?transmission issue
Old 03-16-17, 03:10 PM
nbodycote
nbodycote's Avatar
Default ?transmission issue
ES 330 2004, has 142,000 miles. It is bucking now and then when accelerating. Could this be my transmission?
Old 03-16-17, 05:26 PM
tomf
tomf's Avatar
Is your check engine light on? If so what are the codes? When was the last time you changed your spark plugs?
Old 03-17-17, 12:11 AM
ES300NZ
ES300NZ's Avatar
I seriously doubt it's the transmission. Bucking is usually,
  • a bad spark plug, or six.
  • timing belt failure, slippage (tooth hop), or a timing issue
  • serious vacuum leak.
  • a bad maf / afm.
  • fuel pump issues / blocked filter, low output.
Old 03-19-17, 09:21 AM
01LEXPL
01LEXPL's Avatar
^ *VVTI solenoid/oil control valve as well
Remotecont
RX - 3rd Gen (2010-2015)
12-20-18 07:37 AM
Mohammfa
ES - 6th Gen (2013-2018)
09-10-18 01:35 PM
sxwk12
10-10-17 08:30 PM
red93sc
SC- 1st Gen (1992-2000)
31
01-27-15 06:43 PM
tarzan17
RX - 1st Gen (1999-2003)
23
03-01-13 08:24 AM
Quick Reply: ?transmission issue
