99 ES300 codes p1760 0753 0758 along w/ 0330 and 0325
I don't have the right bolt to ground into the correct spot, I pulled my ground cable to the spot on the side of the engine where the other ground point is. No luck for me so far. Still the same error.
Also, it doesn't look like I'll be able to ground at the proper location, the power steering lines are blocking access.
