02 lexus es300 knock sensor splice
Old 02-19-19, 07:44 PM
crawdawg
crawdawg's Avatar
Default 02 lexus es300 knock sensor splice
I have an 02 lexus es300 and i have a code for the bank 2 knock sensor. I have read on some forums about earlier year vehicles just splicing the 2nd knock sensor into the 1st knock sensor. Does anyone have any info on if this will work or how to do it? I cant find a pin diagram for my ecu anywhere to tell which wires are the sensors. Every time i go to drive the car it goes into into limp mode so i would really like to get this taken care of the cheapest way possible. I had both sensors replaced once before. The weird thing is when its cold outside it will sometimes not do it but when it is hotter, it will instantly throw the code. Any help would be greatly appreciated.
Old 02-19-19, 08:43 PM
Received 3,031 Likes on 2,546 Posts
Not sure if this file will help or not. The knock sensor wires at the ECU are shielded so you should be able to see this.
File Type: pdf
Old 02-20-19, 06:30 AM
HomerJay
HomerJay's Avatar
As an alternative method you could make the piggyback splice at the end of the knock sensor wiring harness which is located under the air filter housing. This eliminates any concern you may have picking the correct wires and is easily reversible if you decide to replace the knock sensor harness. I did this repair and was successful.
Old 02-20-19, 04:18 PM
crawdawg
crawdawg's Avatar
Thank you both! I’ll probably just do the splice in the engine bay if I can do it that way! Seems easier to me!
Old 09-23-19, 10:34 AM
spaldingcl
spaldingcl's Avatar
could i see a picture of what you did?
Old 07-11-24, 01:32 PM
prezjacob
2nd gear
prezjacob's Avatar
Default Just did this.
2000 Lexus ES 300. Picked it up for $400. 148xxx miles. Had the blade of a key but no microchip. Got one programmed for $350. Replaced variable valve timing solenoids for one code. Runs good now but no overdrive. Highly annoying. Now just p330 code. Was about to either attempt it myself or possibly spend upwards of $1000 to have someone open up the valve cover and do this repair properly. Went to oreilly’s. Bought some splice tabs. Did this hack. In the engine bay and on the old harness. That way if I messed it up, well I’d just have to replace what I already needed to replace. IT WORKED. 100%. Hundreds of miles later no cel and good gas mileage. Thanks for this post. Could not have done it without you. Love my 25 year old Lexus! LLL (Long Live Lexus)
Old 07-24-24, 10:14 PM
FavCar
1st Gear
FavCar's Avatar
So you just connect the 2 copper wires together? What tabs did you pick up from Oreilly's?
bolsen
10-09-20 08:55 PM
jaredmac11
10-15-19 09:40 PM
turtle54
05-27-17 07:34 PM
mitmaks
09-26-13 08:57 PM
Quick Reply: 02 lexus es300 knock sensor splice
