1996 Lexus Es300 does not strat..engine cranks no start, Please help !!!
Hello all good people,
i am a student, I got this car from a backyard. 1996 Lexus Es300. Front driver side window does not open. Other than that engine light comes on after driving for some time. turning a/c on and pushing the accelerator hard. Okey so that was the condition i got the car. I drove it to my home 40kms.. drove it around couple of times ..no problems. it had no fuel by then.
Next thing, Car trying to start it feels engine, Turing on then immediately shuts off. i thought maybe it just ran our of fuel. to test i put about 4L of petrol in. Car started right away then for one time.
Next day i went , this time the car u can only hear engine cranking, no start..... one observation : i tired 3-4 times with turning key, if i keep holding on ..the car vibrates nd gives the sound you get when engine starts but this is for one sec only,, and again back to where it was... engine only cranking. the radio cuts power when starting btw.
What things should i try to get an idea ..whats wrong with the car ? fuel pump, sparks etc. Looked in few forums ,,from my search i found this one as such my first post here ...
Greetings from a humble person
Thanks !! Please help
For anyone seeing this : I had a bad battery, had to change battery with 600CCA, Car working good now. thanks all
From what you wrote I'm guessing the car was in a backyard and not run for an unspecified period of time. If that is true what was the state of the car beforehand? There could be multiple old problems and new problems with a car that was not properly stored. Not knowing your abilities do you have a friend with any experience working on cars that help you?
Shin (10-29-17)
Hello Sir, thanks a lot for your reply. yes it was in a backyard means they kept it without using. front driver window not working.other power windows working.
here is the situation --------
So i test drive it, all ok Drove it home 40kms..
only engine light came on after some driving/ turning A/C on, goes away after shut down engine. i wanted to do servicing on it altogether since i have got the car recently for the engine light maybe sensor issue or so i thought . it had no fuel then ..fuel light was on.
Next thing is it worked fine for few days... i drove it short distances.
It didn't start you could feel the engine crank and starting up 2 sec then gone. i thought no fuel at all. so i put 4L of fuel only just to test. It started at one go .
after that one time, it is not starting .no fuel light. radio cuts off power as it should. now it cranks only does not start like before.. if i turn the key few times. hold it long enough .. i could feel the engine starting just for 1 sec. For diagnosis, yes i have cousin who does not know these things but we could work on it ... look into simple things
Actually wanted to know why this happens, should i test again after putting more fuel in ? I am thinking to get an OBD2 scanner to read codes,,, will that help in this situation? since the car does not start now
Shin (10-29-17)
low fuel light indicator off... alright sir thanks, i shall put more fuel and check , let you know
Hopefully this helps you.
Shin (10-29-17)
I got a 92 es300 that would run for a few seconds and then die too. I figured out that it was the Mass Air flow sensor keeping the fuel pump from working. The fuel pump is wired so that when the starter is being used it's powered from that, but then once the car is running it switches over to the fuel pump switch in the MAF sensor.
A bad MAF can effect the engine because it will be unable to correctly measure the air fuel ratio, and cause your car to not start or exhibit other unusual symptoms.
This is not correct:
"The fuel pump is wired so that when the starter is being used it's powered from that, but then once the car is running it switches over to the fuel pump switch in the MAF sensor".
Shin (10-30-17)
Yes it is correct, YOU are wrong this is exactly how it works on a 1992-1993 ES. On a 1994+ ES it effectively functions the same way although uses different inputs to decide when the fuel pump runs.
apoxc69
12-13-11 05:46 PM
triplecore
09-22-06 08:52 AM
