2002 ES300 Broken Vacuum line from Evap Service Port help...
Lexus2000,
That 3-way T junction in the center of the picture omar804 is referencing doesn’t appear to show a p/n. I’m using the vacuum page from the Lexuspartsnow site for a picture. Do you know how to retrieve it?
omar804 (11-12-19)
This
http://www.japan-parts.eu/lexus/us/2...&pa=1733020010
BTW plastic parts can be repaired using super glue and baking soda, glue the broken pieces then apply more super glue and sprinkle baking soda into the glue. Do this a few times, then reinforce with epoxy.
I read up on this idea and found that the baking soda is also an accelerant and the glue dries 5X faster which lowers clamping time for parts that are difficult to glue together and repeating layers of glue and sprinkling more baking soda at the glue point will make it stronger yet.
Bravo for the tip.
omar804 (11-14-19)
omar804 (02-15-20)
You should also check your catalyst and A/F sensor by getting a live data off of your ECU, and checking the temperature of your catalyst - it should be hotter towards the end.
Hope this helps and best of luck!
mggeisen
12-19-17 07:53 AM
