98 ES300 Flashing TRAC OFF and ABS
I replaced my rear tail light bulbs, as well as reverse lights with LEDs. After that, the trac off light started to flash, along with a solid ABS light.
Has anyone else had this problem before? Could it be a fuse?
Thanks
Thanks
What's more likely is your electrical system is seeing irregularities in voltage output from the alternator.
I had the voltage issue when my alternator started going bad. Anytime the system was under load (Hot or Cold outside; Half to Full throttle acceleration) it would trip the ABS/TRAC OFF warning lights which confused the hell out of me for over a year.
Replacing the alternator fixed my warning lights issue.
You could also try going back to incandescents or trying a different brand of LEDs (Philips)
Bumbobee
10-17-14 06:25 AM
