1996 Lexus es300 - cylinder 5 misfire
Old 03-19-17, 05:56 PM
surfing
surfing's Avatar
Default 1996 Lexus es300 - cylinder 5 misfire
I have a 1996 Lexus es300. The check engine light came on and the code reads 'P0305 indicates that Cylinder 5 had too many misfires within a predetermined period of time'. I replaced all 6 spark plugs, changed the 3 plug wires, and checked that the ignition coils met the test specifications. The car still seems to be misfiring. Any ideas why?
Old 03-19-17, 06:22 PM
crwys
crwys's Avatar
https://www.engine-codes.com/p0305_lexus.html
Have you swapped the ignition coils to make sure it wasn't a bad ignition coil?
Old 03-19-17, 07:04 PM
Received 3,030 Likes on 2,545 Posts
If you don't get anywhere swapping coils do a balance test by disconnecting the injector connector on the suspect cylinder. Does the engine idle smoothly or does it sound like there is a miss? Listen closely at the tail pipe.
Old 03-20-17, 07:01 PM
surfing
surfing's Avatar
The problem appears to be fuel injector 5. Thanks for the replies.
CrystalC
04-04-18 02:36 AM
NikS
03-09-18 09:02 PM
Billiamch
04-11-16 01:31 PM
Rollin'ES3
13
03-18-09 08:52 PM
Ariyanna
12-01-07 11:57 PM
Quick Reply: 1996 Lexus es300 - cylinder 5 misfire
