Looking for Brake Torques Specs 2002 ES300
Could anyone help me out with these specs?
I need to know the torque specs for the torque member (caliper bracket) bolts and for caliper bolts, both front and rear. It's for a 2002 ES300, I found some specs for a 2001 but nothing for a 2002. Thanks for the help...
Front:
Cylinder Mounting (bracket) should be 106.9Nm (79ft.lbs)
Disc Brake Cylinder Assembly should be 34.3Nm (25ft.lbs)
Rear:
8mm hexagon slide pin should be torqued to 39.2Nm (29ft.lbs)
These seems to be different wherever i look.
Rear:
99custom (02-25-18)
