thermostat
Old 02-06-18, 10:07 AM
hazmatkid8
hazmatkid8's Avatar
Default thermostat
2003 lexus es 300 thermostat location
Old 02-06-18, 10:40 AM
seanddd
seanddd's Avatar
Driver side of the engine. Need to remove air filter box, throttle body and battery. Get 1-gal SLL 50/50 mix ready.
Old 02-06-18, 11:28 AM
Received 2,932 Likes on 2,469 Posts
Old 02-06-18, 12:28 PM
hazmatkid8
hazmatkid8's Avatar
Default Thanks
So its take air cleaner assembly an battery out the 12 mm but an 3 10mm but on the housing swap out with dot facing up refill an resemble and good to go
Old 02-07-18, 07:14 PM
speedkar9
speedkar9's Avatar
Thanks for posting my video, hope it helped.
Old 02-08-18, 07:50 AM
hazmatkid8
hazmatkid8's Avatar
is it a hard replacement just take the battery aircleaner assembly out and it the 3 bolts like in the video bout an hour or 90 min worth of work
Old 02-08-18, 01:22 PM
HomerJay
HomerJay's Avatar
You have an excellent DIY video explaining in detail the procedure. Overall not difficult, but only you know if you have the skill level to move forward.
Old 02-08-18, 01:25 PM
hazmatkid8
hazmatkid8's Avatar
I've done full suspension replacement on brand new cars rebuilt motors aint much I cant do I know it says 90 min in the book but doesn't look like 90 min
Old 02-08-18, 01:27 PM
hazmatkid8
hazmatkid8's Avatar
I put a blower an full face suspension on a 2015 ss Camaro brand new less than 60 miles with hand tools and a floor jack
Old 02-08-18, 02:04 PM
crwys
crwys's Avatar
Lol oh boy. If you have done all this other work you shouldn't have to ask for help on something as simple as a thermostat location.
Old 02-10-18, 01:04 AM
artbuc
artbuc's Avatar
Was thinking the same. Like asking where the engine is located because he wants to install a new timing belt, a job he has done many times before.
Old 04-07-18, 11:27 AM
TJEDunn
TJEDunn's Avatar
Trying to get this job done this weekend. Ran into trouble, need help. Metal pipe that connects lower radiator hose to thermostat housing. I can't get it to lock into the housing end. There is a lip to it that I assume needs some force to pop into place. But no matter how hard to work it I can't get it to lock in. Am I missing something? Try harder? Thanks
Old 04-07-18, 03:41 PM
TJEDunn
TJEDunn's Avatar
HAha.... that pipe has rubber o-ring that fell under car. Got everything together. Not a complicated diy but time consuming and a pain due to location of stat housing.
weird think is that the engine temp is still not getting up to normal. I noticed my 2003 es300 was generally running under normal temp. Then I got a p0128 code. Assumed it was stat and replaced. If code return I guess I'll have to look at the sensor. ����*♂️
Old 04-09-18, 06:34 AM
TJEDunn
TJEDunn's Avatar
Update: after driving to work today looks like I'm all good. Vehicle wasn't warming up sitting in the driveway, but a ten minute drive got it to normal temp and stayed there. I think (but not sure) part of the reason it wasn't warming up at first is that the computer was resetting the idle. Anyway. If u do this job take a drive for a while before judging the results.
Old 04-09-18, 08:26 AM
HomerJay
HomerJay's Avatar
Glad you figured it out. To avoid leaks it's best to replace the o-ring, hopefully it will not be a problem reusing the old one.
Quick Reply: thermostat
