Sup guys? So i was put an aftermarket stereo into my 250 but a couple things went wrong lets start with the wiring:
blue/yellow-constant power
gray-acc power
Brown-ground
green-illumination
Power antenna-black/red OR pink/blue
Ill skip the speakers they're a non issue however my issue is for the antena wire i have the black/red wire AND pink/blue. Would one of these wires go to the anti theft system and power locks because they stopped working suddenly. The only wires i didn't use on the car harness are:
green-illumination
red/black AND pink/blue (no intentions of needing anntena)
Then there are 2 wires that came off the small pigtail of the stock stereo and i have no clue as to their function and all diagrams i find simply lable them as dont use.
Can anyone help me get my aftermarket stereo wired right to bring back my power locks and alarm? Notice the 2 power antenna wires and that one random white wire? Are any of these linked with the security/powerlock/dome light harness?
Do you mean black/red? Looking at the wiring diagram I see a box that says door lock/theft deterrent ECU time to check all your fuses and circuit breakers. I happen to have an ES250 wiring diagram check page 111 https://www73.zippyshare.com/v/uX7SPRHp/file.html
I take you have the basic stereo not the one with the external amplifier?
I did mean black/red so should i connect that in with the power antenna wire so it'll get power? And yeah the most basic am/fm cassette. Ill check the link but one wire I'm curious about is a white/black wire that was with the pigtail along with 2 of the speakers but no clue what it is.
White/black wire is usually ground but that connector is for the speakers so probably not in this case. The stereo harness is identical to a Camry or most any Toyota 1987-2001-ish see here hopefully this is accurate. https://www.the12volt.com/installbay...tail/2036.html
into my Camry (has the ES250 interior swapped) nice unit I didn't go for a touch screen felt it didn't match the character of the car. Has a dimmer (some don't) and the lighting can be made to match whatever colour theme you have going on.
[QUOTE=Lexus2000;10357491]White/black wire is usually ground but that connector is for the speakers so probably not in this case. The stereo harness is identical to a Camry or most any Toyota 1987-2001-ish see here hopefully this is accurate. https://www.the12volt.com/installbay...tail/2036.html
I'm Just throwing in a single din i had laying around but i plan to go with something similar
So the alarm and power locks was just the fuse but i still have no power to the stereo. That zippy file thing wont open right for me. Im at a total loss right now.
