Trunk string with lever?
I pulled out my trunk mat and the cover underneath it to clean up the bottom of the trunk around the spare. I’m missing my jack and I believe some other things down there but that’s no problem. The cover that goes under the mat has a string with a lever thing on the end of it. What’s this for? Where is it supposed to be placed? I have it sitting on top of my mat but want to hide it and figure out it’s purpose haha.
If you look on the underside of the carpet/mat where the string is connected you'll see a place to insert the plastic piece. Before you put it in there, though, lift the mat all the way up, connect the clip to the passenger side trunk hinge, and you'll see that it holds up the mat for hands free access to the tools and the spare tire. Pretty neat, huh? Took me a while to figure it out on my 2003 es300. I suppose it's in the manual but who reads those?
Hmmm. Not sure I'd use the tub for an oil change but I suppose you could. Hadn't ever thought of that. Mine has the white work gloves that came with the car in it that the previous owner never used. Hard to believe they were still there when I bought it.
Maybe the dealer was wrong? They told me that bucket is to drain the oil with. Does it even go on top of the spare? I might just throw mine out, it’s pointless haha.
Anyone have a full list of what goes down there with the spare? I know I’m missing the jack.
I think if you take a close look you'll see that the "bucket" helps support the trunk mat. So, if you put a heavy item in the middle of the trunk there is support that will help keep the mat level and not bow down. Also the bucket is a handy place to keep little stuff.
Here's a picture of the tool tray:
[img]data:image/jpeg;base64,/9j/4AAQSkZJRgABAQEASABIAAD/4RcERXhpZgAATU0AKgAAAAgACwEPAAIAAAAGAAAIngEQAAIAAAAKAAAIpAESAAMAAAABAAEAAAEaAAUAAAABAAAIrgEbAAUAAAABAAAItgEoAAMAAAABAAIAAAExAAIAAAAFAAAIvgEyAAIAAAAUAAAIxAITAAMAAAABAAEAAIdpAAQAAAABAAAI2OocAAcAAAgMAAAAkgAAAAAc6gAAAAgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAEFwcGxlAGlQaG9uZSA2cwAAAABIAAAAAQAAAEgAAAABMTIuMQAAMjAxODoxMToyNiAxNTozMzo0MgAAI4KaAAUAAAABAAASgoKdAAUAAAABAAASiogiAAMAAAABAAIAAIgnAAMAAAABABkAAJAAAAcAAAAEMDIyMZADAAIAAAAUAAASkpAEAAIAAAAUAAASppEBAAcAAAAEAQIDAJIBAAoAAAABAAASupICAAUAAAABAAASwpIDAAoAAAABAAASypIEAAoAAAABAAAS0pIHAAMAAAABAAUAAJIJAAMAAAABABgAAJIKAAUAAAABAAAS2pIUAAMAAAAEAAAS4pJ8AAcAAAPIAAAS6pKRAAIAAAAEODkxAJKSAAIAAAAEODkxAKAAAAcAAAAEMDEwMKABAAMAAAABAAEAAKACAAQAAAABAAAA76ADAAQAAAABAAAA1qIXAAMAAAABAAIAAKMBAAcAAAABAQAAAKQCAAMAAAABAAAAAKQDAAMAAAABAAAAAKQFAAMAAAABAB0AAKQGAAMAAAABAAAAAKQgAAIAAAAhAAASYKQyAAUAAAAEAAAWsqQzAAIAAAAGAAAW0qQ0AAIAAAAjAAAW2OocAAcAAAfeAAAKguodAAkAAAABAAAQPAAAAAAc6gAAAAgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAMUM0QUY0RjkxMDg3NEMwNjlFNzNFMTFGRDU2RENBODEAAAAAAAEAAAAeAAAACwAAAAUyMDE4OjExOjI2IDE1OjA0OjM4ADIwMTg6MTE6MjYgMTU6MDQ6MzgAAAFKXAAAQ1MAAtULAAE+swAA+HUAADgUAAAAAAAAAAEAAABTAAAAFAffBecIqQUyQXBwbGUgaU9TAAABTU0AEgABAAkAAAABAAAACgACAAcAAAIuAAAA7AADAAcAAABoAAADGgAEAAkAAAABAAAAAQAFAAkAAAABAAAAsQAGAAkAAAABAAAAoAAHAAkAAAABAAAAAQAIAAoAAAADAAADggAJAAkAAAABAAAREwAOAAkAAAABAAAAAAARAAIAAAAlAAADmgAUAAkAAAABAAAABAAXAAkAAAABAAAAAAAZAAkAAAABAAAAAAAfAAkAAAABAAAAAAAlAAkAAAABAAAAAAAmAAkAAAABAAAAAAAnAAoAAAABAAADwAAAAABicGxpc3QwME8RAgDdAN0AkwDcAHwAfQB8AIAAfQCEAI4AjQCJAI8AlQCRAOAA3ACXAOAAfwB/AIEAgwCDAHUAgwCIAIsAiwCMAIoA5gDZAJoA3wCBAHsAegCCAI8AgAB2AH0AhACJAIcAigDlANgAlwC1APkA/gD/APoACgGGAHoAcQB6AIQAhgCFAOkA2wCZAIoAhgCFAIcAiQDmAIYAgQB5AHUAewCBAIQA6gDWAKEAjgCHAIgAjACPAOcAgQB7AHkAdgBvAHsAhwDgANoApQCRAKUAgQCSANcA4gB4AGwAaABtAGkAhwCJAN0A3gCcAIMA4ACHAPcAogHOAG4AagBfAGQAaACCAI4A3gDVAIkAaQDvAIMA+AC1AdAA3gDvAJcAYwBhAIQAjADjANMAnwB4APsAfQDNAPEA6QDEAKYAfABjAGEAfwCRAOAA3gCMAG4ABQF8ALcA1gDbAMMAhQBwAGYAYwCCAJIA2QDZAJ0AbAADAYgAjACfAOcAxACxAHIAZgBuAIYAlADQANYAqgBqAPYAvwAIAQgB9gCvAMIAcABrAHYAlACdAN8A0wCqAIMA7ACQAPMALQHnAHoAbwB3AGwAdwCQAJgA5ADBAKIA6QDmAIIA4AAcAdIAYABRAFIAaAB+AJoAnQDhAMQAwADpAIcAiADPAEAB2gB1AHAAbABqAHcAmQCgAAAIAAAAAAAAAgEAAAAAAAAAAQAAAAAAAAAAAAAAAAAAAgxicGxpc3QwMNQBAgMEBQYHCFVmbGFnc1V2YWx1ZVl0aW1lc2NhbGVVZXBvY2gQARMAA80bmLFSYRI7msoAEAAIERcdJy0vOD0AAAAAAAABAQAAAAAAAAAJAAAAAAAAAAAAAAAAAAAAPwAAC6oAAL/T//+y/gACkZ///7dNAABIxzlCRUQ4RUM1LTUyRUMtNEU4Ri1CNDU2LUI3RkEzRjQ4RDgzNQAAAAAAAAAAAAEAITL1AAf/8QAhMvUAB//xAAAACwAAAAUAAAALAAAABUFwcGxlAGlQaG9uZSA2cyBiYWNrIGNhbWVyYSA0LjE1bW0gZi8yLjIAAP/hM/5odHRwOi8vbnMuYWRvYmUuY29tL3hhcC8xLjAvADw/eHBhY2tldCBiZWdpbj0n77u/JyBpZD0nVzVNME1wQ2VoaUh6cmVTek5UY3prYzlkJz8+DQo8eDp4bXBtZXRhIHhtbG5zOng9ImFkb2JlOm5zOm1ldGEvIj48cmRmOlJERiB4bWxuczpyZGY9Imh0dHA6Ly93d3cudzMub3JnLzE5OTkvMDIvMjItcmRmLXN5bnRheC1ucyMiPjxyZGY6RGVzY3JpcHRpb24gcmRmOmFib3V0PSJ1dWlkOmZhZjViZGQ1LWJhM2QtMTFkYS1hZDMxLWQzM2Q3NTE4MmYxYiIgeG1sbnM6eG1wPSJodHRwOi8vbnMuYWRvYmUuY29tL3hhcC8xLjAvIj48eG1wOkNyZWF0b3JUb29sPk1pY3Jvc29mdCBQaG90byBHYWxsZXJ5IDE2LjQuMzUyOC4zMzE8L3htcDpDcmVhdG9yVG9vbD48L3JkZjpEZXNjcmlwdGlvbj48cmRmOkRlc2NyaXB0aW9uIHJkZjphYm91dD0idXVpZDpmYWY1YmRkNS1iYTNkLTExZGEtYWQzMS1kMzNkNzUxODJmMWIiIHhtbG5zOnByZWZpeDA9Ik1TSW1hZ2luZ1YxIj48cHJlZml4MDpQaXBlbGluZVZlcnNpb24+MDEuMDA8L3ByZWZpeDA6UGlwZWxpbmVWZXJzaW9uPjxwcmVmaXgwOkNhbWVyYU1vZGVsSUQ+PC9wcmVmaXgwOkNhbWVyYU1vZGVsSUQ+PHByZWZpeDA6U3RyZWFtVHlwZT4zPC9wcmVmaXgwOlN0cmVhbVR5cGU+PHByZWZpeDA6V2hpdGVCYWxhbmNlMD4yLjQ5NzU2MjwvcHJlZml4MDpXaGl0ZUJhbGFuY2UwPjxwcmVmaXgwOldoaXRlQmFsYW5jZTE+MS4wMDAwMDA8L3ByZWZpeDA6V2hpdGVCYWxhbmNlMT48cHJlZml4MDpXaGl0ZUJhbGFuY2UyPjEuMDUxNjE2PC9wcmVmaXgwOldoaXRlQmFsYW5jZTI+PHByZWZpeDA6RXhwb3N1cmVDb21wZW5zYXRpb24+MC4wMDAwMDA8L3ByZWZpeDA6RXhwb3N1cmVDb21wZW5zYXRpb24+PHByZWZpeDA6Q29udHJhc3Q+MC4wMDAwMDA8L3ByZWZpeDA6Q29udHJhc3Q+PHByZWZpeDA6QnJpZ2h0bmVzcz4wLjAwMDAwMDwvcHJlZml4MDpCcmlnaHRuZXNzPjwvcmRmOkRlc2NyaXB0aW9uPjwvcmRmOlJERj48L3g6eG1wbWV0YT4NCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIDw/eHBhY2tldCBlbmQ9J3cnPz7/2wBDAAEBAQEBAQEBAQEBAQEBAQIBAQEBAQIBAQECAgICAgICAgIDAwQDAwMDAwICAwQDAwQEBAQEAgMFBQQEBQQEBAT/2wBDAQEBAQEBAQIBAQIEAwIDBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAT/wAARCADWAO8DASIAAhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcICQoL/8QAtRAAAgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS0fAkM2JyggkKFhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqDhIWGh4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uHi4+Tl5ufo6erx8vP09fb3+Pn6/8QAHwEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcICQoL/8QAtREAAgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMzUvAVYnLRChYkNOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6goOEhYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU1dbX2Nna4uPk5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwD5Tg1+0srzQotbvZ7exFqsWpaVbH7KzSTKq7mkcriTezFV4DeWflOa9B8B+HtL1611bTNe12w0fxDfWAuNJh1DVoYtJ1CFVkaXcZH/AHbMW8wIOF5y3THhQv8ATdftbCTRIXjK2k15fC906Sa5eRdqtFvDMNzeSsm5eAd2MDite9sZdO06FNRjsr7UtQZ59bv5GkuhdWdz5ckfkR9nUuvyoAcKRWDi9mdTbaN+e60vSbi6tZY5JjeGWOC6u7SGKxsRGwYR20mW80Ns+VhtCk1ixXOi+JNeu7aOWa1kljW7azmvFbSBGqxiRiWIcO5GGO7vximaxLYzaXDHa6RZXusaZNHMbuGfzI9QtJIWaSPy0AZT9wkMdynPGOayNTklm8PWmoT6Xbv50ENndasqvFDaIobbGGBJw/llsnIIXr2raGi0OZtsYbSxg8Q7VWHUWjgWWY2E2LhI2ELSNAoK796+YcBuChxgcVF/alpYz3+jTa1dXfhrFzqGl6TZ6fJFaaZdSbMqGPzOWH8BXGdw9GO7pM+gwT/ZHtb+5s/sbeVL4cma21C1lURhbqBCu6aPyzJutmKlt338GrHiHSfDC6ZY6p4Vv73Vrn+0rq7js9RtJI3+ytGJo3umVykciht7Rs28eUAH+XFaqbbCy5bswtQ1TWbm8l16/bSIru5sxpzNa2zR3GhwLyrOufL3Oisgi3FlGDgmq+u6hpumeHdUmttTfVLZrn7ZPbGzMI8QYSNpt2w/dwrdhtdsZzWT4c8RXuu6HD4c1PQ7zTft2uySC73R/wCkr/qfNmaQh2Hzxnj+Hdj2ZLpVnHol7oJ1USWsafZrKZdUVpbTe8ZaBYWAyGIaQnkYK5Pc1yRlrIzU5X0KOm32imeaS9ilgvdV0xprSz06L7TJdMNslqzMjYIRGkDeXlv3fIGKvahaa1NpXiKBru8msfDSnWbXVYbdL3T4pvtAkt22+YrHzPM2gsGbKuduBiuQ1a21Xw6+LCaOfWrUR3Fle6VDM2pWENzDNHJJIwIMZVQRkZDbj2rkofHvjPT4FuLXfrdrdSx6pqx1aJrwGXcoW3kDbWdWBb5O2/0BzNPCvEVF7Pq7FTxHsablLocNr3i+eO7g1K7vtVOoWazLFp8cZiiEcg8tmw5CgOeeMFevHJr0I3hFnpFvcXkWo2mtwrPaQWTRw3SRldk8Plxn5WDtAdrHaxiOa8gvLGy1G5uXZD9td/tDW8yMIlYqdzdeMllH0rNuJr+1uZhb3DQxx2TSxFf3kihgu5dy42nO45r7ahwjiKmHTqT5Zeh8tW4mhGrouZH05oGoqNRXRodEtNFuLWdbO9i1aM+bZw20bCZgJWO1nMcZKY+VnODg8e0z+NtC8J6Eq6LcajcaldXR0SJbG3mubnVLOaeSS8kj5VIovLkVXRQPm43YNfnZH4y1nS2s9UE2pNrbJJJHrjz/AGuacvuG+VpNxY5Vhk99tdF4Z/aC8SaBYy6b/YWl6/BeX0in7dZMJ2mmVQ6rIjhgpB7Y+bBzXJV4VxMWnzo6KfEdKS+E940LxNp0g/tFZLt9bN80Fk2sagqaOjwzZeFQclWYthZAfmAZTmtLxx4ik8S+IPEWs3Vta6ZqFl5eqXJ0S7htrG7eONYQzON480K4XZGe27G4HHydL8Uy+jR6Bc6RAt0sjCN7gfaLiJmZniVZXyVCu2dm5t3Tis+w+IPmXEVvN9qgtiWi1tmfzheRqqpHhVCnKdRyMFV9K86rkeOg9D0aebYaorSkfXt/408H6Npml2tvbiSaxurfVXjEMc6WLSL+8WWZF/fGQyOSu35Q2DXE6ZcaDq+q61d6t4hSx1PR7Sy1i00LUtPksrbxCtxIjXVlHNA3ARZIzH90MvPykV4nd/EBJbOIvNdXVvp13cf2fbRKtvEnmorpNw24M/7tShJ70y3+Imn3stvrVxbSwa3AI4YJrkrLZI0e3/WQBPncxxqFC4GTzmuSpluJpxvKDOqhjsPUlZTPdtH12N7mG41lpmtNOkeT+ykk8qB2m+b5p2BDk8gncxwrcjJr0G91a2trqOUWpg8Pre/Y7q0glW6ivbW4gSTzJo8+YWSXDrk42rtBA6fNs3i+HTNRhgspptR0ua8jdF1a38i3SK63bmjgU5DNudTsYBd33s8V6zo+vaclt9qMsJ8y7m0mW+e0mjstHaaPau6PLM6oqsAXy3ccV584uD0OyM+f4jsYtei0JH1HTPD0Ft4aiMjXbQ3ML3F68jMkq/vDuWSLzrYnd/DH8pB5r1rQPiJBrq+G01XV7aS0026ewV7ST7VdmFmaaR2HykOWbcd4G5n45ya+e7++j1iyjshJD5X2D+0LxzaSSR3DRyL5KbgcqMRx5Z2yfpXN+JI7mwv7K40ee1bU7WOSeWSRo/sszKxZUaRSCxQNuXbgNXNWjzR1R1UZO9j7Hv8Axx4b8W6vqLaK95BAJPLFu14r2l3JY5jaRo22xKSQGGM/NzzXB6xr+oX8smjJdX801wrPbqbTz7hYZFO6OSNWPzoFUKMEoxGOwrzvwR/ZLXthrOuXK6cv9kCKayS8NlYLM8kmPMZRhlkX5+cHdwWqHxV4tsI/iLeXGhSPa6TfTxy2bPfi7vrdkZYTJIVA2Lhc7T97ruxWFH2nw3Omfs73R6Z4b1+zvNItrPSvEj20lyJIr+zRrqKO1uI2ZoJ5rgDylmDcqAWJVnzt7fRqeK9M1SFNLliu9asR4fbVbe90iGHQri11CK1jhkt2mufMecr5e5UjKCRpCRkHj5DttStpLC/8Py2lrpK2l+upTaxYX15bS7du/wAx7dpPKY4mY71XjccY7dWNdGg6lpW+50vW9M0KREj1ezupptMu5Ft4/wDWyH5vk8xRu/vZC4HFYVZpOyidFFXV+bQ9p0TW7HRNP03X7XVobI6ay2dtbahOttql55zMo+1s6AgJsUbQQp2jOcknz7xdr8yS2uv+Grto4Li9mtb+HS7qPULu4eHcf3mMNjdcKVYkjPCgEV4B468WXWrQ2+lw+Zq9lpwkkvL+KJoZZLic7o8zOQ06MPLfayrt3MBWF4N1d5ryZNS/tZ1lYS6rDYSG1/sm4jkWVZCmCV8s7tyHacg8Yxi4U7wvIzq1Ep2ifUA8Q32r6HpOgQDUdO1e81U2TnU428ySfdC/7ybeP3oG9SGRPlWPGTuNdJqt1HaXFguo6J9r1jWLBtYumfStv2ZZpMFTHE6h5N1uo3fKQvrXjEukut6muW+vJpkWnQTeI/8AhIr66kiiLQxs0OdoZxcSu0Z28t97nrXsfha/1yWFdWLWOkWerWcN5p2mWjy6jLrMm3FzdyTmTcu5mZlRzyFYgCnJR5Li5pHG+CdL0vRrfVNX8P39mz6TdRzi31i48tp45pBbyfZYyeVTd/qxuPllnJramum1PVdW1Vp9Gt9XvYkktNKe3aIyQyBkZrFH+Q7BHGeSpxIOCQ22DSRcxXOlRWlnJeWtlHM91Yafb4mjhh/eXEki70LBYixbJBC4wcECs+eLw3Dfrrp06S7t767kiS5edLRLSWSRmt1my5CoVUDO7K7WyfTrceeXMeXzNLQvQa5fWs8GmxanqqxPFJbauIraF9Pt52djaCziCKd6oyqzMxJ3ADgEHS0uRL/w3JpOt3cEtvoGqXvlxvp9vFDfDz42TznDglPmc/KCIxyu7NcVG2qTabqdybu41SKCV1nURmTSxLbyK0G6QrtcmPzF2qxJBPPSnS6hLdabPbzwX2n2+t2cd2P7PumhJVpt0M0NuV2xopV0EYcEKeRWpgVPDuvahaX+pajBaWN4NNbF5Kt5HZ6hCrM1rAYcsryZWa3OUXcNp4GKqRxatpupy6dJfLd2zs3iDVLJBuknkXe28xMyovltIfvHB/umqc2g28cuqGdYrfSoJUMzarPCdRl8zarMsKhSS3zEOMHDNknjEtroemtrd5a2+oTRWV9IxS8MtxdRX8Uaec1vDGybpNu3oV+Xucc1vGNveRlKT2Zb8TeJ9JlttCuobOa4utZ1BrW7ie4WCULDDHHA8K5wm0NJwSoJVD8wNYXh/Vjo1zousX1/e6xo6ahMbzSru0KR2Mq+TAx+b5HLwMOQPlOSFJqh4hisYLywvrC9jvRGFvIb97BbDTIpGZWkyhySkeWjJOAx2dBxXPXk/wDod22nx3GpX2syNcw6bprtcQIkkmbiaQjcAAPJAXKnPIwOK2hC+5zym18LO98WeLdJ8RX1xJcWAnvtTaSytbWyMlkfJhjaSKOYRtGrLCsh7At0zXjiPZz36I947wjR/tcFy1k0KR3CySLI2DwwQ7hxzjuetXhrWjR6MtkA0t9PcrcXUq2Si4t1DLuVZclkSQs25uCFQfMDzXK6b/a13qM6a5aNYRxRSC0sp42gkhRNrKmc/Nvbnb1+bnI5r3uGsPD+1KVN6rc8zOa3+wVJqWuw7VU09lE9nPBdSKEiltj8krN8seW/3iB+dcDeiOOCZ55fLWdZI4fKjw25flfHPZmPUfwiuwfSzI0lxZpsYNJIRuUSHzOVVV78j5TWd/Zr6hOsEaweabjyTJIAg3NK3yqQO425PQ/pX6/OlUtzRPzeMk5Kx57LC00T2siERNJGLIKVbfG3mblVs43ZjVsdyx6duajjlhCr9nDOwZLdUYQkd1ZmU8thcYrudRs7+1+1wRbN8EzKEyx2uoZeMsAAQ3UfnWFdaTdiOWYK32e2zNsjYtE6lgNzDdz3yBzhhXl1abUuVnfSnZHFXdsNTiF28Tu6XCxhGU+VGMfeyDgEHqc5+U8VJFZ28du0hjZZCWBZ3O5lwuAzd+ehPSugks/Jaa2ltH2yNvkWOYsRuj+UFs9BuJx/tEVJY6Vam3l8+UoIpDPu3YlUKq7U27u/rWEaDepuqnU52OxnjkkzAssbIGjhlZip3A7ZOMjrjbubouDTzZi0SO6cTvGR+5BG2I4Zfmz77cYz3NdGtsjGytfPdwzKZowD5dsOirycNtHPJNWIdKujFEgnna3a4jWILhpgzLyVAbjj0HpQ8IpK0jWFbktOJwdzb6wxtrm1u2VIE3xvPumlkVnDPCq4wFYsSCD2Fbmg6hr2kWZuodUvreW7vpbWfRYSHia3SPYLiRS+H3b8Irf3ZPY126Wttb3EdlvYyJgi8KeWTnaPvN/dA6H34onMUczPqyJfyIivDNa4jYqv3VYjao4749OuBXj1uGMDWfP8J61LPcXDTcxfC3xI8Y+H7e/0u1vtUFrqpS0uYIgoS7R2A2yK4KqO+Vwo7nFezaJP4eexYzR6raiK4j0/TtPu723urtIxtW78y5Qbc+Yw6jGAwHFectBpd05Wzi225iRo/OBQvKyqx2r0OM9ah/sNVEdvNI8kb/OYU4IOevDZzy35muCtwVRqQUqdU7aPEtaEuWVM9n1L4jeGNOtZNJu9NuNQaG+xeaYiLZ74+N0hn3MGkPddqqByFrAvPG1rqF/b6jpcpsLpbaO28p7RkidFEgMbMDyUHyg9WJrkpLKzRGaQzTzlFUTuu8t2HmMc5PualhsIzGrhlDE4Gc+XENrHkEdeSP8AOa0o8DYKMeSUnzEy4nxLnzKJ6K3jqXUNIt7K5l06KysrC4uUhjijtZ7cyKyYlZhulY4U4IPtVS71jNr4dhh1sQ2khWa4v5Zd1rcr8reX9mQbmUSR7Cp5JxjFed3Fm75QFNvmKQTHuZdyjcueuDt4FVpNPcMptXeCZXVoUQshzn5WVs8YY5rz8RwBSetKtY9GhxZUiv3lPQ9PvIYtTRo7nVbXS/t2o217qNvZWTQ31gsk3mNiPhQI1LYEbHcwKnGK7uC90WHQX/sbUNTt4pNeNzfXUd5m41KTc0cMkzsMxuygs+AA6yYyxFfPS215PIbqfULpbicSfaWkcuzbfmTJzjLNzn3OMZrs/BXiNfB1lqNvd6dFrUt3BMipdXUsCw3MjRsl0wV8SSRhpFBYfxGvBxfCePw8P3dRTseth8+w1f3px5T6j8F+Lp7VDp17YWGo6O+n6lBLp8mkyeZdMqKbe/j4VPNRDHywzhSdpzXZ6dMNKttPu9O8S+Fb6XW9Oj1gaTaaqLKHQ1keaNbeQ5H7zCs5GBt8wAV4V4S8Y+GfFNreWt1ft4Y17TYWEZtJPIh1e2eElkeaST/WIyIEULnBI64NdB4c0618Qwy2WhaMdTlSBV8q7CtqNtcK26YMqhTIu1eQclSwO7HFfL4zBVKH7rEqzZ7dDEQqw5qWp6xrHh3SWt9JTSdTsJfFV/YRJe25uDbyXE0YVvO+0H90JMRksxZcDj0xz8tt5PhKw/tSQ3Vkt9NMllPdLKdQkgj8uRGUA5O+RmDBwCFbAqW4sNFvdQtJr3V307RdtxNoiaj5dpe6gFXbGsgTKnLAOCd+Q1Vn8GPYwGTStRjvX8r7XeW13BJbIwlVfs8kedrKyluQOrZOQOB0p3VzyW7GS3iG20XSRp9vDeNZarfRk2FwWFlbeVuVipBbkbhhutdVpd2tzpWpF/KNhp+mtdW7SR3Fxeamq7G8i3VT5aTYZyskigfKQ3B4zfFN7beRpumXUIVbZGuFv2bYlxcmSG3KysQdoYsR+oFZXnW+hw+Tp0Wr2zqrSXllqDJdWmreXNIqtDIdq+WRGq7D2jzuwa2jTTV2Ju25DqF9ZS6bNP8A2p51jLdxXGtweWsuq2TQny4VWZ03NHjY7GMbVEnOcGqVrqGkaTLb2esQ6va2RsLjUdMkSHzTf3M7bRmbIKR7DsAXKswOAKxLHxBB4e+w3UlsGeWEyXiRPHfQukg2xxyQ5COikkKxwcqQD0rT1XxVoCz232mWedZIIrm102WKTzEgZG/dJG4EahG3EIVPEnO45x0U1dHLKdjn57AS34sItDEtrCGItr474biG4aTyJG+YMuF/ecDClQSOAKwF0ia01iLTre40/RZDZSaHNqbalJ9kvZGjbbIsgHCMfLjCn3zmrmq6iLvVJPEWma1eNaR6XI84mCxz3MqwlWt1UHamdrkcDKjjFeY+H5vEt5JI0epiyvfK+1Qai5F9YGNlRkXZtbDdjgE56V0QhKW7OZygtUjptSns7CEaZAbVbu1gk04Wsk8TLe+ZtaQLcEqqkszFc8heuOtOl1S9159SvJbaGxkdo7CyjAzFCkarujVizABZG+U7v0qzop0+91CLw7r2mS21jcxG61TVLER3uoXEa7ZxNa+eyxwv5bqSxbLDcPpzniWxfRdI8Kravcp/aN+s7MLgx3bxrHlgyjH3yoyCCQcHgHNfUcNUav1uVZR0ieNnU6f1WNHm959C0LLV7Oz1CzkihYyPFdNcrDvmt3RhHtSQcfxbsdB1rAisxNqltbm8e2iaUSPMqkWqzKNu1ivQH+6O/Iwa1rm4e7ns7WzM6s0o2s87GSVvvNvBOFyPXr7U7SZ9T0+7sme1Oo28l0oaCO7WKRmDj5iucce9fo7dblV0j42KpJ2Oc1SC5GpiNBvkt5jDJI8TGfazDy3I67gOc8Vhyadf6VeT+THdXYxJDa+Udu7zOFZ88EY6g/3R0rhP2h/Emr/8J1p2nWesXGl2msXc01w1lcrbzytGq+WpmU8EdK5dbfUfKhe21/xX5rrzH/wkcg53ZXa2epHFeY8VWrYmVKnC6idv1SnSpRqVJe9I9Rh02b7UbdLURyQ4byzGbhJ1ZV+9z2PJ59auXukXF0sy2+ng+ZbN8ps9mGUqPmfAHAGa878MWfinUbseDZvHGp6Cuu6rst9X+xvfa7a4jH7mKYEM28hVH8WT2617d8Tv2VvjD4K03QbzQ/GvxGjm8TeCpPGdpBrusLps0yDeqjcpIjMgjY+XKysRjFYVMZiqdeND2PvM6qWBw9WhLFqppHc87GltAizRIBcIV2QSJIwbzF6r16Dqw/ACt2PTLqSyS5+z31rchm2Qi2kRpM/xKOSQOxr5tsfCf7XHjTwxZDw/pmvSaTZX8NjF4ptZ4rNppp5Ctvb/AGySRSzllYbfvDjOK8s8Y2X7Svw91e00nxn4j8eeHtUuLT7VFFqGqyGe4t3Yr5i7ZPuErIP+A5zg1tUrY2l788PJLzIo0sDV92FZOW1kfcqpNMRGvmGWHcskccIIf+6zgZGfUnFXZNGu0yrQs42AkPGtwsR+9tI9fevhjWPHPx51SXRfDTa5f6NPpdqqpPpsItr7VfMXdHJcSFvnyrKckfxDmsGKb483lm13ZeLvGN1tvfsFwtnfyXM7OV3L8i/MwxzkAdO9ZrMMS3yqmdf9n0IwUnUt59D71i0m5spkeRbiRGjVTIYWiVGUcspAwMY711FrZzMyXBiLgxsmHfDdMbtu7O33r5B8KWH7U+oeHdX8O6dpHiq/mkuY47rXLvSLptR0kScrsZtu1m7bvwrodU/Z/wD2xdMt7Sa71bxZp0sln/aEkOuX0OlXFvb/AMLfPLkqe22pePxcb03RtbvoUsvp8iqxnf8AI+nltPKklQIGuGg2QtPDtVdp+bao6+xqstnqCzFJrdzsYSzK+4Rnsqn1z7VzXws+CH7QPjj4e3J8TfEm18GWVlqf2aPxFf28mtatdShvMKQrE/mLjb9/kY6V6T8VP2NP2g/hx8KG+JP/AA0DZ6/ofnW6RyJ9strq6859rIisTll56n+E10YLFY3Moy+pqMvZ/Frt6k4rB0cEozxXNHn200OTvoLlIUkaG8t45FbYPJ8tpSgKkqWGCAe9ZWnxz3EM3mQ3DsG+VdhCj8c8A/WvM7e88XHw7a6dqfiO8kvInzLqlo+27m9mkbpnuABmuK8Tal4k0/TtTbTfF/iGOeysEvSx1YopXcismwdSCw4qK9THxp+3lBfeTRjhJSVKNTU98IuAzRSWckRVv3S7lIkMarvVu4K7t2ahfV1tYpP9F8yeOT99Jt+WFfuLn12k7SO49+a4T4J+Ite8SeFNZj1u5n1m4tNSY213eSefPEohXzlLH5jyVIySRXcTqqxLA7qTOpkj3Ju3s3lvtOOTliTj/pma5rqth4ztbudFNuFdwcrlGc28kUl9BDMbm2ZZXuHl5j6bWXtnKj6V9a+GfiFd3mjaJrltp1kUsw9m0GnK1qocx7ZJJGjGWMhwd7bvmUjNfIc7GG0urSNonECpA9wq4jL+YfuhiC2Rx0PNei/DXWZdL029jeS38kXbOLeTaWfcqbdvBI27pOOnJ7818NxRhfaYbnerR9XklZ061k7H1gLm9uPFsV3NeRXt/pVvLHY3KQLNpstv9kZriGGOT5PlT5AWw3yodzE16Imp6OLXULexuoDpLQ4a+exkMt42yCRYp1DfuyGDASLwr56jpwEkuhaXoFr/AGTq1lcavdeZPqdpc6coaKN5FVU3M+550Xc6nCqAV9M1vHw7o66VDqMWspaNPqSWFnpm77ZeG0ULGt15IbOTKrDy2+Xax5718pBXep39NTAv4fDhnuofEB1IHWoZLWXUXupTH5KbZyfOPAPUKnfaM8HNazf2ZPpltqNjJdmytrSO1glSeaOTT7jLiN2LPt3Oq7dp+Uj0PzV12rE3Kz6Pr+vWT6Z4WlbUrcXSs2kSXUtvbwvcOzLuUFcKyH938uBg815Za+PNPjtpILu40290K61dltre2vHgk1ZYI7hWnVHyAsbsuAcjgDBrpjD3bmM562OfOk6Pc6VE0F1cR66bn+x9Isb6Rrh7uOG4eSZ7fbhF3Sbhsk6huveuA8RC7t3n1TUryxlKatNa2Vsl4susQfZ1hjZpoeWWOTdsUPuB8kgbSpxo3llqd9q1xcvaF5bbUYZIBbu1wko8kzTPsJQFCDHuHGBL1BFQeKdHnfSLi5u7qFbm3vyusNpjqbmzhLqnk3se4tC2YxsGcMGPfkdEaaRwzlzHIWF5a3EV5DfFLGWyV3tJof8AQLprojzI1eLaCylmXH1ADANiuf0OVrTU7KTTr3ULYvbLPqCWg+yTGNWjZhCxfkqFzudcDk8gGs/Xb61WX7NL9qjtZ4/OdUbz97SW8bL5h9TuwFPzL6cfLveEdKuNSsLhLwuNP3KtnbTQ77yPy/MIZbj5WAG6VCp4xJ9DXrZfgKmPq+woK7PMxOKhhacq1TQ2dA0e5l13T9bupLn+w0LRaJDcTrdarefuiqmRxk4UD+LjgVoeKorC71DTZJ57uJW14vesIxOtmnlsNoJPzMGbB7DjjgV0DaUZLmKy0uGWU+W2DDd/u1HlbmUN0AVc5x/dauUnsbyHT5YlQXKXGowvLPNtW4g/egHy2Y4G4/eJBz7V+q4fAUstwPsIR101PhpYyeMxjrTfoT3enw+ey2MkcggTymld/LeWbbu3J+HABJqO2Nvb6t4duVMm4SeTrEMny2Lb+Mbs9R1NVhKk0htmSVXSfcqrKwi9SzfOcelXLSea5uotOkJaeObZN5sirFt/vD5uTj8a9BNWSZytOMuZnzF+0NYSP8QfDD5ijjl1C5SCZRi3lVQP7vfB64qbT9K8pkklvHdZ4fNLCRmjC9dq88EdBT/2hkH/AAmvg6C3Dzxx6pcyLFb4jZflXdht3Qe+a2tHW1aaKCGaQuYNyBbXYM7FbDZYkjtXn4CH+1Vm19pHpY6f+zUeXsdr8L/ANr8Qvi58M/COoQ3j2Wv+LbPT9QWyma2vJbdZI5JfKkB+Q7VYDH86/av9oXwZ44jsLGx+HHjDVtNuI/hfqGiWmnWFpdX8eqw201wtvZPdOpt/3auy+ZIwbKmvzD/ZXS3sP2qvghdXkazW8fi+G9Kl2WE+VFI+dwPGcYxX7e/FbxjeaD4h0ewvJkg8JXPhHVTHJPEscVlJJNLLGzScZ3bmGWOBuNdtPD4WWaYeWI+FytuYwxGKjk2OhQ1koJ/ij8dvh7+yZ8X9c8Hf8IZ46+K9/wCEPDs11D4qi8LeHpVu9eS6hHk29xO7ECPYrsuV3H5jzUuk/sM6bP8AEq01jxnrOoeJPDNhp0WlSWGozyXWoatMv8UkwC+WmNuVBYkq2OtfXup+PvBsDD4haJq0Gqa1o1s2iT2YvlSO8VW2yKyk8nOGVhXReHfjPoXi/wALavLYhdL1eC0kkvYpGE8tnIsfyTRsM57kZHU19RmssjwuX1XSXNUirrVv+mcPB+EzbHcQ4WOI/hylG6so9j5d8f8A7NfwL8P/ABQ8LeLtVex0mx0+CCxh8F2y+da6tKPlV5NztIcDyx2+6K6i48SfDXwMbvXfCHgTSvDNho+oeadTS2XT1uryaIxBWb78nyHhd2BXBz6F4g8XS6HrGuWkUcGkXkl3N4y1dkTzF2hlWJshnxj7u2vIdd8T+BfCum3E+v62niuSK+/tG3utdaa5CTLvVTa6XFgbflUKZ2UE98V+RvOMdicRSXMqEZW1tqf0biuH8uw+W4yrhKftoU6kvd6RdtvQ+ibj4wX99t1IRXFpaGI6ghthse7YbVVpFOSADnHPYV5/4r+NnhTTLKe98SxaFd6zqEHlw3uuXTa1q0EQyyR29qGfYFHP3V57ivn641X4m/G2KGPwha31vol1CqXEjRx2l1PIsjbI1WIqEyFYYy3y4Pqa/Uz9nf8A4JEeF/GHgY6j8S9S1DTtd1/SFudLfSc3GsRzSKGidFBO4lmALYAx91ia8Z18JPMMRiMXVlK32pSfLp3R52fyx9Hh3A0cHRjGEukYptt9Ln5seBv2gvEXhdbnVtBXUoPCUOoGbUdU8TXUGg6GGcYxDaRKS5PTYGL47ZqL4y/taeMPip4Ns/hHFb6Ang60uodfstS0SC406+3fvQ9tcRuQcl2Z/mycGud/a0/Z0+Inwlvb3Sf+Ee13R7b4ReK28GX1l4oh/syx1VpJCy6laRs7Hc6ry8mQodTuGa8Chxpxs5bmxmglu2Wa7ScMJJm+8zM27Lj5sjB2njB7V9BwtjMJi3N5dUgo315Le8vPufnfEWGx2EhD+0oSbt7vNdJDJYVdZcxJvWMKzsOF/wBrrjPvXmnjOcWmk+JTIxkkOgx2Ssqjy98lxbliefRcZx+Br1TVmtbVjKVkgguwq20iqzNJjnd14545rxT4i3CyaF4hk81ixubG3jWSTZI+6RpG6n0jFfR5qmsK1c+dy/3sRF2PaP2ebaKL4VXt4+ntm48STyR6kkwJlVY4Y5IhGBuJyvUnFdW0Mc2qQWUz+abj97GFGBGud278T9MZNY/wXhng+E+h2To5tdQvLjUEVJfKzvmKttbOSTjmu28OWdir6o7S2Ru7eXyYYHuVF95K8fKrHOd3GFFeFKTjRo049T3KMYurUnN7HK3IW3eazNv9p82UqWIXDDdlTnOcZOMDFafw51my0XxRH/bNj/amn3NnJnTmkW2g83ZuDM4ycgbuPYVDrF4slzeLbsJPLhCJGGaOSP0bd7enXNc9ZfarCa01BJUiuhJKYWmm8nz1YSK2PzyM9s14+aYSNSLoyPXwVeVNKpE++tG8NeHLzxC/iHVbzU9W06U7L7TrS4ihurVFj3feVCJHQ/dwGztA3cMBdvR8P9H1+9j0Y+IL3NxBLZ3SOIlihWNZJY7u1KljtY5EilAxU56jEcerRItxHJBJomoWUDvdQ2l1HqCuu2KOFflxkom1PMfdy/K/LtrK1CLzdN0XWpU1PR7a6ww1ZSt3ea1Luj863h2rtLRr82zIwsY5zk1+cxT2Z783G12VdTvLPVJtbgg3NNdCEXcayrLFqMlw6ugmUP8ALuEe7H8DADNc1p/w98PR+JLbTby0tra5sg1xd3aTyOixr8zPHGzqrBWDdGwwUk9K1YvDz6c9/BfwQahpjXCakmpkSW+ppcTwL9nhfd8+1HjJww2/N96uc8Ra3/bdxDdz6hbCay01tHXzCbeKZpoWihkjXIaNoG3NlvkO45IFdMHJe6zkk1fmL2r3WnRatqN3outLZXaN5GlX9q8jTa40sixn92mVTdG2NhP/ACz5avOdbuNR8NzSCSCO5voplmZB8/8Aa32iONo/NUtlgjbmYFsE8Z7VsanM2pNe6N4b0m1sNO05LEajNplrI9jO1upia4bDttaV1VvMyC0jHAx8tcp4Z1W313XL231TTpb2F3eKVXuWhNoCzCMPMckOu0I2MEhiBtIO30MLhq2Kqxo0o+8cOIrwoR9rV+EqaRplx4m1e6nbUprixhiW6N+YVhjDbdog8peAuBs2j7oUHtXp/wDZcUumrLY36R3eShtRGyyIDj5gcYOSM5+tRw6RaaXp0ljpzmOG2Xykcs0fy8/eYklyd2OPrRbZs7O3jDPdSsHMDh2E0auMY9MZ75r9byXKqOV4fliv3j3Z+f5ljamOrNp+6tjHSF9KQ3F/cPeXUXyWUeSIYgx3yD6/eAP+0awNY1OS/wBOjKxbIzdRI0jbTbn94GjXIIOcV0kUl2ZolvGiFs0eUeRcmLaD8xzznPcVnyy6XLass8O7yjG6ssylZSz7V+UnA+uK78TzOjZHFhr+295DYzdCVPttr9n818mQD93MzLtXO319qvWZsJbuNooJI2juI2kndlkaQ7k5Vcllxnkk8elQrPPBeva5cxpLmB3IMsHI27VPUeoqVI7mW++wvKk0P2j7RGYgY0aUhQWznaDxjBGK1pK9KLJqOXO0z5o/aDhCfEDwo9nNJIp1G5SIBiCv7vc31+ldVocUsUcssKLJJIAku8tvQfLtC89AB0rn/wBpJjpHjDwUssJbOvXEKv8AKMjyRluvI7Vl6VdRO0dyt5KkJZQvlbvssTdNuQckn0wa5svajiKzn3R143ndGj6H1B+z3qJt/wBoX4N3tzgwS+LobbytvKxtvjxj/gVfvF8VrTTvFryeHtQsoLnQ9P8ACN1PdwuMvJ5alVUsDkKWkr+cXwJ4osbX4m/DVzqkaXVj4ss57aDzks7mQtJGu3ceVAPO5unWv3S+Juq6inhGK/8ACV1Lq/iPVfD81hBp+m5nuL68jaFpLdCpO4H1HWumtKhGvhZ1NlPX5iwarPBY5U3b90vwaPg+T4WeFdCs9WnudUlg003dxcafNPMLZdNgkLNsLscMF5xmuX8FeLfhd4d1ex8LaDe2/jPWfE2ofYZdU1W5+yaDpnAKo0h++DjGFyT2qlpPwT+I/wAYNf8AEN58cvF7/DDw3oF1+9sri2KJOFG+a3t0DLG8sajBBYncw6V4CPCvgjT/AIgW1r4e8QFvD58QrbaTc6i+dSWHfsSSRYfuNn5sDkA1vnVSk8FVp5fh+X3d3udPCTqzzzCxxdfnfNHRfCr2Pe/H7z6t47tdD8YeI9e0hI2uNO0SLwzZrLoekzQtDGiPbFlISQFirj5wNrd6yJfht4Asfh3N4n8QWmteJ30/UV0wmaaPTvD/AJn2qRbeR5U/fOw+88alV7Fj0rXh+G3inXvijpiabNq3xG8J6ii3Os6vapNo0cc0cjRJJ51wp/ertUMQp3DI/u4+wrb4YWFulxa6/E15pOnWRGk+G2jV9G05jtkaTy+POuJG5aZ8nrjaOK/Ost4XzDPMbRxdeUowgk1HyTP3/MOJ8Fw9gMdlijFupU5ea+14ncfAb4f/AA61PwZpr+H7Ky8LW2ka/Z3d8I4pNTgsHZVWZopMnep++pbgDK8Cvtv4i/8ABQDwD+zQmj/Dn4e2cXiz4gPpP+la/q+orpcc8zsQjxybsxqsaqqqo4PTnFfFeh6rqcPhtdGsx9gtZrkG5tLVRsQAZjjIXAO1B8xGB7V8zfGbwD43i8YWfjzwz4fh8RXVvoC6VFY6p4dttfltJc+ZDcRw3JCOmflbBJGelYZpwH/aWIrYWhTnUlr7u1ziqcSwwHCODxuNrwhG8dVbTz9T6Pi+LzfHzxnqeo+P/EXwW8DT6jJ5urQ+O/F0t3Jry878W5bDhQeTvXA/i9PzX/az8JWPg34m6vofh4eCrnw1ptxDHpd34JljvdCkjvLGK6/cyLI+xfvfKWPzK3Sszxd8HNSvXg8ZfEfSvGeqa1qcP2nUIvCWm2mkaJ4aUv8ANELSPrtUcpGOtYfiS6+Et94E1PR/AbeKBrGmW8OovJqNi8FtKLLcp39lLpI+AOTWHD3AVfhrNY4+cZU+8fsnxPEPHFPiPLvqUJKpbaWlz5+uXjk32s8kSSGMqvnMDtVTwv3uK+Y/ifOVhkUkf6RrW3aCp4jjZh3/ANvAr2q8urXVWN416wZJGBjSUKW49z2r5q+J2qebeW0IcmNruaXG/eeFjVW4PPC5r7jOasZ4aKjLqfF5bTca1+x91fDiZ7T4Y+CIntzFbNpjzGVyz+Z5k0m7Oew+XHpzWpJYR217FqU83l3QldyqxmGQoyYHmenrzUvg0Q2nw+8F27+bO0Phezb7MjNNEjOiybWzwNwZs49q2ZLdriFriQB5nOzZL80yY/nx2rncIeyi1rZfidlKc1PXrucU07JeSFWie2R5JmeRdvns7JuKnH8JbAHp+dR3jwtbywx2lvLPPJHNDM533EUcYZQFBwozuOauajbzsWVVO24i8tYwSoGzDFuOmVXOBSzRWd3Y2/nxLnYojjE+3HG7p06FevvXg4nV3Z7tJp09T7a8ba3Y2f2j+0TaNPf2EmlWmvaTp6DR2njn3NcSb0xIkizMhaPaVYBhytc7YXcV3CsMesXGp21nPDFbJH5xtPOSIq0xjQrtZAw+YjLFlwRVvxd4jTXvDaeHdUWbUNJkeG4n1d5YDJaSKsG3awbMaMJMtkHrzyObGi6BY2tvf6ympWC2XhuKOf7ALiSMa3FcyQ26hZE5OxvLlyWI2xnNfnFOL36nuVJJHlyeNNUt7+Wxt4XuZtWka2mJka4kt1UN/o5RxyuPMywHAYc81xuspe30Fldxz2xUyNDdm23K1rIuI28yMgEdWHB6niu7uYNHTWv7WcQ3bJey3cxiv2FtbtbsuYIZgSW3g/KPuncQW6Y4LVb59WdU0+GczT6pI0JEnnNpUYV22cHYyuSrbm3HjivTw1CdepGnCN5M86tVjSpuUmZekWPiCSO7i02/vtJsbi4+zSiyvPJQn/WLnsVRhvxt/HPNd5pNjD4bs0s9NCklG+3yTReY5ZsZdpDkt075/lWjo+hw6LC0NvbIwJ3ukkrStux8zKzE4U56evtUaPDa3c1wxnkldtnlqPNR/XjPYV+oZHk8Mvpc8tZy/A+GzDH1MVLkXwkNvA9vNvurqQI8ZmwPnCf88156YPJOOlXXaaSzC2sRlhdvOLo+YV7Ku0nIbPXFSTIL2TgO6SfvMbldlwPu9M+2BUttbLBO8i/6qbEiJIDt9DxjrX0GqlZnlKKSUkQQWczCRHktZTHCscsRfy5k3t0Xr9KydV0+4uLEWUEnlwFFMc80Syurbu4wMqp5zW59lTbMrzOrXEiofJi3BFI6yMP5U975njWySLNrFGsVtIyFHfu3zdeTWsVTlTcZESVTm5onJLo2uIkn2nUWeUKJPO+wJHC0nTcGLbuV9KLOw1OS4mVNRWSV0UA/Z1bLK3++B+ldQbGe82ySm5hVFVY4pJ872X72GPfHNPw0MMsccZSSRsEtC0jfN23ZrZQhy2MGpOWp4h8a/hbF8U49Nm1XU7nT9R0aRpLaa1iERTdjcvpzjivK4f2bxaQ2wTx9ru5l3iKNikiqPvfx4/GvrtLKaRGiUTyPM25kkg3Mfz4FX2tHjB86ymjEUZTY8Q8xx0OMc9PSpjhsM5cytqaSrYjlt0R8yaH+zv4ek1fwq1xdahPrFp4ms9Vn1S4l3XN2vnRs0TNu+VCFxg9c1/Rtp/wsh0n4X6M+karNa3C63qn9ivc6bG9zbRvCpMca7gWADLjOe+civxeCPK1mYYzFJAw2NuYyDb93cMc/jX1d4p/bz+Keh+FY7R/DfhR7fSrhf7K1KXT5YbyOaVI7ZusvBcYJwDwOOawxVFU/ZzpxulJNnVgKspRrUqsrOcWv8jodL+GFlepq8vjbWNW8ZJealNqQsrydrTR7C4mZTM1vZxlY1Zv4icnjrXUeFPg/8M9FuL7Uk8P6Rp11AVuIYXt1md9vlttUuWwcL16818LyfG7xjqfmXU2orbPPP9rkgsdSktlYNjd8mQQM989K5u98b61qDsbrV55Z2iMe+bWJ7i3ZvXhw2cAV9rhszwVOmozwvNc+NxGXZh9YVSlinCzT93TY/Ra88d+B9F8Rzxy6wLW3iT7VaeH3dNM0mNVKq0c0y8SFmYnaXAx/DXB+Jf2jvAj3t6NR8Q6cj2yL/oWlxS3RRQNuyNY8g8DoOc18NHVVv9kbxWcksYLN9ou5DEdy/M3JPdc+tZyaxGod/sWjf6zB3Su0bL/D+vesIZi6FWUsNRSurLyPSnCriaSpYjESn1ld7y7n3MP2hfA+n2WnNp99ceXcnzv9H024mvYAo+9MgTKZ689aqW37WmhXVxJFdT+IcR4jtrq503alzu6+Wu7KgepxXxBeeJLmxsZpbPTNGllgiLwQyXMkIkZRubL+nv2roPC91a+KdB0nxBBa+UNTtVmNuo85IWXKFflG0kN6jpQ89xFGp7RcsZLy3H/Z9GtT+rSnKVPT3W27M+m/En7Rdr5V1Jp+nXer3xRhbxXBW3iaT+6zYbGeCT+lfKmueM/Enil9dGr6DomnWGrWL20WnaTM7RW0sihZLiSQMvmyhV2ruyqbjhc81sz6SzyJiPyIgfImRh5alt24Fe/50yPRJRExZZcNuXEbqEP0XOMmvNx2Y18Yv3s0jvwWBo4PljRi16HyTq/wIg1LUS+neIdR0a2kVY3t4XzGMdW+91OTmuLl/Zh0u9uoZr7xTq08bT+SS6rmNRs3fnX2lc2Esk8IEc4G3iNl2Z3dOR14pj6bI2wCylbdId3lEqjcDkc5yNvT618nXwuDTvI+koVaz9w4qy0+HTrKxsbZ1eCxt47C0DELhIY1jXcoPcL19zSzrLcSRMq+SzN5iszGKIgr03EYH411g0uctj7LPuXmN8c/3l3AnkeopU8OfEHxRqlj4R+GngXxF4/8ceJbtbPRfCXhvT5ri5v5B8vmSsOIIUyCzvtHpXn4zEUcPDQ68PSnOpojjPs8pWI2W8p5q73wssiYVkyo9ztyelSjRrawgmNxC13PkFk+zkjczsx2sDnAG0dK/Trwx/wRQ/al1rRNFk+MPx6+DXwp+JHidmPhf4KN4g+2eKHXYJE85UniUO23ARRI4Pcnivy0+K2lfFv9lPx54i+HfxEhTxBH4c1aTS9S0rUbk30W4DEN1Z3Wd5jYrgg5wQRXzHtliZu/Q+hioUaex9EHUbXVNG1vTdJh0vXPDlpaw61Lqem2g05NPMZXYWEhWWTyvOZHQEsxAO1sBqwrDxC17pkdhpUcuq6X/ZrC3UQ7Lq2jtpJl2qoI2go24hxwFyTit/X5PC+kWlxZXlhp8NsytbPHHqEltPp+VMzKbcNlgAhBBP8ACD82cV84+HdXurazvo9K1TzU1W9WGC3t3MktwpCr86Y3qBuZT/CV618jRw/tHFRizvq1mlzM7WHWrfUr8adBZXTC68uIwQSnT4oWXy1uNoxggr95U+Xqa2fDWlDw5CltPcrqWoruiiuLmdpNsfaOMNyAg4ySe9M0SyNj5E1zDM98tr9ljWMCVdOjPzNHG55xlDkjnHGa27K3jnkuriS5aBAuVh275DuPTnoM1+mcP5NSwcPrFaP7xnxWZY+piZezg/dQ2aWQ3xB3bXRUdFbeIyWzu/DrirKSQQi5VFSRlXMbSr5fln1Ujp9TUNx5vlsqhD5zeZFOwxJ8vpjoPrT4GKiJJZW2NuEsqIPlwPQ5r6Zu0TyFBt6n0z+yZ+y18Lfjp8IPjP8Atm/tg/Fzxj8IP2Mvgj4tT4a2GlfDaIN4++MniL9151raup3BQ00cSgcszHO0AkdzH40/4ItWaomm/sM/t3eKLAHba6zqHxfXRp9RX+GbyftalN/XBAxurZ+H8q33/BB7wnaCJJLfSv8AgphfJfB/3scu6RpITKv+9ItfFVzMyyMkM8atFKC5ziaXcF/Pr0+leBl+GjmHtaleclaVtH/kd+P/ANlnTjRXS59l23xN/wCCNShRH/wT2/bXd5I8bn+Oypu2/ez/AKf2HtT0+K//AARuTai/8E7P2z3Knbhvjwox273tfFVxZNbyPcXF4m9hu2pLuB3cKPY47U6GK3vmZLmV4QI22bB0ZF3fNz3r0lkeBejlP/wOX+ZxfXsRD7MfuP0H0r4w/wDBJmOxJ0X9hX9rrQY/MZZIL39oOC2uAehbDzydRnkVwd18Xf8Agj3fSzzXP7AH7at/ehts9zD8fxNF1xnIu1Xn1C18YW6hhGsqF0LttYsWDNnjcfT2p6K7SFjG3nK2wiPhG28jJxxXQsjweiUp/wDgcv8AM56mOryl70Y/cfU+o/Ff/gkFIrJB+wL+2/YyNzFPB8eI2YbfZrxunv1rhr74g/8ABLS6ZpLP9kX9vizUnlE+M+nTeWM5x80x4ryfULFtNvhHJd2c/m26yGS1m+0xDcPunjhh6VXS2kS384OZFdiXMeBux0XGK9ChlVGlpGU//AjgnVk1dxR6R/wmv/BMX/Wj9l79veOLftAX4taPJk+nEua39G8Tf8EnfEGp2+g+Mv2cv26tDt72VYrW81L4kaTqtvBIdu1gnmdRgYznFePW4WNDtiUOxwUK5GW6H61w3jiGe10u0uPKRXTV7YxSt8zrukVeCOeaeJy2KoXUpNX7muGqXqpcq2P0H0jwF/wRws5PNf4e/tmanEQsTxXXjfRbeM8Z2kKwb+ntW9Po/wDwRlijLQ/Aj9rKVtuCT8SNPhYZ4PPm5Ga/OG2W7jntS84EG7Lc5mPyleQT2ytYHjjWtU0iyto9Cs01DXNWuhYaVbOmEb5Wd5nx2jGM+9dccpoKlGVSUtP7zOOpiJuo1GMfuP0jfTP+CO1sEk/4UT+15JHIuY1Hxb0sINv6irMMn/BGLTz5l3+zZ+1hqKquTHN8ZLGL/wBBxX4//wBh/HQyOftHhs+YPMCt5xRM8kYP5VYbw98cpNyzT+FBhcqSsmB9McZ+tc8stw81/wAvP/ApHRCvUj0ifszH4u/4In2KC4l/ZC/aUuQUZg998dAo2heTxLj8a85sv2lP+COmlRPN4d/4JqftRXGkQzb7O6T4+3GnQXBZuHWNbnjPXdX5RT+F/jdfK1nLe+GRFLH5L7Y5iIozw+0euM19E+H9LNno2kWF4j5stKgtGwd8TtHHtZuemSuefU1yvh/B1XeLqL1qS/zOuGZ16Wvu/wDgKPtz/hp7/gk4w8xf+CY37T7iU4Lv+0fdAM3/AIEVDN+0p/wSumjY23/BL/8AaSdFOFaT9pu6gK+/E9fGhS2R1iFyuUODCRyuejUk7QopMgVQf4tu4H6Y71EuGsLHVOf/AIHL/M3jm9dqz5fuPvO3/aY/4J0Lo6JZ/wDBPr46tZNGwXS5v2oGe7jXumTGTnHA+f8AGvJbr9pL/gmOxYj/AIJj/tHICwfcP2prlSC3Xjf1Jr5Pk27pEEmxMblkkJ+Rcfe68fWqU6XUoV9jEhRExZWCbdv3uWHHfODn1rz8Tw/QUvil956NHM8Q4Km7fcfYdj+0V/wTMg8to/8AgmD8fLmWWTfCt7+1BdShsHO1sOOO1ek+Kf8AgqxYfD3QL7wj+xp+yp4E/Y/mutOW01TxW8i+MPidd26r/wBBKbPlsOocb2z3Ffmz8oRWBmwq7hIG+43y5289OTXKeNtDbxFpsMtgLZdShZvJu5SrFlZVDI/OdvPavFxGUUqMlUd2l5np4fHSqxdLYteBo/2hv2wf2h/Ctl4GufG3xD+JF343sNYvvGAurm/vdB8i6R5LiS+Lfu9pUlQGXOfu45r7G/4LreK/AmnfHzSvBmhRacmveF/Bdho3i250y7W8kvNS/c3FwLooQPORt/mKgO1pACeteUfs4ft3ftc/sifAXxp8Avgj4J8BaNdeL/EEmrXPxcsooJPG+nW80fltBb3ZUMmD8/mMGZASFZa+Lf8AhAvFHjvxXdeMPi3rTa/4g1W4uLuW1F+1zueYs0kks5fLOz+Y7MTuJxk44rgk6lSpzqKhFbeZ0UITpRfPNyl2Pfrrw3pV5fJd3UV1M86q1zPLfXEkrK67fmw+SSMDPoop+m+HdP0oPJo1haWcUTeXcTxyYmmLHgcnOfcHj1rfvrtLho1hCKwi+aVQVQ7Vxt2jHSmMUlit4XzbwOPMWdk8zyV9cDByT617saNGOkIpfI8pzm1Zt/eXJ1gbSbeZbmRLpHa2mgwrbPXB3ZAx35PJqvDKY7eR9gkiblzn59oPyj1OfSs4yEyMUkaTLb0DpsRwPvN19Oxqyt9knYI4W3qyBWVlQr0zg/jXfTcrpXOVwir6al6CfzZyzusMc6YMD7gGA+vT8KYnk3FwEffFCZSTcq+8RrVS4knuW3SNhvlUqD8u/PVT2HsaBNiZiY1hjlyU7rkL/jWkpPlM4xfNY+//AIMjzP8Aghp8X7ctvHhT/gpXY3KjqStx/Z4HToTvzXw3Es+6U7A7+X87NgcNjbj34r7h/Zqb7Z/wRe/bpsHXf/wjn7fPhPV2jU7QgmfR/mXOcFhxmviaaaYH7HJHGJSQiKCwkBTp0+g5NeTkUpJ14PpP9Eejm8LzotdYjGd32tEimcmPY7ruR9vDLt9ferscTTM1wBHDOR5h3qGLt/sVUldYbdJHYCQKYGEPCHcffPIqcFVhQxHzZduDHFw0a99ue/1r6Sm+54k4pF+2nuJbdlUC3Vp9xVAoLsPr0zVnzDGWkCRhJMuYWfBLMNqnj3rPTfITJNbyWqyDMJCYV/TrkZJqWOVonZGZzKGAdRHtQKen0r0KVmrs5JRbeo6OGBI5ZGlDrGvmFpW8qOLP8TN2A96t6WLnWvtVroMKarcWY/04aZ/p81kj7VWR1TOFJ3DP69q/Qn/gl/8As4/sR/tVat4yu/2nfi1LqXxd8Ja1fW3gn9i9/FsPwts/GEFqqvZzHWJ5EF/9sJAEcMihBu3A1/Sj+w54W8U6B8VvEPhSx/4JeeEP2R/hnp/gttLh8aNreiap/wAJI9vfRtb27yWyO9wdjPIJWLcofm5r5fMeLY5fKVOnR1j/ADPl+6+57OEyD60oynJ2f8up/E5rWr6P4akFn4h1G00G7KcW+rS+Rdvzy23rgDvjGcfNXmnjTxZoV7okEOjapba5evf2pjtNJ3ardymOZWbbDHlulf6Wr/BDwHpfjMy/8KR+C174V12XGpazN4Ptb7xncXswYtJcPJAyyRbtvzM+QO1ehP8ACL4YeHrS+1Hwx8Hfh0NYtbSS4sLXTvCOk6LNfTKjNHCLgQAJvbau88LnJ4r5yv4jSfLFYff+8eth+EIvml7SWh/mw/Dn4Q/tC/GW4isvhn+zn8YPG+p3kX2W1k0jwHfx2UqsV+ZriVUiQYHVm9a+rbD/AIJY/t0xaloGveMfAHw++G0di0izaN8Q/jZ4Y8K6ykNwixvI1vLdbldeuCOelfpP/wAFEf8AgpT/AMFA/BfjTVfhj4n8F6x+x94UBa303T/D9ms9z4it84+0R+JkXyZVZcDbbNHjdjGea/CHV/H1/wCLNavdS8Q+I9T8RavPA13d6vq+qzanfXO6XnzJHdiWyd2N1fe5biMzzbCRxEqlOEXty+/L5vQ+Tx+HwWXYiVOMZv8AxaH3z4g/4J2fHPTNKuLjRdQ+CHjLVkUfZ9I8N/HnwtJqk/y7vJUSXipye+7r618ZfEX4M/tSfCG2udU+KP7K3xd0Hw1CNzeLPD9jb+PPDUarndI19YNJCqhQW+/XEDWCLUvIyxAs2FjfbK3dvMbOD65NXPD37TvxG+EuqwP4G+J3jDw1vKxxW/hrxBdRSXz/ANz7Kj4kO7A8tkfPTvXpPDY2jG/1hP5I4VXws9qLOd0HxJ4e1rzDpd6st1DAs32G6/0XUdjsV8zyzyVyNuVz83XFat1NpOh6Xe6lq+pJaWVsfPmluSWXDNtCx9y3tVTxL441r4g/GK98TeNbIWXje88JfbPEDnw3F4Yuj5klstvNPZxwxIkjhTuby1LFy3XmuH1rXvC1n4tsZPHWix+MPCug6jaate+Fpru4s7bXY1bcbe4aEiRY5Nuwlfm+Y4Oa0dWpKHKpamsYxvzOL5SOHx9puoaZf+JrTwr4vvvDFjefZH8VW2js2knb97ZMQInIG07fMDfMBjNdjouo6F4m0m21jSdQW90u7YiGe2XzXJX7yupwUZc4ZWwQeOetf1Q/8Ehv2kfFH7e/hf49/s8fHb9k3wB4G/ZH0H4d2cPgiHQvhpceCfA0UbySWtzpqXU/FzIsQW4F0jeYhj3bgfmr5h8Y/s1/8G9Xwj8a694V8K/tUeJPD2vHUpl1nwr4O8a3vxG8O2EzSLHNGyrazRgo3y8TEjpk44+RhxROjja2AxFCUpR/l95fetj3Y5PGth4YynUS8noz+eLW9YXRwfLMYLLtcYzIV6LjuCeueeK8o8R+ONW8P2dpr9hdXD2QvYINS028dnhv4WkVDG0bHKsASysuK/qof9jX/g368RRrr13+1PqE813CN08nxW1Sx2YAGPs4iCx7em3aMc5rgPGX7GH/AAbzafpzXV9+1jq1pCqNPFLD8Q9V1Ygqpb5U8hgxAHyjBqaWf4epGUHhq2vX2cv8i62X1qclKnUiv+3kfz5S2svmhLVXEJjW5QBG2lXCt/e54wB2z3Fc9rWpW3h5Ije3KTHUbkWGj6VbW0l7rOr3DbVWGztYx5krlto2qCBnlq/dLSfhl/wQhsNKltIf24vihL4ehXyrPUb/AEO+L24f5RHDqBsiwA28Fl4r9Tv+CeHwG/4Ijx+O9D8Wfs/+NvAHxq+MOnzRtoOu/FDxvN4n8YaZLuV1bS9PvhFFGd4U7reEkEDJHWvNzbNZwoynSoz/APAWjrwVGMa8IVLXfbX7z+TnWP2fP2ofCPhuDx14y/ZR/aK8E/Dy4tPtt14r1bwHM1hFC+GimNupMyoobJyPuhsivJr23hVbHVNOurfUbO9sxdQXduQsMm/A2rk4yo4YMQwYkYr+i/8A4LZ+H/8AgpV43/a18XeBvhXp/wAaL/8AZzfwVp/iDSrvwxqi6B8NdNh+ytHqBvrvzIow4lWUyCVj8vtX8yfww0fV9G8DalY+IpYbhdJ8Z3lhDDZ6jFqMLbNscrQ3Ks6tH5qyYZSVbqDzXz+S4itmFOpLEVIS7JXvH/EfV5lQp4RR9jTnH+89n/hPVJGu7uOXGfKV9vKqpRV9cck1HaI7qxSIyZiPO8lXCqW27Sfw4pvmpIrtLCttBGAbrdw7Nnp7kdeKoyXEykLF81vH8yBVK49D6n6V9Ur31PmOVDotyll2RsN+Yo5GYvHuXcvQ8dK3ryE2mmw208ciTy7bi1V4vJIRjywJPIPvWERLJErH73QIE8t/rwf51pXDTXsccl27MqxqkKyNvMcY6KPm6Z5xXRTmzBxV7iLvFuIk8uUXB3NEikzQmNuDnPU+1OgiZ1XOBGE2bZEIKfrS20Mglja2mRzIcARqZDG2cj5e3PenmCUyP55Z03lMKdjt821m/Adq3inJ6mbikro+8P2UiZf+CTH/AAVS0ggySaV+0z8P9egCjDN5kmmqm3/v319RXxJdJJCLkZkjmeZ2M6OXLbsnaee4wMV+jn7H6aFL/wAE/f8AgqZHHdxLaeHNX+HHibWkePbGjR3Ejbm91DRnOP4a/Ny3WZppZDidftTMsgfdFJtP3sdf7v6152VwhGtXV9eZfkjszPmkqMn2FtYZQkfnFntihk8ry8sv97dzxgc1pq8fl7Y2hRYUYOxm2SMD9RimrDJJbzRSbTK586N14YA8MOPaqwiUxyrG0fmwAbYw3mPcH+X5171O0XqeJKLkzZsRc6ioiWbz4bOBpIk5OT7Yz065zQtwqOQkgM0pMeQu3bjpuJPrVa3C2hiVJwqyjaTb7lPuvX86hmktLaJ7iV44AkTSySTyCO3tfLBeRnYnHAGdxwB3rsVRRV0csqbmzmPFPw98MeLUhm1KCSHU7SX/AEPVbSVrDUrGRWG1obhcMCDzkc8nn0+2f2ef25P23P2ZtGXw54G/al+Kmq+HEjW203RfGupxeOtO0uMfKqwC9jkdAB/dbHFfLHg+Sb4jwajc+BdH8S+NbSzc+bN4Z8L32twxyMobbujiI45ORkV2Y+H/AI9hsZL3UPAXjPTbC2ZTJqWseEr7RoI8fw7polHT0qJrL8XFLEQjL1Qk8ZQ96jKUbdj7Q8Rf8FTP+CjWt332rT/2svF2giQbGtbDw1o4tTjJyqm1OMZ9ayLr/gsL/wAFFPhLBpfijVP2rNS8TaTDqlvaa3Z+I/B2i30JSZlXdtW3Vhj/AGTXyRJ4Q8YRwRXkHgvxnfWlw+6C70nwhqOpwwj/AHooWXH514J+0H4L8e6/8ONTsdG+HXxAu7r7db3t7Nc+BNXsdOsoYW3TTXFxLbrGkSKrFmLDG4CuHFYLJVStTo0+b/Cjtw2KzL2l6laVvU/bbT/+DhLU/G3hK/8ACv7Sfw5+B37RvgueNodR0vX/AAtJoN3PGy/N5e0NErYA+ZYs5Oc18Iah8c/+CVHxh8WXMvgX9k/9oPwtrGoWsl/qVh8O/j1baf4a0eNZP3q28N9ZuyxszZCj6e1fhI3ww8YXYYWOitHcxqPPSO8Mwk6LlFbkA46c969S+G3hP4sfCbxJH4n0HR9L1WS5sX0290vUJ5LdXjbY24SAcMCgPHvWeHy7D0GquFo8i7RuvwWhNbGzqJwr1OZ/3j9cvEf/AAxppli934M/Zp+NPjC9gUCDSPiL+0l/Z9hO3VVJ0/TlYgH/AKaL/vCvGp/j/wDHGxtZ9N+BfwA+AX7MlpMrWzeLtC0mTxv8Rwj/ACnbr2pyT3COOu6DyjnkEGvDvDvxa+IR1JR4t+FHkadkyGXwxrZubsN/dZJsAqfVWq74n+L3iCytmudG+Fut3saFpb241nUEsYbaJTubyljZmZgB0zzXr+ww0Y+0mpM4Y1Kl+WHKdZ4O8F+KNN17XfGvjnxnrHjfxh4lt1gv9Y1m4a5dgZPMfazMWLE9z246Vj+PvAWq69Naa54Q1v8AsTxPYbVjmcb7S4VW3Ksqd9p6HPFcn4Y+O1x4i+JFh4D/ALBto7LUdGbU7fU4r2b7ZasI2kEbRnKlcLjPFfTfhvRLjXNZsPD2j2gutY1q6XTdLt5bqGwN1cSsqohmmdY0wWGXdlUdyBzXTGWHnhpSWkYmajXjXinLVlPWP24v+CrniL4dy/BDWf2lvEWkfDK601vD18ujXVvZ3c2n7PLaEXUaLceWyZXargkHGa8h8CfDLw54L0y0hsoo7/Uzu+36vPHi6u2J+Zt3YElhxjlia/VXXf8AglX+2NrHwS1j4z/APxZ+z5+0nqPhbU10TxV8Fvg34qbxd4s8JTbY5Hglvt6211cIJFZ4oWUgMShk2mvCdM/Y2/bKSy0lPFP7K/xk8D6xrkkOnjS9X8H3PkPcyNhUtriPcjIxDMC5XaPvV5mBzDJV7RUZRjPXmWzfqelXweYJx9pF8rtbsfE84trb7RFHAqRJI37ouNrfdJyAcfMTxjtXinxIuLe5uPCmmNAs0F34jtbZowzBGVmw6Hnupr9DvE3/AATq/wCCjkupXcWn/sWfGy5sLedoo7230+2Rb6NVXEiq0/ToMnHGeK801r/gnJ/wUKm1nwrd6n+xd8btJ0/w9ra6teXP9gR388yx+WMLHHK2TgFq1p5ngZ4X2VOrFP1RnPBV4YhynGVvmcPdeHtFaKWwttMtls4nZXtUgXyFUEKMqBg4HrXjfiLwP4n0nVtP8ZfCvXh4T8QaPfpfWklq72K2k0JDw3ULpteOVXVTvT+70r9HdC/Yt/aw8V6zfw+Gf2fPi9q13byxLfWSeB7yzu4GmJKq8cqoqnHLBmAA5zXG/tE/sqfGn9l+y0af4yXnw7+GXibxJZSavpXwz8QeJRqnxOubPdtW5ktYUe3hViy4iaYthudteDmmYYFTjQlU96Tse3lmDr1HKVONlFX9TzX47/t5f8FKv2rfA2kfCf45/H2CDwPaWi2F9p3hW0j8Pav4rhjVV3ahNCEacsF+bLANuOVOa8At7CDwto1l4ctBNDZadbLHFKVNzIWZgzsqkEByxbJH+0PTFXwR43tvF82v2UllDZ6/4Tu1iuzHLusdQhbLLcRxliVIxgq3FdHbs0d5KsjkypJsWaZd0TZUsXK7sc5O0jHU147wmGwUZfVYKMZfF/e+Z66xVbFxSxEm+XbsTSSs6sZVVwZt4kVlZFPvz1qaSNWt4pGfdEfvSIFyh/ut83f1p01vtglVnHIWRY1LKoJ+8W5546Yohhl8uaGIulxEMtAz/LcLtUk9fU11nncl3Yz4mmB8yOQ8gxsX2kKPpuqwGmFttMIaOOfHmELtDNyn8X8qma7Rbh45bRcxsFkVV2oQBxzmrMJinkaS3RFtom8wWm5kaT+9sbplR6iuim3LYkr291NGYp40/feXmNgVyGz1OCOB1rUtbgOAkx5mdnaQsvz853dex9KrIZI5ZBEHhjB2OfM+dA/H0qM7o2UQTNMw+RAAPLj57c9T711wuveOe+uh+hP7FHkXP7EX/BbrR42DRR/CvwXryENubdDJcDeOnPyrXw9HYRSRQXEN5CYksPtBw0aSsw2BlbByc7ulfcH7ADpcfs7f8FqNFSNjJd/shaDrTRy7SvmW899uPAHevgqznieysi3lRGeyicgNiPmNW479cGvEyecpZhiIvo7no5nf2FF+RctDsuz5jSLFIMhi2HiCjP6mrM6xgN9j3i3jk855GjUP83+0O1Z4WSdHitmEsm5d5I3Kc/N1+tWVxuj+ZAqxec6lSQW6LHj1z3r6iLvqjwZqz0JYIFMkcZuTLsJeNlGAd38K1keJPD0HiXQdW0y5eWKHVbOTSrhIJfKnjMiMpZc9OD/jV+GaV48uBCGbMYROBz82O/T0qbypRdwrBIqRSsGkkZt7DA+9yOmK2a5o2ZhZX5onyton7OHi7w0LnT/DHxm8daLpFwN0llo2rXenKzfdO+OGZVbA2jOOhNd1onwT8Q2FheJ4j+JXjnxQtyUinW58UX0sFuP9lJJGXcenNfRdpp8k1xIkcyBkg370lxHyNrZY9MgZqTyhAskSeaqqjSSCM5Tcfxwc9j71pQwtGyfLsc9WpV5neR8w6j8CtflZbjwt8VviF4bs0/dyWUXia8Xbz97bHKq4IzwRWTceBvjJ4HvdNu9N+OPxCvYL+9WxvbTU/FGpXunalbyZElvcWzzkSIyrgq3HtX15bLDDBHLAJluJ/wDSLtJnXyWYfKOhzgrXD/ELUbC10nSrsQRwxpr1vGkkzd23R7txxjDHOKWKw1BUOaK6ovC15yrWl2PJ7Ox+Ick4tL3WvCJtmZkAt/D0yTggZVfM84n8a4/xx4t8Z+FNVsNC0HwtceLr+axa/lOn3XkJAittLfd7n8a9ssfE2hpcQxR3Vn5yZaVjcIWJ9evB/OrZ1zw/a3Q1aO8sDJHFJbwZvIo2ljwWZQxIOAeeTXd9Wo/V17KVvmcLrS9veokz528Oa58aNfuWgk+G9zokaglbrVtWjtLct/dVtjE5960/GbfGnSdNmisPBKatNdQtbB9P1n7cluzKRukj8pScZzw1fTVl4+8CzwB5b+yidxse3l1m3UxsP4jkkUxviB4MnmubaPVrENbRgGSTVbfZP/u4OCR9KSw8J0+V1ZfeaQquNTmjFHw/+zt8P/iFD8Wk8TeM/D1/pNlYaDcRG5niNrCzNGscSrljkncxr7S8daFL4g8NXVjHcXwlimhnCafPHa6hP5b75Io5yCULqCmSGxu6GrkPxF8KBtNtluRcJe3sOmgWmoRm5jaRvLjbywcsobOSMcfnXYZt95MayGQMyyecvG7PHylieRW9PCUFQ+r81rkSxFX2vt5I+jvhB/wVhh/Yn/Zr8dfs+fsBfstfFv4V/Fz4r6tb6t4w+Mfxc+IFr8RJLK8igW1+2aXapaxwbvLDqm9QFMmWViAR5z4c/bZ/4KNXklv4s8e/tj/GO48XxQl7A2/iOSCz0d3XLfuIwsBLfxBlOenFeYXNs8c0LBopGMYlLHgj/Z3Hn8BUxQXFus8Ls0gGJYTHsYFfbvkd64KORYDC+0mo3qS+09ex2yzPE1+SLk1Tj0uet3P/AAVr/wCCgVpbR2Y/a2+Jkt9YzfYb6U6vCtx5ittdnUxnnHIrzjXP+CsX/BR7xj4m0nwb4f8A2wPifZf25C0N1NBrKpLaeXtk8xXWMMrMitz2+vNfLXxI+Bs/ijV73XdD8R3nhy4vgs17Cibre7kUY8xlzncfUHHtTfhT8GLb4fXNxr+o6nLrWsywmFLoxZhtQ/8ArCp3HDHpzXEsNhY/uHh6aa62X+R1OVST9vGpJp9NT65H7Yf7ePg3Sof+EM/bI+OOhanNqA1DXJ/+Emm1G01W4bau+WOYt94j5ipVcZ4xxXlX7Tf/AAUV/ay+Nul+C9L+NXwz8G+PfiR4K0e58OaZ8aL3wpFquua7Z3Eu6N5Iypt1lC7VLBBnaD1+aqGqnACSkMpfzjIo3NIuFIVe4PP8qvaiqyxK23Y4tlhExGW6fwr7V5GNyzDYjEzqOK92zR7GDx9bDUYxj9rQ+c/gZ4Q1Hw/ouv614rili8QeMZluGhY+RJa26MWLMvTl+3YV61qV2Hg2QrILlURYpjID5yrxwc4+UcVauH3NFuLSyW/yAgEkBvvNnP6VmzXKLBbx7mSFCXTAJfnr39a83FtNcj2O7DRcYXNaSeHaIt0kqxptgOYy3Xhskgc+9PjdIZLiaTy5iYivmSKNo3Y42g5yMVl+Ykkcdu0jHAVpMncx7fLznpU0yGMRGNn2gb1kcMsUgXruGe1aKbMuV2uNuZZG2KyQpLvVyqIUkI+9nOc10MbwSQlbWEzCGPLLGpi8pum/OcnPQg5rHubqK5uYr242xyRqgKRLx8nTr60jXHnyRqhAAfczxMY95bn5sce1b0Ze8ZVI3NWzuvOEcU0LrFMd81woAwV7KOox70kapbWzXHa42+WgkO6QlsMdp9OKddRypHNdqUZZDseKLgj5gPwqtFC7RRLGgxNwjN8zQ85IH+NejBM45Wiz9DP+CcSRT+Ff+Cuekxea6at/wT7/ALTKMuQ7QXV9/LIr88tMaO70rRVADb9KtXjUgbgPs8fLN09K/SL/AIJfw+d4m/4KTaPHH5ial/wTc1qOMH7spt7qblh3OWNfmd4VCyeHfDc4y9u+h2bMpf5/mhhAyceteRldNRzHEef/AADvzCXNh6XobsDPE8ieW0iqwCLFmJ5B0zkelWIpUiV5CrysV2pG7Nk/3uPb3q5FLHAyt8z5Icv1AUfwlcZyKqor3M4uURpcS5lRU25+739t3pX09NWVzxJtdSZZCCXvYHtcHakQIYvuH3k9h1wa+bfH3xpufA/j+48O3WqafY6ZD4dtby2N1bRLNctK7K5yScnjI9s19LSeVcSpJKrOkbsQjvgJxgKAeeteZ+MPhL8PvGurw6j4n0WK/vxbNawXE0xhaGNG/doMN1wxAqcRGrNL2chUnCPNzxPrz9lXwB+yj8ePg5q3jP4v/wDBSP4X/sz+P7fxfdaLa/DrxVoEOopd2MMMMkN95iL5uJWkkXaB/wAs693k+CX7B+jwLb3n/BWH9nPXVhi2PqMPgnxDcPJn+95EPl8e+PrX5fwfs0/CeI718HWYUosi+bdySqv1BfPdv++q7uy+FPgPQLGKy0/w1o0dkF8x0SGOcv6buS3X6VzxwOZSlKX1iy7WQvrmBjBJ0Lv1Ptub4QfsLid3X/gsn8CtPtW/5c9N+EesTGDaPuqzQ7icdia7jwN+y7/wS++JOov4d8ef8FXPAPxB03a14nh/S/Amr+DZbiZMsk32tIS7BeuyvzJvP2f/AITX0rXsfha1NxdSefcNGDDCpP3lVc5Ax+NcB8Rvg7Y+FfDtx4h+GPh2JNc0m4jnVYXb7S0DcSRrg5ORn35rPEYHMqOH9o8Q36JGtDHYGpW5HRSP3dj/AOCdP/BFiRltX/bk0w3Un3ja3viK5DL/AHlUx4xXI6h/wTI/4I7TPIF/4KIz2lmSZI7aLwfqmpvH/eXfIvTHtX85Np8TvHcMflz+C/ELy2pwLgPLF5YPGOYySoNTyfFr4hlFt5PDmvRDcuVSaQRj5vu8Rjr05pUYVFC/1qrf0j/kZ1ZQc9KEPvZ/RppX/BMX/giFbNHJrv7enjnVo1P70aR4EurV5M/3m+yyACu/i/4J5/8ABvXZRb779qH42agYSFlnt9O1CME/RNLI5r+Z22+MXi+3ijiHhjxTbbT+88t/PDt7ho93HXOeK1oPjT4kgtWtx4f8XRwb96DaCHP8W48H8RV/UqdZ2niq3y5V/wC2mUa9SGsKEH/Xqf0J+Ov2W/8Ag3O8Cafa67o/7U/x+8Ma1pmoQz2WtafoOqa5co6srKqwS6ckZwVzhjj2xXEzeKP+CIifKn7f37TzrnOIvgbbPI23p832XJP1r8Y/Aus658XNT0rw7rnh3VovDdjetqWtajrSybHWOP8Adw7BhQSeAR+de8WvwL+FF1K/n+HoolAYCZl3Ju/h4z0rajkte/8As2LqW87f/IjeZwTtWowXyP0JuPHH/BGO2nB0f9sf9qvxbldj2z/AG0vHX6YMJH61LP8AEX/giO1nFbXf7Wn7V/h7UOZbqO3+BFukpb3V94AH+9XwVpHwm8EaBvutG0SyikmPkOu1m3oy/ewTiq+tfCzwTrk4e88PabcSWn8bW8aZ3fwlq6quS4uVNQWKnf1X+RNLNMNGUnKjH7j7E8Q6t/wSd8W6adJ+Fv8AwUV+MXgXxDOVgsr/AOLv7PIk8MsS2P8ASJ7VTJGMn7204GTg14D8U/gj+0V8BPCEvxlgX4f/ALTv7NsqHHxh+DGpJq+kQQsRuml8rDQTR9Xt7qGORNy7lx81eK3nwE8AX8PlN4bsv3qrDiEl5xk/wnPX/Ir6f/4Jpardfs8ftV6Z+zp421WTU/2Y/wBsiwuvg/4o8NapOZtI0HWr63ZdE1BUJ2rKlwyxeYOSkrIeNu3wsxwmOyul7WlUbt3Pdyytg8yqexrQtJ7W0PAdG1vT/Edn4b8Q+GNSstW8O6paM8U0QBlVmCmSGZfm2Sxj+H2rT1WN5QpWMcx7UiX5Xb1z/wDWry/4c+BtT+D3xl/aG+Bc8krWfw7+JN9p+nXUpYxQxwXEkW3B4UtHtJzz8re2PV7uVZLucxsZcP8AuHClzg/L246104S9bDuvU0lJHHiYLD140I7JnMTRxl4wiGKaQNGCG80DDBfmxwDj1rndUtEgaOJJoTJzJv8AmIwx6Hmu7v7ZWaV7aFRNn5JURg20cn5c4zjOeK5mSFYmR7pYDLMNiRTxtIzKBu8zhl4J43fpXz2Ni1PlR7eFa9nqVXQuPMUFSwVdjHBHXcuc9cYNTrbrshWZjKuzcQsmxWY9M5PAFe6/sWeKv2MvB3gXxtpn7cXwH/ak+KXxBuvHE2o+EtY+FfiyHStBj0d44/Lt3U3UJ3rIsnQEbWUe5+tdR+MP/BHyKW2vNP8A2H/23pYYF2SW83xNs4VutpzlmN8xH4U4zq396mzOcXvCSsfm9F9ldpE8lAXTLTyjcMdgGz1+gqG1gijO2YmOFX3mSNMvJjbhRz1571+kEn7U3/BJGx8sW3/BNn9ra+ypaI3/AMclg8zb/eUXhFdVd/tV/wDBNxbFLnTv+CZ/xXULb5+xaj+0bHBeMu0fL8m5g+B03Zrpw9WvzaUZfh/mYThHl96oj8zI7adoJLcQyKHzvIdSx/iyPw7VNHbORGYxL50fqnRf73pz0wfzr7yl/bg/YJtXI0z/AIJDeO9QZcO8ur/tJXsobt8zKcYz+lRr+35+yLb4/s//AII3aGIpW3Fta+P+qXbA/wC0FXv9QK7VisQtI0Zfecnsab3qI9P/AOCTmnXDePP+CgXiyeNF8K+HP+Cfev6J4m1Vm22GlXd1cTTW1vKx4EjpFI20/wAODwK/KfweS3hDwuJGaJpfD1mzhofLRv3UZHHXgHrX278Uv+CgnxP+LPwf8U/szfBP9mj4RfsN/s/+OriO6+LFj8N7yTX/AIifEuH5S1jc6pIo2pIECNhWbaxGcE5+SmjsbOzSyS02G3SOK3wx/cxqqxxw47BQq1WW4eqq1TFVlZy2X+YYqtGdONCOyI44QP3tu4MsKbpXfkfN1PvxUrJLahRI3JG9Fil2lj8vzHHpgU1UEIQ7xIrRbgo6oe2fXFW7aeTzVEkcTpEGQpImWKt/EOeor3VvY8sha5lDb2jQnO4N5X7zHfqf1qYBLkLHKI13/vcuxLSe3UgUjW5V9yIWjd/3PmNuGf8Aa56ewq6dNCQRu0YBlDCN43+Yk9sVtCmmzKpLQrNaFXMMaDcgUyTB87l/2V9R6VrQXbQ280MLRMZuYWlUlwQOmCcYz6VWt7GJU2yEmTaWDkEbcVdMMQt5GmkjSFDudgpfylXljyeBj0robjSp889jntKc+WK3Kh1KeD5buOygjjHnztIwi8gejqe5rzm9+Pfwf8P3zaXrPjjw4l0XYTwwXTXcsB6fvGRSuQeMdfavO/it4ovNV8Jaxe6JKcXSw6XoM0btFOzXLLFHJJ3H385zxtqT4cfBj4c+ALq00hNO07xJ4sk****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[/img]
The item at the top holds the lug nut key and the black item at the bottom is a tow eye. It screws into your bumper behind the approximately 2" by 2" plate on your bumper. The jack is in the passenger side well and on the driver's side of the trunk, up on the inside, is a Lexus first aid kit. It's held on by Velcro and measures approximately 8"x8"x2".
Here's a picture of the tool tray:
[img]data:image/jpeg;base64,/9j/4AAQSkZJRgABAQEASABIAAD/4RcERXhpZgAATU0AKgAAAAgACwEPAAIAAAAGAAAIngEQAAIAAAAKAAAIpAESAAMAAAABAAEAAAEaAAUAAAABAAAIrgEbAAUAAAABAAAItgEoAAMAAAABAAIAAAExAAIAAAAFAAAIvgEyAAIAAAAUAAAIxAITAAMAAAABAAEAAIdpAAQAAAABAAAI2OocAAcAAAgMAAAAkgAAAAAc6gAAAAgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAEFwcGxlAGlQaG9uZSA2cwAAAABIAAAAAQAAAEgAAAABMTIuMQAAMjAxODoxMToyNiAxNTozMzo0MgAAI4KaAAUAAAABAAASgoKdAAUAAAABAAASiogiAAMAAAABAAIAAIgnAAMAAAABABkAAJAAAAcAAAAEMDIyMZADAAIAAAAUAAASkpAEAAIAAAAUAAASppEBAAcAAAAEAQIDAJIBAAoAAAABAAASupICAAUAAAABAAASwpIDAAoAAAABAAASypIEAAoAAAABAAAS0pIHAAMAAAABAAUAAJIJAAMAAAABABgAAJIKAAUAAAABAAAS2pIUAAMAAAAEAAAS4pJ8AAcAAAPIAAAS6pKRAAIAAAAEODkxAJKSAAIAAAAEODkxAKAAAAcAAAAEMDEwMKABAAMAAAABAAEAAKACAAQAAAABAAAA76ADAAQAAAABAAAA1qIXAAMAAAABAAIAAKMBAAcAAAABAQAAAKQCAAMAAAABAAAAAKQDAAMAAAABAAAAAKQFAAMAAAABAB0AAKQGAAMAAAABAAAAAKQgAAIAAAAhAAASYKQyAAUAAAAEAAAWsqQzAAIAAAAGAAAW0qQ0AAIAAAAjAAAW2OocAAcAAAfeAAAKguodAAkAAAABAAAQPAAAAAAc6gAAAAgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAMUM0QUY0RjkxMDg3NEMwNjlFNzNFMTFGRDU2RENBODEAAAAAAAEAAAAeAAAACwAAAAUyMDE4OjExOjI2IDE1OjA0OjM4ADIwMTg6MTE6MjYgMTU6MDQ6MzgAAAFKXAAAQ1MAAtULAAE+swAA+HUAADgUAAAAAAAAAAEAAABTAAAAFAffBecIqQUyQXBwbGUgaU9TAAABTU0AEgABAAkAAAABAAAACgACAAcAAAIuAAAA7AADAAcAAABoAAADGgAEAAkAAAABAAAAAQAFAAkAAAABAAAAsQAGAAkAAAABAAAAoAAHAAkAAAABAAAAAQAIAAoAAAADAAADggAJAAkAAAABAAAREwAOAAkAAAABAAAAAAARAAIAAAAlAAADmgAUAAkAAAABAAAABAAXAAkAAAABAAAAAAAZAAkAAAABAAAAAAAfAAkAAAABAAAAAAAlAAkAAAABAAAAAAAmAAkAAAABAAAAAAAnAAoAAAABAAADwAAAAABicGxpc3QwME8RAgDdAN0AkwDcAHwAfQB8AIAAfQCEAI4AjQCJAI8AlQCRAOAA3ACXAOAAfwB/AIEAgwCDAHUAgwCIAIsAiwCMAIoA5gDZAJoA3wCBAHsAegCCAI8AgAB2AH0AhACJAIcAigDlANgAlwC1APkA/gD/APoACgGGAHoAcQB6AIQAhgCFAOkA2wCZAIoAhgCFAIcAiQDmAIYAgQB5AHUAewCBAIQA6gDWAKEAjgCHAIgAjACPAOcAgQB7AHkAdgBvAHsAhwDgANoApQCRAKUAgQCSANcA4gB4AGwAaABtAGkAhwCJAN0A3gCcAIMA4ACHAPcAogHOAG4AagBfAGQAaACCAI4A3gDVAIkAaQDvAIMA+AC1AdAA3gDvAJcAYwBhAIQAjADjANMAnwB4APsAfQDNAPEA6QDEAKYAfABjAGEAfwCRAOAA3gCMAG4ABQF8ALcA1gDbAMMAhQBwAGYAYwCCAJIA2QDZAJ0AbAADAYgAjACfAOcAxACxAHIAZgBuAIYAlADQANYAqgBqAPYAvwAIAQgB9gCvAMIAcABrAHYAlACdAN8A0wCqAIMA7ACQAPMALQHnAHoAbwB3AGwAdwCQAJgA5ADBAKIA6QDmAIIA4AAcAdIAYABRAFIAaAB+AJoAnQDhAMQAwADpAIcAiADPAEAB2gB1AHAAbABqAHcAmQCgAAAIAAAAAAAAAgEAAAAAAAAAAQAAAAAAAAAAAAAAAAAAAgxicGxpc3QwMNQBAgMEBQYHCFVmbGFnc1V2YWx1ZVl0aW1lc2NhbGVVZXBvY2gQARMAA80bmLFSYRI7msoAEAAIERcdJy0vOD0AAAAAAAABAQAAAAAAAAAJAAAAAAAAAAAAAAAAAAAAPwAAC6oAAL/T//+y/gACkZ///7dNAABIxzlCRUQ4RUM1LTUyRUMtNEU4Ri1CNDU2LUI3RkEzRjQ4RDgzNQAAAAAAAAAAAAEAITL1AAf/8QAhMvUAB//xAAAACwAAAAUAAAALAAAABUFwcGxlAGlQaG9uZSA2cyBiYWNrIGNhbWVyYSA0LjE1bW0gZi8yLjIAAP/hM/5odHRwOi8vbnMuYWRvYmUuY29tL3hhcC8xLjAvADw/eHBhY2tldCBiZWdpbj0n77u/JyBpZD0nVzVNME1wQ2VoaUh6cmVTek5UY3prYzlkJz8+DQo8eDp4bXBtZXRhIHhtbG5zOng9ImFkb2JlOm5zOm1ldGEvIj48cmRmOlJERiB4bWxuczpyZGY9Imh0dHA6Ly93d3cudzMub3JnLzE5OTkvMDIvMjItcmRmLXN5bnRheC1ucyMiPjxyZGY6RGVzY3JpcHRpb24gcmRmOmFib3V0PSJ1dWlkOmZhZjViZGQ1LWJhM2QtMTFkYS1hZDMxLWQzM2Q3NTE4MmYxYiIgeG1sbnM6eG1wPSJodHRwOi8vbnMuYWRvYmUuY29tL3hhcC8xLjAvIj48eG1wOkNyZWF0b3JUb29sPk1pY3Jvc29mdCBQaG90byBHYWxsZXJ5IDE2LjQuMzUyOC4zMzE8L3htcDpDcmVhdG9yVG9vbD48L3JkZjpEZXNjcmlwdGlvbj48cmRmOkRlc2NyaXB0aW9uIHJkZjphYm91dD0idXVpZDpmYWY1YmRkNS1iYTNkLTExZGEtYWQzMS1kMzNkNzUxODJmMWIiIHhtbG5zOnByZWZpeDA9Ik1TSW1hZ2luZ1YxIj48cHJlZml4MDpQaXBlbGluZVZlcnNpb24+MDEuMDA8L3ByZWZpeDA6UGlwZWxpbmVWZXJzaW9uPjxwcmVmaXgwOkNhbWVyYU1vZGVsSUQ+PC9wcmVmaXgwOkNhbWVyYU1vZGVsSUQ+PHByZWZpeDA6U3RyZWFtVHlwZT4zPC9wcmVmaXgwOlN0cmVhbVR5cGU+PHByZWZpeDA6V2hpdGVCYWxhbmNlMD4yLjQ5NzU2MjwvcHJlZml4MDpXaGl0ZUJhbGFuY2UwPjxwcmVmaXgwOldoaXRlQmFsYW5jZTE+MS4wMDAwMDA8L3ByZWZpeDA6V2hpdGVCYWxhbmNlMT48cHJlZml4MDpXaGl0ZUJhbGFuY2UyPjEuMDUxNjE2PC9wcmVmaXgwOldoaXRlQmFsYW5jZTI+PHByZWZpeDA6RXhwb3N1cmVDb21wZW5zYXRpb24+MC4wMDAwMDA8L3ByZWZpeDA6RXhwb3N1cmVDb21wZW5zYXRpb24+PHByZWZpeDA6Q29udHJhc3Q+MC4wMDAwMDA8L3ByZWZpeDA6Q29udHJhc3Q+PHByZWZpeDA6QnJpZ2h0bmVzcz4wLjAwMDAwMDwvcHJlZml4MDpCcmlnaHRuZXNzPjwvcmRmOkRlc2NyaXB0aW9uPjwvcmRmOlJERj48L3g6eG1wbWV0YT4NCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIDw/eHBhY2tldCBlbmQ9J3cnPz7/2wBDAAEBAQEBAQEBAQEBAQEBAQIBAQEBAQIBAQECAgICAgICAgIDAwQDAwMDAwICAwQDAwQEBAQEAgMFBQQEBQQEBAT/2wBDAQEBAQEBAQIBAQIEAwIDBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAT/wAARCADWAO8DASIAAhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcICQoL/8QAtRAAAgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS0fAkM2JyggkKFhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqDhIWGh4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uHi4+Tl5ufo6erx8vP09fb3+Pn6/8QAHwEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcICQoL/8QAtREAAgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMzUvAVYnLRChYkNOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6goOEhYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU1dbX2Nna4uPk5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwD5Tg1+0srzQotbvZ7exFqsWpaVbH7KzSTKq7mkcriTezFV4DeWflOa9B8B+HtL1611bTNe12w0fxDfWAuNJh1DVoYtJ1CFVkaXcZH/AHbMW8wIOF5y3THhQv8ATdftbCTRIXjK2k15fC906Sa5eRdqtFvDMNzeSsm5eAd2MDite9sZdO06FNRjsr7UtQZ59bv5GkuhdWdz5ckfkR9nUuvyoAcKRWDi9mdTbaN+e60vSbi6tZY5JjeGWOC6u7SGKxsRGwYR20mW80Ns+VhtCk1ixXOi+JNeu7aOWa1kljW7azmvFbSBGqxiRiWIcO5GGO7vximaxLYzaXDHa6RZXusaZNHMbuGfzI9QtJIWaSPy0AZT9wkMdynPGOayNTklm8PWmoT6Xbv50ENndasqvFDaIobbGGBJw/llsnIIXr2raGi0OZtsYbSxg8Q7VWHUWjgWWY2E2LhI2ELSNAoK796+YcBuChxgcVF/alpYz3+jTa1dXfhrFzqGl6TZ6fJFaaZdSbMqGPzOWH8BXGdw9GO7pM+gwT/ZHtb+5s/sbeVL4cma21C1lURhbqBCu6aPyzJutmKlt338GrHiHSfDC6ZY6p4Vv73Vrn+0rq7js9RtJI3+ytGJo3umVykciht7Rs28eUAH+XFaqbbCy5bswtQ1TWbm8l16/bSIru5sxpzNa2zR3GhwLyrOufL3Oisgi3FlGDgmq+u6hpumeHdUmttTfVLZrn7ZPbGzMI8QYSNpt2w/dwrdhtdsZzWT4c8RXuu6HD4c1PQ7zTft2uySC73R/wCkr/qfNmaQh2Hzxnj+Hdj2ZLpVnHol7oJ1USWsafZrKZdUVpbTe8ZaBYWAyGIaQnkYK5Pc1yRlrIzU5X0KOm32imeaS9ilgvdV0xprSz06L7TJdMNslqzMjYIRGkDeXlv3fIGKvahaa1NpXiKBru8msfDSnWbXVYbdL3T4pvtAkt22+YrHzPM2gsGbKuduBiuQ1a21Xw6+LCaOfWrUR3Fle6VDM2pWENzDNHJJIwIMZVQRkZDbj2rkofHvjPT4FuLXfrdrdSx6pqx1aJrwGXcoW3kDbWdWBb5O2/0BzNPCvEVF7Pq7FTxHsablLocNr3i+eO7g1K7vtVOoWazLFp8cZiiEcg8tmw5CgOeeMFevHJr0I3hFnpFvcXkWo2mtwrPaQWTRw3SRldk8Plxn5WDtAdrHaxiOa8gvLGy1G5uXZD9td/tDW8yMIlYqdzdeMllH0rNuJr+1uZhb3DQxx2TSxFf3kihgu5dy42nO45r7ahwjiKmHTqT5Zeh8tW4mhGrouZH05oGoqNRXRodEtNFuLWdbO9i1aM+bZw20bCZgJWO1nMcZKY+VnODg8e0z+NtC8J6Eq6LcajcaldXR0SJbG3mubnVLOaeSS8kj5VIovLkVXRQPm43YNfnZH4y1nS2s9UE2pNrbJJJHrjz/AGuacvuG+VpNxY5Vhk99tdF4Z/aC8SaBYy6b/YWl6/BeX0in7dZMJ2mmVQ6rIjhgpB7Y+bBzXJV4VxMWnzo6KfEdKS+E940LxNp0g/tFZLt9bN80Fk2sagqaOjwzZeFQclWYthZAfmAZTmtLxx4ik8S+IPEWs3Vta6ZqFl5eqXJ0S7htrG7eONYQzON480K4XZGe27G4HHydL8Uy+jR6Bc6RAt0sjCN7gfaLiJmZniVZXyVCu2dm5t3Tis+w+IPmXEVvN9qgtiWi1tmfzheRqqpHhVCnKdRyMFV9K86rkeOg9D0aebYaorSkfXt/408H6Npml2tvbiSaxurfVXjEMc6WLSL+8WWZF/fGQyOSu35Q2DXE6ZcaDq+q61d6t4hSx1PR7Sy1i00LUtPksrbxCtxIjXVlHNA3ARZIzH90MvPykV4nd/EBJbOIvNdXVvp13cf2fbRKtvEnmorpNw24M/7tShJ70y3+Imn3stvrVxbSwa3AI4YJrkrLZI0e3/WQBPncxxqFC4GTzmuSpluJpxvKDOqhjsPUlZTPdtH12N7mG41lpmtNOkeT+ykk8qB2m+b5p2BDk8gncxwrcjJr0G91a2trqOUWpg8Pre/Y7q0glW6ivbW4gSTzJo8+YWSXDrk42rtBA6fNs3i+HTNRhgspptR0ua8jdF1a38i3SK63bmjgU5DNudTsYBd33s8V6zo+vaclt9qMsJ8y7m0mW+e0mjstHaaPau6PLM6oqsAXy3ccV584uD0OyM+f4jsYtei0JH1HTPD0Ft4aiMjXbQ3ML3F68jMkq/vDuWSLzrYnd/DH8pB5r1rQPiJBrq+G01XV7aS0026ewV7ST7VdmFmaaR2HykOWbcd4G5n45ya+e7++j1iyjshJD5X2D+0LxzaSSR3DRyL5KbgcqMRx5Z2yfpXN+JI7mwv7K40ee1bU7WOSeWSRo/sszKxZUaRSCxQNuXbgNXNWjzR1R1UZO9j7Hv8Axx4b8W6vqLaK95BAJPLFu14r2l3JY5jaRo22xKSQGGM/NzzXB6xr+oX8smjJdX801wrPbqbTz7hYZFO6OSNWPzoFUKMEoxGOwrzvwR/ZLXthrOuXK6cv9kCKayS8NlYLM8kmPMZRhlkX5+cHdwWqHxV4tsI/iLeXGhSPa6TfTxy2bPfi7vrdkZYTJIVA2Lhc7T97ruxWFH2nw3Omfs73R6Z4b1+zvNItrPSvEj20lyJIr+zRrqKO1uI2ZoJ5rgDylmDcqAWJVnzt7fRqeK9M1SFNLliu9asR4fbVbe90iGHQri11CK1jhkt2mufMecr5e5UjKCRpCRkHj5DttStpLC/8Py2lrpK2l+upTaxYX15bS7du/wAx7dpPKY4mY71XjccY7dWNdGg6lpW+50vW9M0KREj1ezupptMu5Ft4/wDWyH5vk8xRu/vZC4HFYVZpOyidFFXV+bQ9p0TW7HRNP03X7XVobI6ay2dtbahOttql55zMo+1s6AgJsUbQQp2jOcknz7xdr8yS2uv+Grto4Li9mtb+HS7qPULu4eHcf3mMNjdcKVYkjPCgEV4B468WXWrQ2+lw+Zq9lpwkkvL+KJoZZLic7o8zOQ06MPLfayrt3MBWF4N1d5ryZNS/tZ1lYS6rDYSG1/sm4jkWVZCmCV8s7tyHacg8Yxi4U7wvIzq1Ep2ifUA8Q32r6HpOgQDUdO1e81U2TnU428ySfdC/7ybeP3oG9SGRPlWPGTuNdJqt1HaXFguo6J9r1jWLBtYumfStv2ZZpMFTHE6h5N1uo3fKQvrXjEukut6muW+vJpkWnQTeI/8AhIr66kiiLQxs0OdoZxcSu0Z28t97nrXsfha/1yWFdWLWOkWerWcN5p2mWjy6jLrMm3FzdyTmTcu5mZlRzyFYgCnJR5Li5pHG+CdL0vRrfVNX8P39mz6TdRzi31i48tp45pBbyfZYyeVTd/qxuPllnJramum1PVdW1Vp9Gt9XvYkktNKe3aIyQyBkZrFH+Q7BHGeSpxIOCQ22DSRcxXOlRWlnJeWtlHM91Yafb4mjhh/eXEki70LBYixbJBC4wcECs+eLw3Dfrrp06S7t767kiS5edLRLSWSRmt1my5CoVUDO7K7WyfTrceeXMeXzNLQvQa5fWs8GmxanqqxPFJbauIraF9Pt52djaCziCKd6oyqzMxJ3ADgEHS0uRL/w3JpOt3cEtvoGqXvlxvp9vFDfDz42TznDglPmc/KCIxyu7NcVG2qTabqdybu41SKCV1nURmTSxLbyK0G6QrtcmPzF2qxJBPPSnS6hLdabPbzwX2n2+t2cd2P7PumhJVpt0M0NuV2xopV0EYcEKeRWpgVPDuvahaX+pajBaWN4NNbF5Kt5HZ6hCrM1rAYcsryZWa3OUXcNp4GKqRxatpupy6dJfLd2zs3iDVLJBuknkXe28xMyovltIfvHB/umqc2g28cuqGdYrfSoJUMzarPCdRl8zarMsKhSS3zEOMHDNknjEtroemtrd5a2+oTRWV9IxS8MtxdRX8Uaec1vDGybpNu3oV+Xucc1vGNveRlKT2Zb8TeJ9JlttCuobOa4utZ1BrW7ie4WCULDDHHA8K5wm0NJwSoJVD8wNYXh/Vjo1zousX1/e6xo6ahMbzSru0KR2Mq+TAx+b5HLwMOQPlOSFJqh4hisYLywvrC9jvRGFvIb97BbDTIpGZWkyhySkeWjJOAx2dBxXPXk/wDod22nx3GpX2syNcw6bprtcQIkkmbiaQjcAAPJAXKnPIwOK2hC+5zym18LO98WeLdJ8RX1xJcWAnvtTaSytbWyMlkfJhjaSKOYRtGrLCsh7At0zXjiPZz36I947wjR/tcFy1k0KR3CySLI2DwwQ7hxzjuetXhrWjR6MtkA0t9PcrcXUq2Si4t1DLuVZclkSQs25uCFQfMDzXK6b/a13qM6a5aNYRxRSC0sp42gkhRNrKmc/Nvbnb1+bnI5r3uGsPD+1KVN6rc8zOa3+wVJqWuw7VU09lE9nPBdSKEiltj8krN8seW/3iB+dcDeiOOCZ55fLWdZI4fKjw25flfHPZmPUfwiuwfSzI0lxZpsYNJIRuUSHzOVVV78j5TWd/Zr6hOsEaweabjyTJIAg3NK3yqQO425PQ/pX6/OlUtzRPzeMk5Kx57LC00T2siERNJGLIKVbfG3mblVs43ZjVsdyx6duajjlhCr9nDOwZLdUYQkd1ZmU8thcYrudRs7+1+1wRbN8EzKEyx2uoZeMsAAQ3UfnWFdaTdiOWYK32e2zNsjYtE6lgNzDdz3yBzhhXl1abUuVnfSnZHFXdsNTiF28Tu6XCxhGU+VGMfeyDgEHqc5+U8VJFZ28du0hjZZCWBZ3O5lwuAzd+ehPSugks/Jaa2ltH2yNvkWOYsRuj+UFs9BuJx/tEVJY6Vam3l8+UoIpDPu3YlUKq7U27u/rWEaDepuqnU52OxnjkkzAssbIGjhlZip3A7ZOMjrjbubouDTzZi0SO6cTvGR+5BG2I4Zfmz77cYz3NdGtsjGytfPdwzKZowD5dsOirycNtHPJNWIdKujFEgnna3a4jWILhpgzLyVAbjj0HpQ8IpK0jWFbktOJwdzb6wxtrm1u2VIE3xvPumlkVnDPCq4wFYsSCD2Fbmg6hr2kWZuodUvreW7vpbWfRYSHia3SPYLiRS+H3b8Irf3ZPY126Wttb3EdlvYyJgi8KeWTnaPvN/dA6H34onMUczPqyJfyIivDNa4jYqv3VYjao4749OuBXj1uGMDWfP8J61LPcXDTcxfC3xI8Y+H7e/0u1vtUFrqpS0uYIgoS7R2A2yK4KqO+Vwo7nFezaJP4eexYzR6raiK4j0/TtPu723urtIxtW78y5Qbc+Yw6jGAwHFectBpd05Wzi225iRo/OBQvKyqx2r0OM9ah/sNVEdvNI8kb/OYU4IOevDZzy35muCtwVRqQUqdU7aPEtaEuWVM9n1L4jeGNOtZNJu9NuNQaG+xeaYiLZ74+N0hn3MGkPddqqByFrAvPG1rqF/b6jpcpsLpbaO28p7RkidFEgMbMDyUHyg9WJrkpLKzRGaQzTzlFUTuu8t2HmMc5PualhsIzGrhlDE4Gc+XENrHkEdeSP8AOa0o8DYKMeSUnzEy4nxLnzKJ6K3jqXUNIt7K5l06KysrC4uUhjijtZ7cyKyYlZhulY4U4IPtVS71jNr4dhh1sQ2khWa4v5Zd1rcr8reX9mQbmUSR7Cp5JxjFed3Fm75QFNvmKQTHuZdyjcueuDt4FVpNPcMptXeCZXVoUQshzn5WVs8YY5rz8RwBSetKtY9GhxZUiv3lPQ9PvIYtTRo7nVbXS/t2o217qNvZWTQ31gsk3mNiPhQI1LYEbHcwKnGK7uC90WHQX/sbUNTt4pNeNzfXUd5m41KTc0cMkzsMxuygs+AA6yYyxFfPS215PIbqfULpbicSfaWkcuzbfmTJzjLNzn3OMZrs/BXiNfB1lqNvd6dFrUt3BMipdXUsCw3MjRsl0wV8SSRhpFBYfxGvBxfCePw8P3dRTseth8+w1f3px5T6j8F+Lp7VDp17YWGo6O+n6lBLp8mkyeZdMqKbe/j4VPNRDHywzhSdpzXZ6dMNKttPu9O8S+Fb6XW9Oj1gaTaaqLKHQ1keaNbeQ5H7zCs5GBt8wAV4V4S8Y+GfFNreWt1ft4Y17TYWEZtJPIh1e2eElkeaST/WIyIEULnBI64NdB4c0618Qwy2WhaMdTlSBV8q7CtqNtcK26YMqhTIu1eQclSwO7HFfL4zBVKH7rEqzZ7dDEQqw5qWp6xrHh3SWt9JTSdTsJfFV/YRJe25uDbyXE0YVvO+0H90JMRksxZcDj0xz8tt5PhKw/tSQ3Vkt9NMllPdLKdQkgj8uRGUA5O+RmDBwCFbAqW4sNFvdQtJr3V307RdtxNoiaj5dpe6gFXbGsgTKnLAOCd+Q1Vn8GPYwGTStRjvX8r7XeW13BJbIwlVfs8kedrKyluQOrZOQOB0p3VzyW7GS3iG20XSRp9vDeNZarfRk2FwWFlbeVuVipBbkbhhutdVpd2tzpWpF/KNhp+mtdW7SR3Fxeamq7G8i3VT5aTYZyskigfKQ3B4zfFN7beRpumXUIVbZGuFv2bYlxcmSG3KysQdoYsR+oFZXnW+hw+Tp0Wr2zqrSXllqDJdWmreXNIqtDIdq+WRGq7D2jzuwa2jTTV2Ju25DqF9ZS6bNP8A2p51jLdxXGtweWsuq2TQny4VWZ03NHjY7GMbVEnOcGqVrqGkaTLb2esQ6va2RsLjUdMkSHzTf3M7bRmbIKR7DsAXKswOAKxLHxBB4e+w3UlsGeWEyXiRPHfQukg2xxyQ5COikkKxwcqQD0rT1XxVoCz232mWedZIIrm102WKTzEgZG/dJG4EahG3EIVPEnO45x0U1dHLKdjn57AS34sItDEtrCGItr474biG4aTyJG+YMuF/ecDClQSOAKwF0ia01iLTre40/RZDZSaHNqbalJ9kvZGjbbIsgHCMfLjCn3zmrmq6iLvVJPEWma1eNaR6XI84mCxz3MqwlWt1UHamdrkcDKjjFeY+H5vEt5JI0epiyvfK+1Qai5F9YGNlRkXZtbDdjgE56V0QhKW7OZygtUjptSns7CEaZAbVbu1gk04Wsk8TLe+ZtaQLcEqqkszFc8heuOtOl1S9159SvJbaGxkdo7CyjAzFCkarujVizABZG+U7v0qzop0+91CLw7r2mS21jcxG61TVLER3uoXEa7ZxNa+eyxwv5bqSxbLDcPpzniWxfRdI8Kravcp/aN+s7MLgx3bxrHlgyjH3yoyCCQcHgHNfUcNUav1uVZR0ieNnU6f1WNHm959C0LLV7Oz1CzkihYyPFdNcrDvmt3RhHtSQcfxbsdB1rAisxNqltbm8e2iaUSPMqkWqzKNu1ivQH+6O/Iwa1rm4e7ns7WzM6s0o2s87GSVvvNvBOFyPXr7U7SZ9T0+7sme1Oo28l0oaCO7WKRmDj5iucce9fo7dblV0j42KpJ2Oc1SC5GpiNBvkt5jDJI8TGfazDy3I67gOc8Vhyadf6VeT+THdXYxJDa+Udu7zOFZ88EY6g/3R0rhP2h/Emr/8J1p2nWesXGl2msXc01w1lcrbzytGq+WpmU8EdK5dbfUfKhe21/xX5rrzH/wkcg53ZXa2epHFeY8VWrYmVKnC6idv1SnSpRqVJe9I9Rh02b7UbdLURyQ4byzGbhJ1ZV+9z2PJ59auXukXF0sy2+ng+ZbN8ps9mGUqPmfAHAGa878MWfinUbseDZvHGp6Cuu6rst9X+xvfa7a4jH7mKYEM28hVH8WT2617d8Tv2VvjD4K03QbzQ/GvxGjm8TeCpPGdpBrusLps0yDeqjcpIjMgjY+XKysRjFYVMZiqdeND2PvM6qWBw9WhLFqppHc87GltAizRIBcIV2QSJIwbzF6r16Dqw/ACt2PTLqSyS5+z31rchm2Qi2kRpM/xKOSQOxr5tsfCf7XHjTwxZDw/pmvSaTZX8NjF4ptZ4rNppp5Ctvb/AGySRSzllYbfvDjOK8s8Y2X7Svw91e00nxn4j8eeHtUuLT7VFFqGqyGe4t3Yr5i7ZPuErIP+A5zg1tUrY2l788PJLzIo0sDV92FZOW1kfcqpNMRGvmGWHcskccIIf+6zgZGfUnFXZNGu0yrQs42AkPGtwsR+9tI9fevhjWPHPx51SXRfDTa5f6NPpdqqpPpsItr7VfMXdHJcSFvnyrKckfxDmsGKb483lm13ZeLvGN1tvfsFwtnfyXM7OV3L8i/MwxzkAdO9ZrMMS3yqmdf9n0IwUnUt59D71i0m5spkeRbiRGjVTIYWiVGUcspAwMY711FrZzMyXBiLgxsmHfDdMbtu7O33r5B8KWH7U+oeHdX8O6dpHiq/mkuY47rXLvSLptR0kScrsZtu1m7bvwrodU/Z/wD2xdMt7Sa71bxZp0sln/aEkOuX0OlXFvb/AMLfPLkqe22pePxcb03RtbvoUsvp8iqxnf8AI+nltPKklQIGuGg2QtPDtVdp+bao6+xqstnqCzFJrdzsYSzK+4Rnsqn1z7VzXws+CH7QPjj4e3J8TfEm18GWVlqf2aPxFf28mtatdShvMKQrE/mLjb9/kY6V6T8VP2NP2g/hx8KG+JP/AA0DZ6/ofnW6RyJ9strq6859rIisTll56n+E10YLFY3Moy+pqMvZ/Frt6k4rB0cEozxXNHn200OTvoLlIUkaG8t45FbYPJ8tpSgKkqWGCAe9ZWnxz3EM3mQ3DsG+VdhCj8c8A/WvM7e88XHw7a6dqfiO8kvInzLqlo+27m9mkbpnuABmuK8Tal4k0/TtTbTfF/iGOeysEvSx1YopXcismwdSCw4qK9THxp+3lBfeTRjhJSVKNTU98IuAzRSWckRVv3S7lIkMarvVu4K7t2ahfV1tYpP9F8yeOT99Jt+WFfuLn12k7SO49+a4T4J+Ite8SeFNZj1u5n1m4tNSY213eSefPEohXzlLH5jyVIySRXcTqqxLA7qTOpkj3Ju3s3lvtOOTliTj/pma5rqth4ztbudFNuFdwcrlGc28kUl9BDMbm2ZZXuHl5j6bWXtnKj6V9a+GfiFd3mjaJrltp1kUsw9m0GnK1qocx7ZJJGjGWMhwd7bvmUjNfIc7GG0urSNonECpA9wq4jL+YfuhiC2Rx0PNei/DXWZdL029jeS38kXbOLeTaWfcqbdvBI27pOOnJ7818NxRhfaYbnerR9XklZ061k7H1gLm9uPFsV3NeRXt/pVvLHY3KQLNpstv9kZriGGOT5PlT5AWw3yodzE16Imp6OLXULexuoDpLQ4a+exkMt42yCRYp1DfuyGDASLwr56jpwEkuhaXoFr/AGTq1lcavdeZPqdpc6coaKN5FVU3M+550Xc6nCqAV9M1vHw7o66VDqMWspaNPqSWFnpm77ZeG0ULGt15IbOTKrDy2+Xax5718pBXep39NTAv4fDhnuofEB1IHWoZLWXUXupTH5KbZyfOPAPUKnfaM8HNazf2ZPpltqNjJdmytrSO1glSeaOTT7jLiN2LPt3Oq7dp+Uj0PzV12rE3Kz6Pr+vWT6Z4WlbUrcXSs2kSXUtvbwvcOzLuUFcKyH938uBg815Za+PNPjtpILu40290K61dltre2vHgk1ZYI7hWnVHyAsbsuAcjgDBrpjD3bmM562OfOk6Pc6VE0F1cR66bn+x9Isb6Rrh7uOG4eSZ7fbhF3Sbhsk6huveuA8RC7t3n1TUryxlKatNa2Vsl4susQfZ1hjZpoeWWOTdsUPuB8kgbSpxo3llqd9q1xcvaF5bbUYZIBbu1wko8kzTPsJQFCDHuHGBL1BFQeKdHnfSLi5u7qFbm3vyusNpjqbmzhLqnk3se4tC2YxsGcMGPfkdEaaRwzlzHIWF5a3EV5DfFLGWyV3tJof8AQLprojzI1eLaCylmXH1ADANiuf0OVrTU7KTTr3ULYvbLPqCWg+yTGNWjZhCxfkqFzudcDk8gGs/Xb61WX7NL9qjtZ4/OdUbz97SW8bL5h9TuwFPzL6cfLveEdKuNSsLhLwuNP3KtnbTQ77yPy/MIZbj5WAG6VCp4xJ9DXrZfgKmPq+woK7PMxOKhhacq1TQ2dA0e5l13T9bupLn+w0LRaJDcTrdarefuiqmRxk4UD+LjgVoeKorC71DTZJ57uJW14vesIxOtmnlsNoJPzMGbB7DjjgV0DaUZLmKy0uGWU+W2DDd/u1HlbmUN0AVc5x/dauUnsbyHT5YlQXKXGowvLPNtW4g/egHy2Y4G4/eJBz7V+q4fAUstwPsIR101PhpYyeMxjrTfoT3enw+ey2MkcggTymld/LeWbbu3J+HABJqO2Nvb6t4duVMm4SeTrEMny2Lb+Mbs9R1NVhKk0htmSVXSfcqrKwi9SzfOcelXLSea5uotOkJaeObZN5sirFt/vD5uTj8a9BNWSZytOMuZnzF+0NYSP8QfDD5ijjl1C5SCZRi3lVQP7vfB64qbT9K8pkklvHdZ4fNLCRmjC9dq88EdBT/2hkH/AAmvg6C3Dzxx6pcyLFb4jZflXdht3Qe+a2tHW1aaKCGaQuYNyBbXYM7FbDZYkjtXn4CH+1Vm19pHpY6f+zUeXsdr8L/ANr8Qvi58M/COoQ3j2Wv+LbPT9QWyma2vJbdZI5JfKkB+Q7VYDH86/av9oXwZ44jsLGx+HHjDVtNuI/hfqGiWmnWFpdX8eqw201wtvZPdOpt/3auy+ZIwbKmvzD/ZXS3sP2qvghdXkazW8fi+G9Kl2WE+VFI+dwPGcYxX7e/FbxjeaD4h0ewvJkg8JXPhHVTHJPEscVlJJNLLGzScZ3bmGWOBuNdtPD4WWaYeWI+FytuYwxGKjk2OhQ1koJ/ij8dvh7+yZ8X9c8Hf8IZ46+K9/wCEPDs11D4qi8LeHpVu9eS6hHk29xO7ECPYrsuV3H5jzUuk/sM6bP8AEq01jxnrOoeJPDNhp0WlSWGozyXWoatMv8UkwC+WmNuVBYkq2OtfXup+PvBsDD4haJq0Gqa1o1s2iT2YvlSO8VW2yKyk8nOGVhXReHfjPoXi/wALavLYhdL1eC0kkvYpGE8tnIsfyTRsM57kZHU19RmssjwuX1XSXNUirrVv+mcPB+EzbHcQ4WOI/hylG6so9j5d8f8A7NfwL8P/ABQ8LeLtVex0mx0+CCxh8F2y+da6tKPlV5NztIcDyx2+6K6i48SfDXwMbvXfCHgTSvDNho+oeadTS2XT1uryaIxBWb78nyHhd2BXBz6F4g8XS6HrGuWkUcGkXkl3N4y1dkTzF2hlWJshnxj7u2vIdd8T+BfCum3E+v62niuSK+/tG3utdaa5CTLvVTa6XFgbflUKZ2UE98V+RvOMdicRSXMqEZW1tqf0biuH8uw+W4yrhKftoU6kvd6RdtvQ+ibj4wX99t1IRXFpaGI6ghthse7YbVVpFOSADnHPYV5/4r+NnhTTLKe98SxaFd6zqEHlw3uuXTa1q0EQyyR29qGfYFHP3V57ivn641X4m/G2KGPwha31vol1CqXEjRx2l1PIsjbI1WIqEyFYYy3y4Pqa/Uz9nf8A4JEeF/GHgY6j8S9S1DTtd1/SFudLfSc3GsRzSKGidFBO4lmALYAx91ia8Z18JPMMRiMXVlK32pSfLp3R52fyx9Hh3A0cHRjGEukYptt9Ln5seBv2gvEXhdbnVtBXUoPCUOoGbUdU8TXUGg6GGcYxDaRKS5PTYGL47ZqL4y/taeMPip4Ns/hHFb6Ang60uodfstS0SC406+3fvQ9tcRuQcl2Z/mycGud/a0/Z0+Inwlvb3Sf+Ee13R7b4ReK28GX1l4oh/syx1VpJCy6laRs7Hc6ry8mQodTuGa8Chxpxs5bmxmglu2Wa7ScMJJm+8zM27Lj5sjB2njB7V9BwtjMJi3N5dUgo315Le8vPufnfEWGx2EhD+0oSbt7vNdJDJYVdZcxJvWMKzsOF/wBrrjPvXmnjOcWmk+JTIxkkOgx2Ssqjy98lxbliefRcZx+Br1TVmtbVjKVkgguwq20iqzNJjnd14545rxT4i3CyaF4hk81ixubG3jWSTZI+6RpG6n0jFfR5qmsK1c+dy/3sRF2PaP2ebaKL4VXt4+ntm48STyR6kkwJlVY4Y5IhGBuJyvUnFdW0Mc2qQWUz+abj97GFGBGud278T9MZNY/wXhng+E+h2To5tdQvLjUEVJfKzvmKttbOSTjmu28OWdir6o7S2Ru7eXyYYHuVF95K8fKrHOd3GFFeFKTjRo049T3KMYurUnN7HK3IW3eazNv9p82UqWIXDDdlTnOcZOMDFafw51my0XxRH/bNj/amn3NnJnTmkW2g83ZuDM4ycgbuPYVDrF4slzeLbsJPLhCJGGaOSP0bd7enXNc9ZfarCa01BJUiuhJKYWmm8nz1YSK2PzyM9s14+aYSNSLoyPXwVeVNKpE++tG8NeHLzxC/iHVbzU9W06U7L7TrS4ihurVFj3feVCJHQ/dwGztA3cMBdvR8P9H1+9j0Y+IL3NxBLZ3SOIlihWNZJY7u1KljtY5EilAxU56jEcerRItxHJBJomoWUDvdQ2l1HqCuu2KOFflxkom1PMfdy/K/LtrK1CLzdN0XWpU1PR7a6ww1ZSt3ea1Luj863h2rtLRr82zIwsY5zk1+cxT2Z783G12VdTvLPVJtbgg3NNdCEXcayrLFqMlw6ugmUP8ALuEe7H8DADNc1p/w98PR+JLbTby0tra5sg1xd3aTyOixr8zPHGzqrBWDdGwwUk9K1YvDz6c9/BfwQahpjXCakmpkSW+ppcTwL9nhfd8+1HjJww2/N96uc8Ra3/bdxDdz6hbCay01tHXzCbeKZpoWihkjXIaNoG3NlvkO45IFdMHJe6zkk1fmL2r3WnRatqN3outLZXaN5GlX9q8jTa40sixn92mVTdG2NhP/ACz5avOdbuNR8NzSCSCO5voplmZB8/8Aa32iONo/NUtlgjbmYFsE8Z7VsanM2pNe6N4b0m1sNO05LEajNplrI9jO1upia4bDttaV1VvMyC0jHAx8tcp4Z1W313XL231TTpb2F3eKVXuWhNoCzCMPMckOu0I2MEhiBtIO30MLhq2Kqxo0o+8cOIrwoR9rV+EqaRplx4m1e6nbUprixhiW6N+YVhjDbdog8peAuBs2j7oUHtXp/wDZcUumrLY36R3eShtRGyyIDj5gcYOSM5+tRw6RaaXp0ljpzmOG2Xykcs0fy8/eYklyd2OPrRbZs7O3jDPdSsHMDh2E0auMY9MZ75r9byXKqOV4fliv3j3Z+f5ljamOrNp+6tjHSF9KQ3F/cPeXUXyWUeSIYgx3yD6/eAP+0awNY1OS/wBOjKxbIzdRI0jbTbn94GjXIIOcV0kUl2ZolvGiFs0eUeRcmLaD8xzznPcVnyy6XLass8O7yjG6ssylZSz7V+UnA+uK78TzOjZHFhr+295DYzdCVPttr9n818mQD93MzLtXO319qvWZsJbuNooJI2juI2kndlkaQ7k5Vcllxnkk8elQrPPBeva5cxpLmB3IMsHI27VPUeoqVI7mW++wvKk0P2j7RGYgY0aUhQWznaDxjBGK1pK9KLJqOXO0z5o/aDhCfEDwo9nNJIp1G5SIBiCv7vc31+ldVocUsUcssKLJJIAku8tvQfLtC89AB0rn/wBpJjpHjDwUssJbOvXEKv8AKMjyRluvI7Vl6VdRO0dyt5KkJZQvlbvssTdNuQckn0wa5svajiKzn3R143ndGj6H1B+z3qJt/wBoX4N3tzgwS+LobbytvKxtvjxj/gVfvF8VrTTvFryeHtQsoLnQ9P8ACN1PdwuMvJ5alVUsDkKWkr+cXwJ4osbX4m/DVzqkaXVj4ss57aDzks7mQtJGu3ceVAPO5unWv3S+Juq6inhGK/8ACV1Lq/iPVfD81hBp+m5nuL68jaFpLdCpO4H1HWumtKhGvhZ1NlPX5iwarPBY5U3b90vwaPg+T4WeFdCs9WnudUlg003dxcafNPMLZdNgkLNsLscMF5xmuX8FeLfhd4d1ex8LaDe2/jPWfE2ofYZdU1W5+yaDpnAKo0h++DjGFyT2qlpPwT+I/wAYNf8AEN58cvF7/DDw3oF1+9sri2KJOFG+a3t0DLG8sajBBYncw6V4CPCvgjT/AIgW1r4e8QFvD58QrbaTc6i+dSWHfsSSRYfuNn5sDkA1vnVSk8FVp5fh+X3d3udPCTqzzzCxxdfnfNHRfCr2Pe/H7z6t47tdD8YeI9e0hI2uNO0SLwzZrLoekzQtDGiPbFlISQFirj5wNrd6yJfht4Asfh3N4n8QWmteJ30/UV0wmaaPTvD/AJn2qRbeR5U/fOw+88alV7Fj0rXh+G3inXvijpiabNq3xG8J6ii3Os6vapNo0cc0cjRJJ51wp/ertUMQp3DI/u4+wrb4YWFulxa6/E15pOnWRGk+G2jV9G05jtkaTy+POuJG5aZ8nrjaOK/Ost4XzDPMbRxdeUowgk1HyTP3/MOJ8Fw9gMdlijFupU5ea+14ncfAb4f/AA61PwZpr+H7Ky8LW2ka/Z3d8I4pNTgsHZVWZopMnep++pbgDK8Cvtv4i/8ABQDwD+zQmj/Dn4e2cXiz4gPpP+la/q+orpcc8zsQjxybsxqsaqqqo4PTnFfFeh6rqcPhtdGsx9gtZrkG5tLVRsQAZjjIXAO1B8xGB7V8zfGbwD43i8YWfjzwz4fh8RXVvoC6VFY6p4dttfltJc+ZDcRw3JCOmflbBJGelYZpwH/aWIrYWhTnUlr7u1ziqcSwwHCODxuNrwhG8dVbTz9T6Pi+LzfHzxnqeo+P/EXwW8DT6jJ5urQ+O/F0t3Jry878W5bDhQeTvXA/i9PzX/az8JWPg34m6vofh4eCrnw1ptxDHpd34JljvdCkjvLGK6/cyLI+xfvfKWPzK3Sszxd8HNSvXg8ZfEfSvGeqa1qcP2nUIvCWm2mkaJ4aUv8ANELSPrtUcpGOtYfiS6+Et94E1PR/AbeKBrGmW8OovJqNi8FtKLLcp39lLpI+AOTWHD3AVfhrNY4+cZU+8fsnxPEPHFPiPLvqUJKpbaWlz5+uXjk32s8kSSGMqvnMDtVTwv3uK+Y/ifOVhkUkf6RrW3aCp4jjZh3/ANvAr2q8urXVWN416wZJGBjSUKW49z2r5q+J2qebeW0IcmNruaXG/eeFjVW4PPC5r7jOasZ4aKjLqfF5bTca1+x91fDiZ7T4Y+CIntzFbNpjzGVyz+Z5k0m7Oew+XHpzWpJYR217FqU83l3QldyqxmGQoyYHmenrzUvg0Q2nw+8F27+bO0Phezb7MjNNEjOiybWzwNwZs49q2ZLdriFriQB5nOzZL80yY/nx2rncIeyi1rZfidlKc1PXrucU07JeSFWie2R5JmeRdvns7JuKnH8JbAHp+dR3jwtbywx2lvLPPJHNDM533EUcYZQFBwozuOauajbzsWVVO24i8tYwSoGzDFuOmVXOBSzRWd3Y2/nxLnYojjE+3HG7p06FevvXg4nV3Z7tJp09T7a8ba3Y2f2j+0TaNPf2EmlWmvaTp6DR2njn3NcSb0xIkizMhaPaVYBhytc7YXcV3CsMesXGp21nPDFbJH5xtPOSIq0xjQrtZAw+YjLFlwRVvxd4jTXvDaeHdUWbUNJkeG4n1d5YDJaSKsG3awbMaMJMtkHrzyObGi6BY2tvf6ympWC2XhuKOf7ALiSMa3FcyQ26hZE5OxvLlyWI2xnNfnFOL36nuVJJHlyeNNUt7+Wxt4XuZtWka2mJka4kt1UN/o5RxyuPMywHAYc81xuspe30Fldxz2xUyNDdm23K1rIuI28yMgEdWHB6niu7uYNHTWv7WcQ3bJey3cxiv2FtbtbsuYIZgSW3g/KPuncQW6Y4LVb59WdU0+GczT6pI0JEnnNpUYV22cHYyuSrbm3HjivTw1CdepGnCN5M86tVjSpuUmZekWPiCSO7i02/vtJsbi4+zSiyvPJQn/WLnsVRhvxt/HPNd5pNjD4bs0s9NCklG+3yTReY5ZsZdpDkt075/lWjo+hw6LC0NvbIwJ3ukkrStux8zKzE4U56evtUaPDa3c1wxnkldtnlqPNR/XjPYV+oZHk8Mvpc8tZy/A+GzDH1MVLkXwkNvA9vNvurqQI8ZmwPnCf88156YPJOOlXXaaSzC2sRlhdvOLo+YV7Ku0nIbPXFSTIL2TgO6SfvMbldlwPu9M+2BUttbLBO8i/6qbEiJIDt9DxjrX0GqlZnlKKSUkQQWczCRHktZTHCscsRfy5k3t0Xr9KydV0+4uLEWUEnlwFFMc80Syurbu4wMqp5zW59lTbMrzOrXEiofJi3BFI6yMP5U975njWySLNrFGsVtIyFHfu3zdeTWsVTlTcZESVTm5onJLo2uIkn2nUWeUKJPO+wJHC0nTcGLbuV9KLOw1OS4mVNRWSV0UA/Z1bLK3++B+ldQbGe82ySm5hVFVY4pJ872X72GPfHNPw0MMsccZSSRsEtC0jfN23ZrZQhy2MGpOWp4h8a/hbF8U49Nm1XU7nT9R0aRpLaa1iERTdjcvpzjivK4f2bxaQ2wTx9ru5l3iKNikiqPvfx4/GvrtLKaRGiUTyPM25kkg3Mfz4FX2tHjB86ymjEUZTY8Q8xx0OMc9PSpjhsM5cytqaSrYjlt0R8yaH+zv4ek1fwq1xdahPrFp4ms9Vn1S4l3XN2vnRs0TNu+VCFxg9c1/Rtp/wsh0n4X6M+karNa3C63qn9ivc6bG9zbRvCpMca7gWADLjOe+civxeCPK1mYYzFJAw2NuYyDb93cMc/jX1d4p/bz+Keh+FY7R/DfhR7fSrhf7K1KXT5YbyOaVI7ZusvBcYJwDwOOawxVFU/ZzpxulJNnVgKspRrUqsrOcWv8jodL+GFlepq8vjbWNW8ZJealNqQsrydrTR7C4mZTM1vZxlY1Zv4icnjrXUeFPg/8M9FuL7Uk8P6Rp11AVuIYXt1md9vlttUuWwcL16818LyfG7xjqfmXU2orbPPP9rkgsdSktlYNjd8mQQM989K5u98b61qDsbrV55Z2iMe+bWJ7i3ZvXhw2cAV9rhszwVOmozwvNc+NxGXZh9YVSlinCzT93TY/Ra88d+B9F8Rzxy6wLW3iT7VaeH3dNM0mNVKq0c0y8SFmYnaXAx/DXB+Jf2jvAj3t6NR8Q6cj2yL/oWlxS3RRQNuyNY8g8DoOc18NHVVv9kbxWcksYLN9ou5DEdy/M3JPdc+tZyaxGod/sWjf6zB3Su0bL/D+vesIZi6FWUsNRSurLyPSnCriaSpYjESn1ld7y7n3MP2hfA+n2WnNp99ceXcnzv9H024mvYAo+9MgTKZ689aqW37WmhXVxJFdT+IcR4jtrq503alzu6+Wu7KgepxXxBeeJLmxsZpbPTNGllgiLwQyXMkIkZRubL+nv2roPC91a+KdB0nxBBa+UNTtVmNuo85IWXKFflG0kN6jpQ89xFGp7RcsZLy3H/Z9GtT+rSnKVPT3W27M+m/En7Rdr5V1Jp+nXer3xRhbxXBW3iaT+6zYbGeCT+lfKmueM/Enil9dGr6DomnWGrWL20WnaTM7RW0sihZLiSQMvmyhV2ruyqbjhc81sz6SzyJiPyIgfImRh5alt24Fe/50yPRJRExZZcNuXEbqEP0XOMmvNx2Y18Yv3s0jvwWBo4PljRi16HyTq/wIg1LUS+neIdR0a2kVY3t4XzGMdW+91OTmuLl/Zh0u9uoZr7xTq08bT+SS6rmNRs3fnX2lc2Esk8IEc4G3iNl2Z3dOR14pj6bI2wCylbdId3lEqjcDkc5yNvT618nXwuDTvI+koVaz9w4qy0+HTrKxsbZ1eCxt47C0DELhIY1jXcoPcL19zSzrLcSRMq+SzN5iszGKIgr03EYH411g0uctj7LPuXmN8c/3l3AnkeopU8OfEHxRqlj4R+GngXxF4/8ceJbtbPRfCXhvT5ri5v5B8vmSsOIIUyCzvtHpXn4zEUcPDQ68PSnOpojjPs8pWI2W8p5q73wssiYVkyo9ztyelSjRrawgmNxC13PkFk+zkjczsx2sDnAG0dK/Trwx/wRQ/al1rRNFk+MPx6+DXwp+JHidmPhf4KN4g+2eKHXYJE85UniUO23ARRI4Pcnivy0+K2lfFv9lPx54i+HfxEhTxBH4c1aTS9S0rUbk30W4DEN1Z3Wd5jYrgg5wQRXzHtliZu/Q+hioUaex9EHUbXVNG1vTdJh0vXPDlpaw61Lqem2g05NPMZXYWEhWWTyvOZHQEsxAO1sBqwrDxC17pkdhpUcuq6X/ZrC3UQ7Lq2jtpJl2qoI2go24hxwFyTit/X5PC+kWlxZXlhp8NsytbPHHqEltPp+VMzKbcNlgAhBBP8ACD82cV84+HdXurazvo9K1TzU1W9WGC3t3MktwpCr86Y3qBuZT/CV618jRw/tHFRizvq1mlzM7WHWrfUr8adBZXTC68uIwQSnT4oWXy1uNoxggr95U+Xqa2fDWlDw5CltPcrqWoruiiuLmdpNsfaOMNyAg4ySe9M0SyNj5E1zDM98tr9ljWMCVdOjPzNHG55xlDkjnHGa27K3jnkuriS5aBAuVh275DuPTnoM1+mcP5NSwcPrFaP7xnxWZY+piZezg/dQ2aWQ3xB3bXRUdFbeIyWzu/DrirKSQQi5VFSRlXMbSr5fln1Ujp9TUNx5vlsqhD5zeZFOwxJ8vpjoPrT4GKiJJZW2NuEsqIPlwPQ5r6Zu0TyFBt6n0z+yZ+y18Lfjp8IPjP8Atm/tg/Fzxj8IP2Mvgj4tT4a2GlfDaIN4++MniL9151raup3BQ00cSgcszHO0AkdzH40/4ItWaomm/sM/t3eKLAHba6zqHxfXRp9RX+GbyftalN/XBAxurZ+H8q33/BB7wnaCJJLfSv8AgphfJfB/3scu6RpITKv+9ItfFVzMyyMkM8atFKC5ziaXcF/Pr0+leBl+GjmHtaleclaVtH/kd+P/ANlnTjRXS59l23xN/wCCNShRH/wT2/bXd5I8bn+Oypu2/ez/AKf2HtT0+K//AARuTai/8E7P2z3Knbhvjwox273tfFVxZNbyPcXF4m9hu2pLuB3cKPY47U6GK3vmZLmV4QI22bB0ZF3fNz3r0lkeBejlP/wOX+ZxfXsRD7MfuP0H0r4w/wDBJmOxJ0X9hX9rrQY/MZZIL39oOC2uAehbDzydRnkVwd18Xf8Agj3fSzzXP7AH7at/ehts9zD8fxNF1xnIu1Xn1C18YW6hhGsqF0LttYsWDNnjcfT2p6K7SFjG3nK2wiPhG28jJxxXQsjweiUp/wDgcv8AM56mOryl70Y/cfU+o/Ff/gkFIrJB+wL+2/YyNzFPB8eI2YbfZrxunv1rhr74g/8ABLS6ZpLP9kX9vizUnlE+M+nTeWM5x80x4ryfULFtNvhHJd2c/m26yGS1m+0xDcPunjhh6VXS2kS384OZFdiXMeBux0XGK9ChlVGlpGU//AjgnVk1dxR6R/wmv/BMX/Wj9l79veOLftAX4taPJk+nEua39G8Tf8EnfEGp2+g+Mv2cv26tDt72VYrW81L4kaTqtvBIdu1gnmdRgYznFePW4WNDtiUOxwUK5GW6H61w3jiGe10u0uPKRXTV7YxSt8zrukVeCOeaeJy2KoXUpNX7muGqXqpcq2P0H0jwF/wRws5PNf4e/tmanEQsTxXXjfRbeM8Z2kKwb+ntW9Po/wDwRlijLQ/Aj9rKVtuCT8SNPhYZ4PPm5Ga/OG2W7jntS84EG7Lc5mPyleQT2ytYHjjWtU0iyto9Cs01DXNWuhYaVbOmEb5Wd5nx2jGM+9dccpoKlGVSUtP7zOOpiJuo1GMfuP0jfTP+CO1sEk/4UT+15JHIuY1Hxb0sINv6irMMn/BGLTz5l3+zZ+1hqKquTHN8ZLGL/wBBxX4//wBh/HQyOftHhs+YPMCt5xRM8kYP5VYbw98cpNyzT+FBhcqSsmB9McZ+tc8stw81/wAvP/ApHRCvUj0ifszH4u/4In2KC4l/ZC/aUuQUZg998dAo2heTxLj8a85sv2lP+COmlRPN4d/4JqftRXGkQzb7O6T4+3GnQXBZuHWNbnjPXdX5RT+F/jdfK1nLe+GRFLH5L7Y5iIozw+0euM19E+H9LNno2kWF4j5stKgtGwd8TtHHtZuemSuefU1yvh/B1XeLqL1qS/zOuGZ16Wvu/wDgKPtz/hp7/gk4w8xf+CY37T7iU4Lv+0fdAM3/AIEVDN+0p/wSumjY23/BL/8AaSdFOFaT9pu6gK+/E9fGhS2R1iFyuUODCRyuejUk7QopMgVQf4tu4H6Y71EuGsLHVOf/AIHL/M3jm9dqz5fuPvO3/aY/4J0Lo6JZ/wDBPr46tZNGwXS5v2oGe7jXumTGTnHA+f8AGvJbr9pL/gmOxYj/AIJj/tHICwfcP2prlSC3Xjf1Jr5Pk27pEEmxMblkkJ+Rcfe68fWqU6XUoV9jEhRExZWCbdv3uWHHfODn1rz8Tw/QUvil956NHM8Q4Km7fcfYdj+0V/wTMg8to/8AgmD8fLmWWTfCt7+1BdShsHO1sOOO1ek+Kf8AgqxYfD3QL7wj+xp+yp4E/Y/mutOW01TxW8i+MPidd26r/wBBKbPlsOocb2z3Ffmz8oRWBmwq7hIG+43y5289OTXKeNtDbxFpsMtgLZdShZvJu5SrFlZVDI/OdvPavFxGUUqMlUd2l5np4fHSqxdLYteBo/2hv2wf2h/Ctl4GufG3xD+JF343sNYvvGAurm/vdB8i6R5LiS+Lfu9pUlQGXOfu45r7G/4LreK/AmnfHzSvBmhRacmveF/Bdho3i250y7W8kvNS/c3FwLooQPORt/mKgO1pACeteUfs4ft3ftc/sifAXxp8Avgj4J8BaNdeL/EEmrXPxcsooJPG+nW80fltBb3ZUMmD8/mMGZASFZa+Lf8AhAvFHjvxXdeMPi3rTa/4g1W4uLuW1F+1zueYs0kks5fLOz+Y7MTuJxk44rgk6lSpzqKhFbeZ0UITpRfPNyl2Pfrrw3pV5fJd3UV1M86q1zPLfXEkrK67fmw+SSMDPoop+m+HdP0oPJo1haWcUTeXcTxyYmmLHgcnOfcHj1rfvrtLho1hCKwi+aVQVQ7Vxt2jHSmMUlit4XzbwOPMWdk8zyV9cDByT617saNGOkIpfI8pzm1Zt/eXJ1gbSbeZbmRLpHa2mgwrbPXB3ZAx35PJqvDKY7eR9gkiblzn59oPyj1OfSs4yEyMUkaTLb0DpsRwPvN19Oxqyt9knYI4W3qyBWVlQr0zg/jXfTcrpXOVwir6al6CfzZyzusMc6YMD7gGA+vT8KYnk3FwEffFCZSTcq+8RrVS4knuW3SNhvlUqD8u/PVT2HsaBNiZiY1hjlyU7rkL/jWkpPlM4xfNY+//AIMjzP8Aghp8X7ctvHhT/gpXY3KjqStx/Z4HToTvzXw3Es+6U7A7+X87NgcNjbj34r7h/Zqb7Z/wRe/bpsHXf/wjn7fPhPV2jU7QgmfR/mXOcFhxmviaaaYH7HJHGJSQiKCwkBTp0+g5NeTkUpJ14PpP9Eejm8LzotdYjGd32tEimcmPY7ruR9vDLt9ferscTTM1wBHDOR5h3qGLt/sVUldYbdJHYCQKYGEPCHcffPIqcFVhQxHzZduDHFw0a99ue/1r6Sm+54k4pF+2nuJbdlUC3Vp9xVAoLsPr0zVnzDGWkCRhJMuYWfBLMNqnj3rPTfITJNbyWqyDMJCYV/TrkZJqWOVonZGZzKGAdRHtQKen0r0KVmrs5JRbeo6OGBI5ZGlDrGvmFpW8qOLP8TN2A96t6WLnWvtVroMKarcWY/04aZ/p81kj7VWR1TOFJ3DP69q/Qn/gl/8As4/sR/tVat4yu/2nfi1LqXxd8Ja1fW3gn9i9/FsPwts/GEFqqvZzHWJ5EF/9sJAEcMihBu3A1/Sj+w54W8U6B8VvEPhSx/4JeeEP2R/hnp/gttLh8aNreiap/wAJI9vfRtb27yWyO9wdjPIJWLcofm5r5fMeLY5fKVOnR1j/ADPl+6+57OEyD60oynJ2f8up/E5rWr6P4akFn4h1G00G7KcW+rS+Rdvzy23rgDvjGcfNXmnjTxZoV7okEOjapba5evf2pjtNJ3ardymOZWbbDHlulf6Wr/BDwHpfjMy/8KR+C174V12XGpazN4Ptb7xncXswYtJcPJAyyRbtvzM+QO1ehP8ACL4YeHrS+1Hwx8Hfh0NYtbSS4sLXTvCOk6LNfTKjNHCLgQAJvbau88LnJ4r5yv4jSfLFYff+8eth+EIvml7SWh/mw/Dn4Q/tC/GW4isvhn+zn8YPG+p3kX2W1k0jwHfx2UqsV+ZriVUiQYHVm9a+rbD/AIJY/t0xaloGveMfAHw++G0di0izaN8Q/jZ4Y8K6ykNwixvI1vLdbldeuCOelfpP/wAFEf8AgpT/AMFA/BfjTVfhj4n8F6x+x94UBa303T/D9ms9z4it84+0R+JkXyZVZcDbbNHjdjGea/CHV/H1/wCLNavdS8Q+I9T8RavPA13d6vq+qzanfXO6XnzJHdiWyd2N1fe5biMzzbCRxEqlOEXty+/L5vQ+Tx+HwWXYiVOMZv8AxaH3z4g/4J2fHPTNKuLjRdQ+CHjLVkUfZ9I8N/HnwtJqk/y7vJUSXipye+7r618ZfEX4M/tSfCG2udU+KP7K3xd0Hw1CNzeLPD9jb+PPDUarndI19YNJCqhQW+/XEDWCLUvIyxAs2FjfbK3dvMbOD65NXPD37TvxG+EuqwP4G+J3jDw1vKxxW/hrxBdRSXz/ANz7Kj4kO7A8tkfPTvXpPDY2jG/1hP5I4VXws9qLOd0HxJ4e1rzDpd6st1DAs32G6/0XUdjsV8zyzyVyNuVz83XFat1NpOh6Xe6lq+pJaWVsfPmluSWXDNtCx9y3tVTxL441r4g/GK98TeNbIWXje88JfbPEDnw3F4Yuj5klstvNPZxwxIkjhTuby1LFy3XmuH1rXvC1n4tsZPHWix+MPCug6jaate+Fpru4s7bXY1bcbe4aEiRY5Nuwlfm+Y4Oa0dWpKHKpamsYxvzOL5SOHx9puoaZf+JrTwr4vvvDFjefZH8VW2js2knb97ZMQInIG07fMDfMBjNdjouo6F4m0m21jSdQW90u7YiGe2XzXJX7yupwUZc4ZWwQeOetf1Q/8Ehv2kfFH7e/hf49/s8fHb9k3wB4G/ZH0H4d2cPgiHQvhpceCfA0UbySWtzpqXU/FzIsQW4F0jeYhj3bgfmr5h8Y/s1/8G9Xwj8a694V8K/tUeJPD2vHUpl1nwr4O8a3vxG8O2EzSLHNGyrazRgo3y8TEjpk44+RhxROjja2AxFCUpR/l95fetj3Y5PGth4YynUS8noz+eLW9YXRwfLMYLLtcYzIV6LjuCeueeK8o8R+ONW8P2dpr9hdXD2QvYINS028dnhv4WkVDG0bHKsASysuK/qof9jX/g368RRrr13+1PqE813CN08nxW1Sx2YAGPs4iCx7em3aMc5rgPGX7GH/AAbzafpzXV9+1jq1pCqNPFLD8Q9V1Ygqpb5U8hgxAHyjBqaWf4epGUHhq2vX2cv8i62X1qclKnUiv+3kfz5S2svmhLVXEJjW5QBG2lXCt/e54wB2z3Fc9rWpW3h5Ije3KTHUbkWGj6VbW0l7rOr3DbVWGztYx5krlto2qCBnlq/dLSfhl/wQhsNKltIf24vihL4ehXyrPUb/AEO+L24f5RHDqBsiwA28Fl4r9Tv+CeHwG/4Ijx+O9D8Wfs/+NvAHxq+MOnzRtoOu/FDxvN4n8YaZLuV1bS9PvhFFGd4U7reEkEDJHWvNzbNZwoynSoz/APAWjrwVGMa8IVLXfbX7z+TnWP2fP2ofCPhuDx14y/ZR/aK8E/Dy4tPtt14r1bwHM1hFC+GimNupMyoobJyPuhsivJr23hVbHVNOurfUbO9sxdQXduQsMm/A2rk4yo4YMQwYkYr+i/8A4LZ+H/8AgpV43/a18XeBvhXp/wAaL/8AZzfwVp/iDSrvwxqi6B8NdNh+ytHqBvrvzIow4lWUyCVj8vtX8yfww0fV9G8DalY+IpYbhdJ8Z3lhDDZ6jFqMLbNscrQ3Ks6tH5qyYZSVbqDzXz+S4itmFOpLEVIS7JXvH/EfV5lQp4RR9jTnH+89n/hPVJGu7uOXGfKV9vKqpRV9cck1HaI7qxSIyZiPO8lXCqW27Sfw4pvmpIrtLCttBGAbrdw7Nnp7kdeKoyXEykLF81vH8yBVK49D6n6V9Ur31PmOVDotyll2RsN+Yo5GYvHuXcvQ8dK3ryE2mmw208ciTy7bi1V4vJIRjywJPIPvWERLJErH73QIE8t/rwf51pXDTXsccl27MqxqkKyNvMcY6KPm6Z5xXRTmzBxV7iLvFuIk8uUXB3NEikzQmNuDnPU+1OgiZ1XOBGE2bZEIKfrS20Mglja2mRzIcARqZDG2cj5e3PenmCUyP55Z03lMKdjt821m/Adq3inJ6mbikro+8P2UiZf+CTH/AAVS0ggySaV+0z8P9egCjDN5kmmqm3/v319RXxJdJJCLkZkjmeZ2M6OXLbsnaee4wMV+jn7H6aFL/wAE/f8AgqZHHdxLaeHNX+HHibWkePbGjR3Ejbm91DRnOP4a/Ny3WZppZDidftTMsgfdFJtP3sdf7v6152VwhGtXV9eZfkjszPmkqMn2FtYZQkfnFntihk8ry8sv97dzxgc1pq8fl7Y2hRYUYOxm2SMD9RimrDJJbzRSbTK586N14YA8MOPaqwiUxyrG0fmwAbYw3mPcH+X5171O0XqeJKLkzZsRc6ioiWbz4bOBpIk5OT7Yz065zQtwqOQkgM0pMeQu3bjpuJPrVa3C2hiVJwqyjaTb7lPuvX86hmktLaJ7iV44AkTSySTyCO3tfLBeRnYnHAGdxwB3rsVRRV0csqbmzmPFPw98MeLUhm1KCSHU7SX/AEPVbSVrDUrGRWG1obhcMCDzkc8nn0+2f2ef25P23P2ZtGXw54G/al+Kmq+HEjW203RfGupxeOtO0uMfKqwC9jkdAB/dbHFfLHg+Sb4jwajc+BdH8S+NbSzc+bN4Z8L32twxyMobbujiI45ORkV2Y+H/AI9hsZL3UPAXjPTbC2ZTJqWseEr7RoI8fw7polHT0qJrL8XFLEQjL1Qk8ZQ96jKUbdj7Q8Rf8FTP+CjWt332rT/2svF2giQbGtbDw1o4tTjJyqm1OMZ9ayLr/gsL/wAFFPhLBpfijVP2rNS8TaTDqlvaa3Z+I/B2i30JSZlXdtW3Vhj/AGTXyRJ4Q8YRwRXkHgvxnfWlw+6C70nwhqOpwwj/AHooWXH514J+0H4L8e6/8ONTsdG+HXxAu7r7db3t7Nc+BNXsdOsoYW3TTXFxLbrGkSKrFmLDG4CuHFYLJVStTo0+b/Cjtw2KzL2l6laVvU/bbT/+DhLU/G3hK/8ACv7Sfw5+B37RvgueNodR0vX/AAtJoN3PGy/N5e0NErYA+ZYs5Oc18Iah8c/+CVHxh8WXMvgX9k/9oPwtrGoWsl/qVh8O/j1baf4a0eNZP3q28N9ZuyxszZCj6e1fhI3ww8YXYYWOitHcxqPPSO8Mwk6LlFbkA46c969S+G3hP4sfCbxJH4n0HR9L1WS5sX0290vUJ5LdXjbY24SAcMCgPHvWeHy7D0GquFo8i7RuvwWhNbGzqJwr1OZ/3j9cvEf/AAxppli934M/Zp+NPjC9gUCDSPiL+0l/Z9hO3VVJ0/TlYgH/AKaL/vCvGp/j/wDHGxtZ9N+BfwA+AX7MlpMrWzeLtC0mTxv8Rwj/ACnbr2pyT3COOu6DyjnkEGvDvDvxa+IR1JR4t+FHkadkyGXwxrZubsN/dZJsAqfVWq74n+L3iCytmudG+Fut3saFpb241nUEsYbaJTubyljZmZgB0zzXr+ww0Y+0mpM4Y1Kl+WHKdZ4O8F+KNN17XfGvjnxnrHjfxh4lt1gv9Y1m4a5dgZPMfazMWLE9z246Vj+PvAWq69Naa54Q1v8AsTxPYbVjmcb7S4VW3Ksqd9p6HPFcn4Y+O1x4i+JFh4D/ALBto7LUdGbU7fU4r2b7ZasI2kEbRnKlcLjPFfTfhvRLjXNZsPD2j2gutY1q6XTdLt5bqGwN1cSsqohmmdY0wWGXdlUdyBzXTGWHnhpSWkYmajXjXinLVlPWP24v+CrniL4dy/BDWf2lvEWkfDK601vD18ujXVvZ3c2n7PLaEXUaLceWyZXargkHGa8h8CfDLw54L0y0hsoo7/Uzu+36vPHi6u2J+Zt3YElhxjlia/VXXf8AglX+2NrHwS1j4z/APxZ+z5+0nqPhbU10TxV8Fvg34qbxd4s8JTbY5Hglvt6211cIJFZ4oWUgMShk2mvCdM/Y2/bKSy0lPFP7K/xk8D6xrkkOnjS9X8H3PkPcyNhUtriPcjIxDMC5XaPvV5mBzDJV7RUZRjPXmWzfqelXweYJx9pF8rtbsfE84trb7RFHAqRJI37ouNrfdJyAcfMTxjtXinxIuLe5uPCmmNAs0F34jtbZowzBGVmw6Hnupr9DvE3/AATq/wCCjkupXcWn/sWfGy5sLedoo7230+2Rb6NVXEiq0/ToMnHGeK801r/gnJ/wUKm1nwrd6n+xd8btJ0/w9ra6teXP9gR388yx+WMLHHK2TgFq1p5ngZ4X2VOrFP1RnPBV4YhynGVvmcPdeHtFaKWwttMtls4nZXtUgXyFUEKMqBg4HrXjfiLwP4n0nVtP8ZfCvXh4T8QaPfpfWklq72K2k0JDw3ULpteOVXVTvT+70r9HdC/Yt/aw8V6zfw+Gf2fPi9q13byxLfWSeB7yzu4GmJKq8cqoqnHLBmAA5zXG/tE/sqfGn9l+y0af4yXnw7+GXibxJZSavpXwz8QeJRqnxOubPdtW5ktYUe3hViy4iaYthudteDmmYYFTjQlU96Tse3lmDr1HKVONlFX9TzX47/t5f8FKv2rfA2kfCf45/H2CDwPaWi2F9p3hW0j8Pav4rhjVV3ahNCEacsF+bLANuOVOa8At7CDwto1l4ctBNDZadbLHFKVNzIWZgzsqkEByxbJH+0PTFXwR43tvF82v2UllDZ6/4Tu1iuzHLusdQhbLLcRxliVIxgq3FdHbs0d5KsjkypJsWaZd0TZUsXK7sc5O0jHU147wmGwUZfVYKMZfF/e+Z66xVbFxSxEm+XbsTSSs6sZVVwZt4kVlZFPvz1qaSNWt4pGfdEfvSIFyh/ut83f1p01vtglVnHIWRY1LKoJ+8W5546Yohhl8uaGIulxEMtAz/LcLtUk9fU11nncl3Yz4mmB8yOQ8gxsX2kKPpuqwGmFttMIaOOfHmELtDNyn8X8qma7Rbh45bRcxsFkVV2oQBxzmrMJinkaS3RFtom8wWm5kaT+9sbplR6iuim3LYkr291NGYp40/feXmNgVyGz1OCOB1rUtbgOAkx5mdnaQsvz853dex9KrIZI5ZBEHhjB2OfM+dA/H0qM7o2UQTNMw+RAAPLj57c9T711wuveOe+uh+hP7FHkXP7EX/BbrR42DRR/CvwXryENubdDJcDeOnPyrXw9HYRSRQXEN5CYksPtBw0aSsw2BlbByc7ulfcH7ADpcfs7f8FqNFSNjJd/shaDrTRy7SvmW899uPAHevgqznieysi3lRGeyicgNiPmNW479cGvEyecpZhiIvo7no5nf2FF+RctDsuz5jSLFIMhi2HiCjP6mrM6xgN9j3i3jk855GjUP83+0O1Z4WSdHitmEsm5d5I3Kc/N1+tWVxuj+ZAqxec6lSQW6LHj1z3r6iLvqjwZqz0JYIFMkcZuTLsJeNlGAd38K1keJPD0HiXQdW0y5eWKHVbOTSrhIJfKnjMiMpZc9OD/jV+GaV48uBCGbMYROBz82O/T0qbypRdwrBIqRSsGkkZt7DA+9yOmK2a5o2ZhZX5onyton7OHi7w0LnT/DHxm8daLpFwN0llo2rXenKzfdO+OGZVbA2jOOhNd1onwT8Q2FheJ4j+JXjnxQtyUinW58UX0sFuP9lJJGXcenNfRdpp8k1xIkcyBkg370lxHyNrZY9MgZqTyhAskSeaqqjSSCM5Tcfxwc9j71pQwtGyfLsc9WpV5neR8w6j8CtflZbjwt8VviF4bs0/dyWUXia8Xbz97bHKq4IzwRWTceBvjJ4HvdNu9N+OPxCvYL+9WxvbTU/FGpXunalbyZElvcWzzkSIyrgq3HtX15bLDDBHLAJluJ/wDSLtJnXyWYfKOhzgrXD/ELUbC10nSrsQRwxpr1vGkkzd23R7txxjDHOKWKw1BUOaK6ovC15yrWl2PJ7Ox+Ick4tL3WvCJtmZkAt/D0yTggZVfM84n8a4/xx4t8Z+FNVsNC0HwtceLr+axa/lOn3XkJAittLfd7n8a9ssfE2hpcQxR3Vn5yZaVjcIWJ9evB/OrZ1zw/a3Q1aO8sDJHFJbwZvIo2ljwWZQxIOAeeTXd9Wo/V17KVvmcLrS9veokz528Oa58aNfuWgk+G9zokaglbrVtWjtLct/dVtjE5960/GbfGnSdNmisPBKatNdQtbB9P1n7cluzKRukj8pScZzw1fTVl4+8CzwB5b+yidxse3l1m3UxsP4jkkUxviB4MnmubaPVrENbRgGSTVbfZP/u4OCR9KSw8J0+V1ZfeaQquNTmjFHw/+zt8P/iFD8Wk8TeM/D1/pNlYaDcRG5niNrCzNGscSrljkncxr7S8daFL4g8NXVjHcXwlimhnCafPHa6hP5b75Io5yCULqCmSGxu6GrkPxF8KBtNtluRcJe3sOmgWmoRm5jaRvLjbywcsobOSMcfnXYZt95MayGQMyyecvG7PHylieRW9PCUFQ+r81rkSxFX2vt5I+jvhB/wVhh/Yn/Zr8dfs+fsBfstfFv4V/Fz4r6tb6t4w+Mfxc+IFr8RJLK8igW1+2aXapaxwbvLDqm9QFMmWViAR5z4c/bZ/4KNXklv4s8e/tj/GO48XxQl7A2/iOSCz0d3XLfuIwsBLfxBlOenFeYXNs8c0LBopGMYlLHgj/Z3Hn8BUxQXFus8Ls0gGJYTHsYFfbvkd64KORYDC+0mo3qS+09ex2yzPE1+SLk1Tj0uet3P/AAVr/wCCgVpbR2Y/a2+Jkt9YzfYb6U6vCtx5ittdnUxnnHIrzjXP+CsX/BR7xj4m0nwb4f8A2wPifZf25C0N1NBrKpLaeXtk8xXWMMrMitz2+vNfLXxI+Bs/ijV73XdD8R3nhy4vgs17Cibre7kUY8xlzncfUHHtTfhT8GLb4fXNxr+o6nLrWsywmFLoxZhtQ/8ArCp3HDHpzXEsNhY/uHh6aa62X+R1OVST9vGpJp9NT65H7Yf7ePg3Sof+EM/bI+OOhanNqA1DXJ/+Emm1G01W4bau+WOYt94j5ipVcZ4xxXlX7Tf/AAUV/ay+Nul+C9L+NXwz8G+PfiR4K0e58OaZ8aL3wpFquua7Z3Eu6N5Iypt1lC7VLBBnaD1+aqGqnACSkMpfzjIo3NIuFIVe4PP8qvaiqyxK23Y4tlhExGW6fwr7V5GNyzDYjEzqOK92zR7GDx9bDUYxj9rQ+c/gZ4Q1Hw/ouv614rili8QeMZluGhY+RJa26MWLMvTl+3YV61qV2Hg2QrILlURYpjID5yrxwc4+UcVauH3NFuLSyW/yAgEkBvvNnP6VmzXKLBbx7mSFCXTAJfnr39a83FtNcj2O7DRcYXNaSeHaIt0kqxptgOYy3Xhskgc+9PjdIZLiaTy5iYivmSKNo3Y42g5yMVl+Ykkcdu0jHAVpMncx7fLznpU0yGMRGNn2gb1kcMsUgXruGe1aKbMuV2uNuZZG2KyQpLvVyqIUkI+9nOc10MbwSQlbWEzCGPLLGpi8pum/OcnPQg5rHubqK5uYr242xyRqgKRLx8nTr60jXHnyRqhAAfczxMY95bn5sce1b0Ze8ZVI3NWzuvOEcU0LrFMd81woAwV7KOox70kapbWzXHa42+WgkO6QlsMdp9OKddRypHNdqUZZDseKLgj5gPwqtFC7RRLGgxNwjN8zQ85IH+NejBM45Wiz9DP+CcSRT+Ff+Cuekxea6at/wT7/ALTKMuQ7QXV9/LIr88tMaO70rRVADb9KtXjUgbgPs8fLN09K/SL/AIJfw+d4m/4KTaPHH5ial/wTc1qOMH7spt7qblh3OWNfmd4VCyeHfDc4y9u+h2bMpf5/mhhAyceteRldNRzHEef/AADvzCXNh6XobsDPE8ieW0iqwCLFmJ5B0zkelWIpUiV5CrysV2pG7Nk/3uPb3q5FLHAyt8z5Icv1AUfwlcZyKqor3M4uURpcS5lRU25+739t3pX09NWVzxJtdSZZCCXvYHtcHakQIYvuH3k9h1wa+bfH3xpufA/j+48O3WqafY6ZD4dtby2N1bRLNctK7K5yScnjI9s19LSeVcSpJKrOkbsQjvgJxgKAeeteZ+MPhL8PvGurw6j4n0WK/vxbNawXE0xhaGNG/doMN1wxAqcRGrNL2chUnCPNzxPrz9lXwB+yj8ePg5q3jP4v/wDBSP4X/sz+P7fxfdaLa/DrxVoEOopd2MMMMkN95iL5uJWkkXaB/wAs693k+CX7B+jwLb3n/BWH9nPXVhi2PqMPgnxDcPJn+95EPl8e+PrX5fwfs0/CeI718HWYUosi+bdySqv1BfPdv++q7uy+FPgPQLGKy0/w1o0dkF8x0SGOcv6buS3X6VzxwOZSlKX1iy7WQvrmBjBJ0Lv1Ptub4QfsLid3X/gsn8CtPtW/5c9N+EesTGDaPuqzQ7icdia7jwN+y7/wS++JOov4d8ef8FXPAPxB03a14nh/S/Amr+DZbiZMsk32tIS7BeuyvzJvP2f/AITX0rXsfha1NxdSefcNGDDCpP3lVc5Ax+NcB8Rvg7Y+FfDtx4h+GPh2JNc0m4jnVYXb7S0DcSRrg5ORn35rPEYHMqOH9o8Q36JGtDHYGpW5HRSP3dj/AOCdP/BFiRltX/bk0w3Un3ja3viK5DL/AHlUx4xXI6h/wTI/4I7TPIF/4KIz2lmSZI7aLwfqmpvH/eXfIvTHtX85Np8TvHcMflz+C/ELy2pwLgPLF5YPGOYySoNTyfFr4hlFt5PDmvRDcuVSaQRj5vu8Rjr05pUYVFC/1qrf0j/kZ1ZQc9KEPvZ/RppX/BMX/giFbNHJrv7enjnVo1P70aR4EurV5M/3m+yyACu/i/4J5/8ABvXZRb779qH42agYSFlnt9O1CME/RNLI5r+Z22+MXi+3ijiHhjxTbbT+88t/PDt7ho93HXOeK1oPjT4kgtWtx4f8XRwb96DaCHP8W48H8RV/UqdZ2niq3y5V/wC2mUa9SGsKEH/Xqf0J+Ov2W/8Ag3O8Cafa67o/7U/x+8Ma1pmoQz2WtafoOqa5co6srKqwS6ckZwVzhjj2xXEzeKP+CIifKn7f37TzrnOIvgbbPI23p832XJP1r8Y/Aus658XNT0rw7rnh3VovDdjetqWtajrSybHWOP8Adw7BhQSeAR+de8WvwL+FF1K/n+HoolAYCZl3Ju/h4z0rajkte/8As2LqW87f/IjeZwTtWowXyP0JuPHH/BGO2nB0f9sf9qvxbldj2z/AG0vHX6YMJH61LP8AEX/giO1nFbXf7Wn7V/h7UOZbqO3+BFukpb3V94AH+9XwVpHwm8EaBvutG0SyikmPkOu1m3oy/ewTiq+tfCzwTrk4e88PabcSWn8bW8aZ3fwlq6quS4uVNQWKnf1X+RNLNMNGUnKjH7j7E8Q6t/wSd8W6adJ+Fv8AwUV+MXgXxDOVgsr/AOLv7PIk8MsS2P8ASJ7VTJGMn7204GTg14D8U/gj+0V8BPCEvxlgX4f/ALTv7NsqHHxh+DGpJq+kQQsRuml8rDQTR9Xt7qGORNy7lx81eK3nwE8AX8PlN4bsv3qrDiEl5xk/wnPX/Ir6f/4Jpardfs8ftV6Z+zp421WTU/2Y/wBsiwuvg/4o8NapOZtI0HWr63ZdE1BUJ2rKlwyxeYOSkrIeNu3wsxwmOyul7WlUbt3Pdyytg8yqexrQtJ7W0PAdG1vT/Edn4b8Q+GNSstW8O6paM8U0QBlVmCmSGZfm2Sxj+H2rT1WN5QpWMcx7UiX5Xb1z/wDWry/4c+BtT+D3xl/aG+Bc8krWfw7+JN9p+nXUpYxQxwXEkW3B4UtHtJzz8re2PV7uVZLucxsZcP8AuHClzg/L246104S9bDuvU0lJHHiYLD140I7JnMTRxl4wiGKaQNGCG80DDBfmxwDj1rndUtEgaOJJoTJzJv8AmIwx6Hmu7v7ZWaV7aFRNn5JURg20cn5c4zjOeK5mSFYmR7pYDLMNiRTxtIzKBu8zhl4J43fpXz2Ni1PlR7eFa9nqVXQuPMUFSwVdjHBHXcuc9cYNTrbrshWZjKuzcQsmxWY9M5PAFe6/sWeKv2MvB3gXxtpn7cXwH/ak+KXxBuvHE2o+EtY+FfiyHStBj0d44/Lt3U3UJ3rIsnQEbWUe5+tdR+MP/BHyKW2vNP8A2H/23pYYF2SW83xNs4VutpzlmN8xH4U4zq396mzOcXvCSsfm9F9ldpE8lAXTLTyjcMdgGz1+gqG1gijO2YmOFX3mSNMvJjbhRz1571+kEn7U3/BJGx8sW3/BNn9ra+ypaI3/AMclg8zb/eUXhFdVd/tV/wDBNxbFLnTv+CZ/xXULb5+xaj+0bHBeMu0fL8m5g+B03Zrpw9WvzaUZfh/mYThHl96oj8zI7adoJLcQyKHzvIdSx/iyPw7VNHbORGYxL50fqnRf73pz0wfzr7yl/bg/YJtXI0z/AIJDeO9QZcO8ur/tJXsobt8zKcYz+lRr+35+yLb4/s//AII3aGIpW3Fta+P+qXbA/wC0FXv9QK7VisQtI0Zfecnsab3qI9P/AOCTmnXDePP+CgXiyeNF8K+HP+Cfev6J4m1Vm22GlXd1cTTW1vKx4EjpFI20/wAODwK/KfweS3hDwuJGaJpfD1mzhofLRv3UZHHXgHrX278Uv+CgnxP+LPwf8U/szfBP9mj4RfsN/s/+OriO6+LFj8N7yTX/AIifEuH5S1jc6pIo2pIECNhWbaxGcE5+SmjsbOzSyS02G3SOK3wx/cxqqxxw47BQq1WW4eqq1TFVlZy2X+YYqtGdONCOyI44QP3tu4MsKbpXfkfN1PvxUrJLahRI3JG9Fil2lj8vzHHpgU1UEIQ7xIrRbgo6oe2fXFW7aeTzVEkcTpEGQpImWKt/EOeor3VvY8sha5lDb2jQnO4N5X7zHfqf1qYBLkLHKI13/vcuxLSe3UgUjW5V9yIWjd/3PmNuGf8Aa56ewq6dNCQRu0YBlDCN43+Yk9sVtCmmzKpLQrNaFXMMaDcgUyTB87l/2V9R6VrQXbQ280MLRMZuYWlUlwQOmCcYz6VWt7GJU2yEmTaWDkEbcVdMMQt5GmkjSFDudgpfylXljyeBj0robjSp889jntKc+WK3Kh1KeD5buOygjjHnztIwi8gejqe5rzm9+Pfwf8P3zaXrPjjw4l0XYTwwXTXcsB6fvGRSuQeMdfavO/it4ovNV8Jaxe6JKcXSw6XoM0btFOzXLLFHJJ3H385zxtqT4cfBj4c+ALq00hNO07xJ4sk****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[/img]
The item at the top holds the lug nut key and the black item at the bottom is a tow eye. It screws into your bumper behind the approximately 2" by 2" plate on your bumper. The jack is in the passenger side well and on the driver's side of the trunk, up on the inside, is a Lexus first aid kit. It's held on by Velcro and measures approximately 8"x8"x2".
Well, that didn't work. I tried to submit a picture and it filled in with all kinds of strange stuff. Then, I couldn't edit. Still learning.
I think if you take a close look you'll see that the "bucket" helps support the trunk mat. So, if you put a heavy item in the middle of the trunk there is support that will help keep the mat level and not bow down. Also the bucket is a handy place to keep little stuff.
In the tool tray: 2 box end wrenches (mm) 1 pair of pliers, a tow eye, a lug nut key, a lug wrench, a phillips screwdriver, a straight blade screw driver, and a jack handle,
The "bucket" is a handy place to keep things for roadside use. I keep jumper cables, clean gloves, and the tar/rope style tire plugs and tools to install them along with a foot pump for flat repair (usually on OTHER peoples cars). There is also a piece of scrap carpet in there for me to kneel on when doing anything with the aforementioned tools. Seems I am everyone's emergency contact but there are worse things in life. I also keep a couple massive garbage bags and a small tarp shoved around the spare tire.
JL626
06-05-10 12:42 PM
