Radiator fan does not work
Both of my fans stopped working and the heat blew both my top and bottom radiator coolant hoses. The hoses were easy to replace but after testing both fans my driver side fan worked, only when I bypassed the OEM connection. the passenger fan assy does not work at all.
My question is what could be the problem with the connection of the driver side fan and how in the hell do I order a passenger side fan? I noticed its a different size fan housing than the driver side fan and when I look up the fan assy online I get mixed results.
Any help would be great guys, thanks.
If the fans work when you apply voltage directly, I would suspect a bad thermo fan switch. It's located at the bottom passenger side of the radiator (19mm socket to get it out). It has a detachable harness that snakes all the way across the bottom of the radiator and up the driver's side...you will see two connections mounted on the radiator driver side: one is for the driver side fan, the other is for the thermo fan switch.
The switch is normally-closed, and opens when the coolant temp is high enough. As such, you can test if it's working by disconnecting it: if the fans go on, you have a bad switch. If they don't, bad fans or power delivery problem.
pyr8
12-08-17 05:13 PM
