direction).
- worn out engine accessory (bad bearings in alternator, worn out p/s pump, or AC pump).
Lexterious
11-27-16 12:45 AM
TMaxxTim
02-09-15 08:16 AM
shaft1
12-14-14 07:15 PM
340massive
01-06-14 06:25 AM
fisher9720
07-20-10 06:41 AM
Quick Reply: Stalls when turning steering wheel to lock?
