'95 ES 300 engine coolant temperature sensor
Depends which one you want, 1 pin is for the instrument cluster 2 pin for the engine computer.
That could be a bad ECU temp sensor (2 pin) for example Beck/Arnley 1580421
I am not actually endorsing any of those brands, not because they are necessarily bad (they could be) but because I have not used those specific parts. Beck/Arnley generally doesn't make anything they rebox stuff from other suppliers. Sometimes that means you get OEM parts in a different box.
I don't think the sensor is hard to change, can't remember specifically. Remove the connector and check it along with the wiring before you replace the sensor problem could be frayed/damages wiring.
Rokas
07-04-17 04:29 AM
Rokas
06-25-17 06:15 AM
