Speed Sensor Problems
My Speedometer on my 1997 Lexus ES 300 intermittently fails to work. I replaced the speed sensor but the problem remains. The speedometer most often fails when I drive more than 20 miles or so. It seems to be directly related to how far I drive. When the speedometer stops working the transmission stops shifting correctly as well. Any suggestions would be appreciated
Last edited by dave61259; 11-03-18 at 04:19 PM. Reason: Added info and corrected some typo's.
There are two speed sensors one is called sensor, speedometer the other sensor, speed which one did you replace? Google these part numbers and look at images
89413-24010
83181-12040
89413-24010
83181-12040
