aftermarket vacuum surge tank
I'm having trouble locating an aftermarket solution for a small piece of plastic that sits in between the egr valve vacuum line called the "vacuum surge tank", similar to the one shown in this post
https://www.clublexus.com/forums/rx-...it-is-not.html
Toyota and Lexus want over $50 part and have had no luck finding it online due to frustration of failing California visual smog inspection. If anybody would be so kind to provide a link to a reputable source, it would be greatly appreciated.
have you tried bypassing it with a straight piece of hose?
I also had no luck in locating an aftermarket one and had to get one from the dealer but I don't believe it was 50 bucks I think around $30.
I did look at the old one that crumbled and honestly it doesn't look like it does anything special. you might be able to get away with a straight hose.
mak89
Performance & Maintenance
04-25-19 04:10 AM
