03 es300 thermostat replacement
Try this link http://www.toyotanation.com/forum/10...hermostat.html It's for a camry but same engine.
11. INSTALL THERMOSTAT
(a) Install a new gasket to the thermostat.
(b) Align the thermostat jiggle valve with the upper stud bolt,
and insert the thermostat in the water inlet housing.
HINT:
The jiggle valve may be set within 15 degrees of either side of the prescribed
position.
HINT:
position.
