Fuel regulator Lexus es300
Hello
I want to replace fuel regulator for Lexus es300 model 2000 but I don't know where it's located
Does any body know?
In tank or near the engine
It's good if you have a picture
Note. Some body told me it come with fuel pump but not sure
Does any body know?
It's in the tank. with the fuel pump. it's a returnless system.
why, .. why do you want to do this ? I've very unlikely to have failed, the only reason you'd need to go near it is if the engine needs a higher fuel pressure than the 43.5 psi it's set as at factory. did you turbo it or something ? does it need rising rate now ?
No. I don't want to change its position. I mean I want to replace the fuel regulator itself. Because I have a problem with the old one.
Does anybody have a picture of it?
I have no power going to my relay box under the hood that contains the starter relay that EFI for horn relay as another relay in there I'm not too sure what do I do to get power back to that box
The only thing I can think of is one of the Main 50A and above fuse is blown, check ALL the Bigger fuses you can find.
Hope this helps and best of luck!
DGIKULJOT
08-16-12 11:13 AM
mcelligott
05-16-05 02:52 PM
