Help please 99 Lexus 300es
Ok my car I bought off this lady 500 dollars it's starts when put it in gear it's starts to go slowly and when I push down on the gas it's like I get no pressure so idk I can't take it yet to get tested cause it won't go anyone know anything about this.
Codes?
Have you checked the fluid? could be many things. The 99 to 01 models have a known design flaw that results in shattered planetary gear sets and in/op transmission. Same issue as on the later Sequoias.
How much miles in on the car? Any CEL/DTC?
As mention, the 99-01 models has the different trans from the more reliable a541e vs the u140e found in the 1999-2001. the u140e doesn't have a good trackrecord.
Drain and refill the transmission fluid. I'd recommend blackstone lab for fluid sample test. You may need to rebuild the trans or find a replacement.
Noahhjones
08-19-16 04:11 PM
85Krtagena
10-23-12 03:36 PM
tomstep2
RX - 1st Gen (1999-2003)
06-25-10 12:33 PM
