1997-2001 ES300 Pioneer amplifier wiring and specs
I have one of these laying around so thought I'd put it on the bench and verify the basic wiring. Here's the unit in question it came standard in the 1997-2001 ES with the Pioneer head unit and changer.
click for larger image
![](https://i.imgur.com/KorelW0.jpg)
I only have a cut harness so I can't detail exact specs on all the connectors and their locations but here's the basics, I got the info from labels on the back of the amp PCB.
Pioneer GM-8066ZT
Toyota part number 86280-33080
marked 86100-33010
Front: 4ohms
Rear: 4ohms
Subwoofer: 2ohms
Grey bundle #1 audio inputs (thicker outer insulation)
ACC - red (don't know what this does)
ACC - black (don't know what this does)
white - amp positive (trigger, turns amp on)
mute - brown
FL input - blue
RL input - yellow
RR input - green
Grey bundle #2 audio inputs (thinner outer insulation)
FR input - black
white - signal ground
red - beep
Speakers
FL(+) pink
FL(-) purple
FR(+) green
FR(-) blue
RL(+) black
RL(-) yellow
RR(+) red
RR(-) white
woofer(+) light green/black
woofer(-) light green/red
Power & ground
brown - ground (heavy gauge)
blue/yellow - battery positive (heavy gauge)
grey - ACC (this doesn't seem to do anything)
The white wire in grey bundle #1 (thicker) turns on the amp this would go to the antenna or power trigger of a head unit. The amplifier has no dedicated subwoofer input so set your head unit to full range speakers. Here's the amp section from the wiring diagram it gives more detail on some of the wires.
https://i.imgur.com/OcGTXIj.png
The amp is behind the glove box.
Pioneer GM-8066ZT
marked 86100-33010
Front: 4ohms
Rear: 4ohms
Subwoofer: 2ohms
mute - brown
FL input - blue
RL input - yellow
RR input - green
FR input - black
red - beep
Speakers
FL(+) pink
FL(-) purple
FR(+) green
FR(-) blue
RL(+) black
RL(-) yellow
RR(+) red
RR(-) white
Power & ground
turtlepeas (04-26-20)
I didn't see any I'd say it's around 20 watts/channel nominal 40 watts peak.
See the two posts above yours.
jrolin1
01-21-19 11:16 AM
kalpol
13
01-07-19 06:43 PM
2Tone93
10-25-06 12:36 AM
