Coilpack arcing?
I have a question about installing the coil packs.
I have only used spark plug wires on a distributor which "snap" onto the plug. It seems like my coil pack just sits over the top, also it sounds to me like it could be arcing above the spark plug,is this normal?
My question is, how should these seat against the spark plugs?
None of my coils ever snapped into place. The arcing could just be valve tapping, just curious since I couldn't find anything on the forums about this.
1999 Gold/silver ES300 1MZ-FE with about 180 miles on the clock
If the coils are leaking electricity the engine will have a misfire/run poorly and likely throw code(s). Are the coils original? Not sure if they "snap" into place don't remember.
Thanks for the quick reply. So they wont clip over the plug ends? I am getting an intermittent misfire, but that is usually just after its warmed up. looking at the forum its possibly the oct? Anything else i should check?
2GSTony
12-12-14 11:46 AM
rockyvo09
10-21-14 08:04 AM
mzeitlin
02-17-08 05:20 PM
