can I use a gasket sealant on the intake manifold?
Aren't we supposed to have the pink SLL coolant? Why yours is greenish yellowish?
Generic bypass hose and screw clamps is a leak waiting to happen.
Also, when the car overheats, the coolant reservoir/tank bobbles. Some say this is a sign of a bad head gasket or blown head gasket. But, I am puzzled because there are no other signs of blown head gasket such as oil on the oil stick nor is there oil on the engine oil cap. There is NO smoke from the tail pipe, nor steam, nor water. the radiator cap has been replaced twice and the radiator has been replaced also. The thermostat is new as well.
CORRECTIONS to last post:
Also, when the car overheats, the coolant reservoir/tank bobbles. Some say this is a sign of a bad head gasket or blown head gasket. But, I am puzzled because there are no other signs of blown head gasket such as milky-like oil and water mixture on the oil stick nor is there milky-like oil and water mixture on the engine oil cap. There is NO smoke from the tail pipe, nor steam, nor water. the radiator cap has been replaced twice and the radiator has been replaced also. The thermostat is new as well.
