Flaming ignition coil
Old 06-26-18 | 05:00 PM
depehlps12's Avatar
depehlps12
Default Flaming ignition coil
I was cruising down a bridge off ramp this morning on my way to work when the dreaded CEL came on, and quickly went to flashing. I figured immediately that it was a bad coil pack, although I figured I wouldn't be able to confirm until I got home and plugged in the scan tool. (which of course had been removed from the car, along with the spare coils, about 2 nights ago) But as I pulled in into the parking lot at work, I smelled a smell and noticed some smoke coming out of the hood. The coil pack was ON FIRE. Now let's see, was it bank 1 or bank 2?...oh yeah THE BURNING ONE. Diagnosis confirmed! Luckily I extinguished it before it damaged more than the connector it was on. Got a new connector coming tomorrow and plenty of coils. Anything I should be on the look out for? I figure if there are no shorts in the connector/harness, then the issue arose from the coil itself? Any tips appreciated, can't find too much info on burning coil packs out there.
Old 06-26-18 | 11:29 PM
I've never seen this happen. If the replacement works properly then it was likely just the coil itself that failed not because of the signal sent to it. Although a coil should not start on fire no matter the signal sent to it.
gifford546
Performance & Maintenance
17
09-29-14 11:37 AM
gorm2
08-12-12 11:06 PM
jdsSC
05-24-12 04:11 PM
91supra
IS - 1st Gen (2001-2005)
12-17-08 10:54 AM
SorrGwa
12-04-08 07:23 PM
Quick Reply: Flaming ignition coil
