HELP! My 04 ES330 blows either full hot or cold
I changed out the servo on the driver side a while back and pulled out the AC control panel just below the radio at the same time, thinking it would provide me better access to the servo. As it turns out the removal wasnt required so I put everything back together and started getting AC to the drivers side again. So that issue was resolved. However, the system only blows full cold or full hot no in between. I pulled codes today and the only one I got was the P0442, low leak in the EVAP system. Anyone ever had this happen, if so, were you able to resolve the issue? I am thinking that something has to be reset after reinstalling the AC control panel on the dash.
Any help would be appreciated.
Thanks
Thanks
I don't think that code is related to the work you did. I would go back under the dash and see if the blend door is moving properly.
djw1960 (08-28-18)
Epic123
04-19-23 08:22 PM
