Got a replacement Engine and Transmission
Hey all,
So I was able to find a replacement transmission. Car history report shows last emission done at 2008 with 25k miles. it seems like the owner did the emission waiver if they drive less than 5k miles a year. Looked inside car and found all original dealership documentation and manuals/booklets, even wheel lock number card.Turns out the car was junked after the owner passed, so I took out the engine transmission combined.
Engine looks clean, took off the valve covers and its golden stained from motor oil. Engine Oil dipstick still has clean fluid. The coolant reservoir had bright red coolant. I took the upper portion of the timing belt cover off and the belt looks almost brand new maybe. Hard to do a compression test by hand cranking the crankshaft pulley.
What should I do now? Transmission and engine fluid was drained by junkyard. I thinking about adding an extra external trans filter in line to the radiator. and opening up both pans (engine and trans) to see inside.
Tags: 2000 ES300 U140E
If you didn't find sludge under the valve cover I see no reason to open the pan. For the tranny use a high quality synthetic ATF and you're good to go the problem with the U140E is not heat but simply a bad design. I would replace the transmission filter with an OEM unit (the aftermarket I've seen are cheap and scary looking).
The replacement engine had the active vacuum front mount with vacuum line hoses, anyway to delete that? If not I can go back and pickup the mount off the subframe.
There are multiple design flaws the worst IMO is how quickly the fluid darkens meaning clutch material gets into the fluid I'm not a tranny expert so not sure why. When this happens the fluid doesn't do its job properly and you have a snowball effect. I would replace the fluid for sure I'm currently using Amsoil but have not run it long enough to know how good (or not) it is.
Your car should have the active mount.
The OEM one is going to say “Genuine Toyota” on the box. ![Wink](https://www.clublexus.com/forums/images/smilies/wink.gif)
I have seen cases where the TC was starved for fluid because of aftermarket Autozone filters (read at TN, not saw it with mine own eyes...). But, honestly I wouldn’t bother with the pans if it is really low miles. Not sure how many miles you are saying are on it. If over 100k, I would change the at filter.
A magnefine inline filter on the aux cooler lines is a good idea. I believe it’s a 3/8” fitment. I would also put some Lubegard red in the AT. It works.
Bought it at the dealer could be wrong but I believe the question was who makes the filter for Toyota.
Agree with all of this except I would drop the pan the old fluid could have dried up in the filter and ruined it.
Called the dealership for the trans filter and they quoted $90 for the transmission filter I found online for $40.
Would this be the correct part number: 35330-06010?
Strainer - Lexus (35330-06010)
Do exhaust and intake gaskets matter brandwise, ofcourse OEM is great, but they are special order, and won't get in a week.
In the future tell everyone what car you own not everyone is familiar with your ride or post history. That's the correct filter for a 2000 ES300 on gaskets get anything made in Japan such as Ishino/Stone, Victor Reinz, Mahle etc.
So I got all the gaskets received, and was about to install the valve cover gaskets for both banks. Issue I'm having is that, the diy I found (Diy valve covers) lists that each bank has 8 bolts. This replacement engine and my current installed engine have 9 per bank.
I just called the dealer and even they stated there's 8 per bank.
Was this a design revision?
There are 9 per bank don't why the dealer told you 8. Look at this diagram is shows 18 total.
http://www.japan-parts.eu/lexus/us/2..._cylinder-head
edit - I see where the confusion is coming from the VVTi engine (like yours) has 9 per the 1998 and earlier are non VVTi and have 8 per.
