Finally clearing my corners!!
After months of looking at other people's experiences with clearing their turn signals, I've decided that I can't let the Lexus emblem intimidate me, it's a car and therefore can be worked on...thanks to the many that have posted detailed instructions on this site with pictures, I can say that I should be able to pull this off with relative ease given how much advice this site has
i hope i don't end up cracking or melting something...i'm gonna post before and after pictures soon...
since i'm opening up the lens, i'm gonna clean it with meguiar's plastic cleaner and follow it with the polish...does anyone have any thoughts on something that should precede this for non-fine scratches, as I seem to have quite a few of those...sanding perhaps?
oh yeah, i've been looking for anyone that took pictures when they cleared their taillights, as in a step by step kind of thing, haven't found anything...help anyone? and from what I recall, these cleared taillights don't really look cleared, in comparison to the newer ESs, was that perhaps just the picture i saw or is there a general agreement about this?
Get a tube of windshield silicone from your local auto parts store. I put a thick line of it on the points where the 2 parts of the headlight meet, all the way around the light when i take mine apart. While you're clearing the corners, windex the inner side of the plastic lens -- youll probably notice a difference while driving at night.
thanks mcelligott, i got my driver side headlight done...took like 4 1/2 hours but only because i didn't want to break anything...anyhow i'm loving the look! any suggestions for a white bulb in place of the amber? oh yeah i used plastic cleaner and polish on the inside of the lens, it's looking good...when i was sealing the light back the two ends didn't meet as close as they originally were, i guess this is just a question of reheating repeatedly and pushing the ends together right...
yup turns out it isn't legal to have white bulbs...i could just take a risk, or leave it as amber, clears would look so much better though...sigh...
thanks for your help!!
thanks to everyone that contributed to this post, as well as those people that tried these things out with their cars and helped create proper tutorials for others to follow!!
Those look very nice!
I want to clear mine, it is just a matter of finding the time. Besides mine are so dirty and grimy I really want to clean them up inside and out. Yours look brand new!
Great job!
badams
Great job!
badams
fog80, to get the assembly out of the car, you first have to pop a bunch of those plastic screw-type things, that hold a long black piece of plastic down over the radiator and headlights. Once that plastic piece is off, there are three bolts per headlight. If you bend down and face the headlight, you will two bolts (on the right of the headlight if it's the left headlight you're taking out, and vice versa) after those two bolts, stand up and find a bolt connected to the frame of the car. This bolt will have a black plastic joint that is directly connected to the headlight. Getting these three bolts out will allow the headlights to be removed, but before you do that, make sure the high and low beam cables are disconnected from the light. Pull the headlight out, but not too fast, 'cause you still have to take the turn signal cable off, you'll be able to do this once the headlight is out a few inches. Disconnect that cable and you're ready to put it in the oven!
