Fuel Door Release Switch
97 ES300 Fuel Door Release switch does not open Door. I open it manually through the trunk manual release. how do I change that door solenoid?
The fuse block is locate behind the coin holder. Try to push on the fuel release switch and make sure you here the solenoid clicking. Sometime the fuel door spring is broken and it won't release the fuel door.
Granite88
07-25-16 05:11 PM
