Car Alarm Goin Crazy!
My car alarn goes crazy for no reason! Does this sound familar to anyone? I had to take out the fuse to the horn and hazard lights (only cuz I couldn't take out the one directly to the horn b/c it was too hard to take out ) because it gets so annoying.
Sound like your car is wrecked on the left side or something. Just my guess from all the problems you got wiht alarm going crazy, wind noise, ABS and battery drain after a few days. May be the door actuator connector in the driver door or passenger door is broke, the window is not properly adjust(for the wind noise). Good luck!
I have the same exact problem!!!!!! It will go off for hours at a time in the middle of the night keeping the whole neighborhood up!! All i can figure out to do is take out the fuse for the horn so at least its quiet. If anyone has a solution that would help alot! trust us it sucks!
Check
check your connections and grounds!! or maybe the sensativity is just to high. One more thing, the brain could just be malfuntioning and in that case you would be S.O.L!!
volt
get a volt tester and get the wiring diagram for your es (remember to get the diagram for the alarm, not radio etc...). Most of the wires will be in the dr. side kick panel and by the fuse box. The wires are easy to locate with the diagram (hope your not color blind). I would post the diagram if I could find it, but no luck. It doesn't matter though, I sure you can find it on the net. Even if you don't solve the problem you will know how to put an alarm on the es
memoalkati
03-24-18 09:54 AM
MartijnAms
12-09-14 06:45 PM
dbs600
01-31-14 09:00 AM
