2006 Es330 gas pedal issue
This has happened several times since I bought the car in October. I will be coming up to a light and it will turn yellow so i go to speed up and the gas pedal does nothing. If I take my foot off of it and push it again its fine. Has this happened to anybody else? If so, how did you solve the problem?
I don't think Lexus engineers designed gas pedal to do nothing when owner needs to speed up. You should check Air filters, Gas sensors (need machines to check them, mechanic charges around $40-$50 to check if all sensors OK or not). And be sure nothing is underneath your pedal like mud mat moved up while you driving and block the pedal. And also use Premium gas ( 91-93) .Good luck.
D2006
D2006
