The other day I noticed the smell of fuel from within the engine bay and decided to take a look. I noticed that there is a fuel line coming off of the fuel pressure pulsation damper that runs to the charcoal canister area; this is where the leak is at, where the green plastic clip connects at. I'm having a hard time getting a part number for the fuel line and the plastic clip so I can do a replacement. I'm hoping that this is also what is throwing a code . Any help is appreciated !
I recently purchased a 2000 es300, just like yours. I need to get your help in identifying one part and understanding its function. Please see the image. What I want to know is the item inside the yellow circle.
is it a remains of broken item ?
My questions are in the image itself.
Red circle is a vacuum port, the yellow not sure it's hard to see in the picture. My ES is out of town right now I can look at it when it gets back, or someone else can look for you.
Thank you,
I will try to get you a more clear picture. When you get your car back, please check that vacuum connection.
Where it goes and is there anything in between that vacuum port in red circle and the other end of the vacuum line.
