What causes filling problem at gas pump
Old 09-14-17, 06:35 AM
way2lo
way2lo's Avatar
Default What causes filling problem at gas pump
2001 es300....I have to allow the gas to enter the tube slowly or it shuts the pump off. However if I rotate the nozzle 90 degrees it works.
Old 09-14-17, 07:07 AM
Dave Mac
Dave Mac's Avatar
That's interesting. I usually buy gas at Costco where they have an attendant to monitor the pumps and he has become quite an expert on such problems. He gave me the same advice about inserting the nozzle at "3:00 o'clock" to prevent early shut off on a Denali and it works. He said there were other car that required the same positioning. Just recently all the pump nozzles were changed and I wonder if that has changed things. It has something to do with the auto shutoff and the fuel venting of course - and apparently the temperature.
Dave Mac
Old 09-14-17, 08:10 AM
ArmyofOne
Dysfunctional Veteran
ArmyofOne's Avatar
is it consistent no matter which station you fill at? if so I would say its a car issue, not a pump issue.
Old 09-14-17, 10:31 AM
nsghtbrwry
nsghtbrwry's Avatar
Dave Mac
Cool, I had this problem on an '01 DeVille and an '02 Sienna at Costco - nearly the same fix, was 1 o'clock for me. Dunno if the AZ nozzles are the same as CA (doubtful, thanks CARB), but I started having more problems when they switched to the nozzles with less articulation where the head connects to the hose. Also, the newer ones with a compression nut holding the head to the hose can leak/spray gas when you twist them.
Old 09-16-17, 04:09 AM
way2lo
way2lo's Avatar
Problem is consistent regardless of gas station...
Old 09-16-17, 07:02 AM
way2lo
way2lo's Avatar
I found this...I assume the fix is probably the same for my es300.
kenjh
03-20-17 04:09 PM
mstrsltr
GX - 1st Gen (2003-2009)
19
01-23-17 11:55 AM
Negrodamus
01-17-14 12:36 PM
YWW
08-30-10 07:46 PM
fju2112
01-24-08 04:46 PM
Quick Reply: What causes filling problem at gas pump
