Start issue
Start issue
ES 300 Every now and then My Lexus will not start.. wait about 10 min and it's good. On Check Engine light. Now as I sat in the while key was of. I heard a noise or a movement control behind the dash! Turn the key and it started....But Later it didn't start again..so I open Hood and heard a click at the relay ..few min went by..and it started!! Any suggestions on was my issue
A few things to clarify;
The check engine/MIL is on when the engine is running? If yes, what is the code(s)
Are you describing a no crank or cranking without engine starting issue?
If a no crank, check the battery connections and have the battery load tested. Maybe your problem is a weak battery.
smokedawgs
RX - 1st Gen (1999-2003)
25
10-29-06 08:40 PM
